Ciao, good evening.
So, I pulled the trigger on the Pianeta Fibra Diva 6000 promotion. Even if [for now] I 'only' manage to upgrade my upload from 1Gbps to 2.5Gbps - it's fantastic value. Then when prices come down for 10Gb equipped hardware, I can make full use of the connection.
I have a technical question if I may.
I was thinking of adding a Deco BE25 router/mesh which gives me Wifi 7 and a pair of 2.5gbps ports. Although it claims to support PPPOE I'm trying to understand from the documentation if there's a way to set the user credentials inside the Deco master unit.
It would help me to plan by understanding whether, when OpenFibre connect me to the POP and install the ONT - do they have to configure something on the ONT (ie. it's not just a passive media convertor) - or would the authentication need to take place on the router?
Basically, if I were to connect a PC with a 2.5gb Ethernet Port to the ONT, would I get a class C DHCP address (and DNS etc.) from the ONT? Does the public IP get assigned to the ONTs Optical port and is NATed by the ONT? I guess I'm trying to avoid having an unneccessary router (as I do today) just acting as a modem, when the media converter might be doing the job of the modem
I was also wondering if, when the installation is done, and the ONT (which will have a 10gb Ethernet Port) is cabled to a 2.5gb router - does this negotiated speed somehow 'stick' so that Pianeta Fibra will create a profile with 2.5gb, or can I later on swap the router out with a 10gb device and hopefully it will re-synch at 10gbps (even if traffic is capped at 6gpbs)
Last question. By opting for the 6.0/2.5 product - even if the minimum speeds are probably the same as the 2.5/1.0 product - could I reasonably expect to get 2.5 most of the time (considering that I have a contracted for max 6.0 bandwidth)?
All feels a bit silly talking about these speeds when in the real world [today] there's hardly any benefit for a home user to have such bandwidth - but I guess I'm amongst nerds here 😁 so you'll understand the quest for having the best connection I can reasonably have without spending a fortune - which I think this Diva offer seems to be.
Grazie mille e buona serata. K
