TheMarsican Gli ONT esterni, con uscita RJ45, soffrono entrambi di qualche problema in upload su server con latenze oltre i 20/25ms con link 2,5G (PC-Router):
Non so se hanno risolto il problema o se il mio è un caso fortunato ma ieri facendo un po di test non ho notato problemi
Server: Wind Tre - Milano (id: 27363)
ISP: Wind Tre
Idle Latency: 9.96 ms (jitter: 0.04ms, low: 9.91ms, high: 10.01ms)
Download: 948.27 Mbps (data used: 967.0 MB)
15.69 ms (jitter: 1.35ms, low: 11.54ms, high: 47.02ms)
Upload: 942.80 Mbps (data used: 856.5 MB)
21.35 ms (jitter: 7.67ms, low: 9.16ms, high: 321.24ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/89fb262c-c626-4985-ae7f-2cf56390fbb1
Server: Grain Connect - Manchester (id: 59135)
ISP: Wind Tre
Idle Latency: 35.97 ms (jitter: 0.22ms, low: 35.83ms, high: 36.40ms)
Download: 948.95 Mbps (data used: 1.3 GB)
42.44 ms (jitter: 3.06ms, low: 34.86ms, high: 155.25ms)
Upload: 936.02 Mbps (data used: 1.1 GB)
80.21 ms (jitter: 13.03ms, low: 37.26ms, high: 206.05ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/af1c71d1-6f3e-48ce-ab57-ba87b8fb5684
Server: Telenor Norge AS - Oslo (id: 12919)
ISP: Wind Tre
Idle Latency: 59.92 ms (jitter: 0.20ms, low: 59.65ms, high: 60.09ms)
Download: 894.83 Mbps (data used: 1.5 GB)
100.14 ms (jitter: 12.08ms, low: 59.24ms, high: 237.27ms)
Upload: 936.08 Mbps (data used: 1.3 GB)
136.56 ms (jitter: 40.85ms, low: 57.53ms, high: 342.63ms)
Packet Loss: Not available.
Result URL: https://www.speedtest.net/result/c/74e057ef-d034-43c7-986e-fb48af2d7f4c
Server: Deutsche Telekom - Berlin (id: 30907)
ISP: Wind Tre
Idle Latency: 28.49 ms (jitter: 0.13ms, low: 28.43ms, high: 28.81ms)
Download: 946.39 Mbps (data used: 1.6 GB)
38.31 ms (jitter: 21.13ms, low: 26.62ms, high: 352.12ms)
Upload: 938.52 Mbps (data used: 1.1 GB)
49.91 ms (jitter: 4.82ms, low: 27.84ms, high: 171.72ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/cf32c679-07f6-4ab6-bb4a-c54f01863d18
Server: Telia Sweden AB - Stockholm (id: 45936)
ISP: Wind Tre
Idle Latency: 37.73 ms (jitter: 0.41ms, low: 37.49ms, high: 37.99ms)
Download: 949.70 Mbps (data used: 1.2 GB)
42.41 ms (jitter: 8.41ms, low: 37.34ms, high: 340.91ms)
Upload: 938.51 Mbps (data used: 1.3 GB)
79.30 ms (jitter: 10.57ms, low: 40.22ms, high: 186.06ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/ae7d7f01-ca0b-4948-95ab-76b1cb09fa1e
Server: CJSC RASCOM - Moscow (id: 20933)
ISP: Wind Tre
Idle Latency: 67.89 ms (jitter: 0.14ms, low: 67.74ms, high: 68.15ms)
Download: 935.22 Mbps (data used: 1.5 GB)
111.54 ms (jitter: 19.90ms, low: 71.29ms, high: 225.18ms)
Upload: 929.87 Mbps (data used: 1.3 GB)
128.82 ms (jitter: 33.61ms, low: 65.00ms, high: 271.72ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/72c6ca71-df52-421b-8685-e61c105279b3
Per completezza di informazioni sono in VULA FW sotto FC con ONT Sercomm FG1000R e sul router Wind XB432V non ho impostato Qos nonostante ne fosse equipaggiato
Che sia stata la classica fortuna del principiante ? ovviamente con il tempo che ho a disposizione se qualcuno vuole qualche test in piu appena ho tempo lo farò
