Buongiorno a tutti, dopo aver passato qualche mese a provare a diagnosticare (senza successo) i problemi rimasti da un precedente disservizio di OF (qui il thread), ci avevo quasi rinunciato credendo fosse semplicemente un comportamento normale delle connessioni ad alta velocità.
Oggi però mi accorgo che specificando alcuni server su speedtest CLI, la parte upload fallisce completamente.
Iniziando con uno speedtest riuscito, verso EOLO milano:
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
❯ speedtest -v -v -s 11427
[2024-09-09 17:29:42.668] [info] Resolved address 1: 104.17.147.22
[2024-09-09 17:29:42.669] [info] Resolved address 2: 104.17.148.22
[2024-09-09 17:29:42.833] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=b919e86ccc9e22a2fe988d4880bb0634f661dd8d5a93a956b08388b2620c5bb8&hid=a91%2520%2520%2502%250E%2505W%250CZ&serverid=11427&sid=60aeeacd923819f5302a91b85c86c646849f1cf1dff978dd064a6c87cf9c7590&uname=Windows%20%20Microsoft%20Windows%20%5BVersion%2010.0.22621.4037%5D%20AMD64) completed with response code 200
[2024-09-09 17:29:42.838] [info] configuration content:
{"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"b191390266e8c680-Ceb5e7c04bf39a1a5-697cc3cf0fd49ab5","license":{"message":"You may only use this Speedtest software and information generated\nfromit for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location.Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policyat:\n\n       http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"11427","host":"test.eolo.it:8080","name":"Milan","country":"Italy","sponsor":"EOLO","sponsored":false,"host_functional":"1"}]}
[info] Configuration expiry date: 1726531200
   Speedtest by Ookla
[info] Server count: 1
[info] app.version: 1.2.0.84 (ea6b6773cf)
[info] server selected: 11427
[info] Server id: 11427
[info] Name: Milan
[info] Country: Italy
[info] Sponsor: EOLO
      Server: EOLO - Milan (id: 11427)
         ISP: Dimensione
[info] Running TCP test suite
[info] Running Speedtest against host:port test.eolo.it:8080
[info] Starting stage 1 of type 2
[info] Resolved address 1: 88.149.202.248
[info] Opening socket to '88.149.202.248'
[info] Ping 1: 8.58 ms (8.58ms min, 0.00ms jitter)
[info] Ping 2: 9.10 ms (8.58ms min, 0.52ms jitter)
[info] Ping 3: 8.75 ms (8.58ms min, 0.43ms jitter)
[info] Ping 4: 8.62 ms (8.58ms min, 0.33ms jitter)
[info] Ping 5: 8.57 ms (8.57ms min, 0.26ms jitter)
[info] Final Ping: 8.57 ms
[info] Stage 1 completed
Idle Latency:     8.65 ms   (jitter: 0.26ms, low: 8.57ms, high: 9.10ms)
[info] Starting stage 2 of type 3
[warning] recvfrom failed: An invalid argument was supplied.
[warning] Loaded latency: cannot read response.: [10053] An established connection was aborted by the software in your host machine.
[info] Stage 2 completed
[info] Smoothing graph for test with 0.668 progress, with duration of 1000 ms in 60 updates
    Download:  2141.13 Mbps (data used: 2.6 GB)
                 34.45 ms   (jitter: 21.49ms, low: 8.85ms, high: 314.18ms)
[info] Starting stage 3 of type 4
[info] Packet loss sent=162, received=162, dupes=0, maxId=161
[warning] Receive error: 10060 (A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
[info] Connection 1 failed. Added connection and continuing test.
info] Stage 3 completed                                     atency: 8.44 ms
[info] Smoothing graph for test with 0.394 progress, with duration of 1000 ms in 60 updates
      Upload:   443.58 Mbps (data used: 326.4 MB)
                 11.15 ms   (jitter: 1.36ms, low: 7.51ms, high: 22.14ms)
[info] final result - serverid: 11427 ping: 9 download: 2141132 upload: 443577
[info] latency 9ms jitter: 0.26ms packet loss 0.00%
[info] total download bytes: 2639836751
[info] total download stage duration: 10026.371000 ms
[info] total upload bytes: 326374943
[info] total upload stage duration: 5903.000000 ms
[warning] No libz support available, not compressing data.
[info] HTTP request (effective url: https://results.speedtest.net/reports) completed with response code 200
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/9852678a-c56d-492d-8a60-e9033d747115
~ took 20s
Fin qui sembra tutto normale, andiamo ora su windtre e fastweb
Windows PowerShell
❯ speedtest -v -v -s 27363
[2024-09-09 17:23:09.054] [info] Resolved address 1: 104.17.148.22
[2024-09-09 17:23:09.055] [info] Resolved address 2: 104.17.147.22
[2024-09-09 17:23:09.210] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=b919e86ccc9e22a2fe988d4880bb0634f661dd8d5a93a956b08388b2620c5bb8&hid=a91%2520%2520%2502%250E%2505W%250CZ&serverid=27363&sid=60aeeacd923819f5302a91b85c86c646849f1cf1dff978dd064a6c87cf9c7590&uname=Windows%20%20Microsoft%20Windows%20%5BVersion%2010.0.22621.4037%5D%20AMD64) completed with response code 200
[2024-09-09 17:23:09.215] [info] configuration content:
{"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"b191390266e8c680-Cd4ede49f77d946ac-9567a2aa85a1f4f8","license":{"message":"You may only use this Speedtest software and information generated\nfromit for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location.Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policyat:\n\n       http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"27363","host":"speedtest7.windtre.it:8080","name":"Milano","country":"Italy","sponsor":"Wind Tre","sponsored":false,"host_functional":"1"}]}
   Speedtest by Ookla
[info] server selected: 27363
[info] Server id: 27363
[info] Name: Milano
[info] Sponsor: Wind Tre
      Server: Wind Tre - Milano (id: 27363)
         ISP: Dimensione
[info] Running Speedtest against host:port speedtest7.windtre.it:8080
[info] Resolved address 1: 151.78.3.129
[info] Opening socket to '151.78.3.129'
[info] Ping 1: 32.39 ms (32.39ms min, 0.00ms jitter)
[info] Ping 2: 31.92 ms (31.92ms min, 0.47ms jitter)
[info] Ping 3: 32.29 ms (31.92ms min, 0.42ms jitter)
[info] Ping 4: 31.92 ms (31.92ms min, 0.40ms jitter)
[info] Ping 5: 32.29 ms (31.92ms min, 0.39ms jitter)
[info] Final Ping: 31.92 ms
Idle Latency:    32.18 ms   (jitter: 0.39ms, low: 31.92ms, high: 32.39ms)
[info] Smoothing graph for test with 0.581 progress, with duration of 1000 ms in 60 updates
    Download:  2273.20 Mbps (data used: 2.4 GB)
                 23.65 ms   (jitter: 3.94ms, low: 21.76ms, high: 249.94ms)
[info] Packet loss sent=141, received=141, dupes=0, maxId=140
[info] Connection 2 failed. Added connection and continuing test.
[info] Connection 3 failed. Added connection and continuing test.
[info] Connection 4 failed. Added connection and continuing test.
      Upload: FAILED
[error] Cannot read:
~ took 17s
Windows PowerShell
❯ speedtest -v -v -s 7839
[2024-09-09 17:21:42.164] [info] Resolved address 1: 104.17.147.22
[2024-09-09 17:21:42.165] [info] Resolved address 2: 104.17.148.22
[2024-09-09 17:21:42.281] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=b919e86ccc9e22a2fe988d4880bb0634f661dd8d5a93a956b08388b2620c5bb8&hid=a91%2520%2520%2502%250E%2505W%250CZ&serverid=7839&sid=60aeeacd923819f5302a91b85c86c646849f1cf1dff978dd064a6c87cf9c7590&uname=Windows%20%20Microsoft%20Windows%20%5BVersion%2010.0.22621.4037%5D%20AMD64) completed with response code 200
[2024-09-09 17:21:42.286] [info] configuration content:
{"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"b191390266e8c680-Cc0ed6380090f2de7-d8032748af118df8","license":{"message":"You may only use this Speedtest software and information generated\nfromit for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location.Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policyat:\n\n       http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"7839","host":"spd-pub-mi-01-01.fastwebnet.it:8080","name":"Milan","country":"Italy","sponsor":"Fastweb SpA","sponsored":false,"host_functional":"1"}]}
   Speedtest by Ookla
[info] server selected: 7839
[info] Server id: 7839
[info] Name: Milan
[info] Sponsor: Fastweb SpA
      Server: Fastweb SpA - Milan (id: 7839)
         ISP: Dimensione
[info] Running Speedtest against host:port spd-pub-mi-01-01.fastwebnet.it:8080
[info] Resolved address 1: 89.96.108.170
[info] Opening socket to '89.96.108.170'
[info] Ping 1: 20.88 ms (20.88ms min, 0.00ms jitter)
[info] Ping 2: 21.19 ms (20.88ms min, 0.32ms jitter)
[info] Ping 3: 20.79 ms (20.79ms min, 0.36ms jitter)
[info] Ping 4: 21.19 ms (20.79ms min, 0.37ms jitter)
[info] Ping 5: 20.83 ms (20.79ms min, 0.37ms jitter)
[info] Final Ping: 20.79 ms
Idle Latency:    20.96 ms   (jitter: 0.37ms, low: 20.79ms, high: 21.19ms)
[info] Smoothing graph for test with 0.662 progress, with duration of 1000 ms in 60 updates
    Download:  2226.44 Mbps (data used: 2.7 GB)
                 43.67 ms   (jitter: 18.22ms, low: 21.53ms, high: 355.83ms)
[info] Packet loss sent=161, received=161, dupes=0, maxId=160
warning] Receive error: 10060 (A connection attempt failed because the connected party did not properly respond after aperiod of time, or established connection failed because connected host has failed to respond.
      Upload: FAILED
~ took 18s
Upload falliti in entrambi i casi. Spostandosi su server internazionali la situazione non fa altro che peggiorare
❯ speedtest -v -v -s 56181
[2024-09-09 17:24:15.200] [info] Resolved address 1: 104.17.148.22
[2024-09-09 17:24:15.200] [info] Resolved address 2: 104.17.147.22
[2024-09-09 17:24:15.371] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=b919e86ccc9e22a2fe988d4880bb0634f661dd8d5a93a956b08388b2620c5bb8&hid=a91%2520%2520%2502%250E%2505W%250CZ&serverid=56181&sid=60aeeacd923819f5302a91b85c86c646849f1cf1dff978dd064a6c87cf9c7590&uname=Windows%20%20Microsoft%20Windows%20%5BVersion%2010.0.22621.4037%5D%20AMD64) completed with response code 200
[2024-09-09 17:24:15.376] [info] configuration content:
{"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"b191390266e8c680-Ce890d00a2d98daeb-ff2210c883aca0c6","license":{"message":"You may only use this Speedtest software and information generated\nfromit for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location.Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policyat:\n\n       http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"56181","host":"sh-speedtest.utopiafiber.com:8080","name":"Salt Lake City, UT","country":"United States","sponsor":"UTOPIA Fiber","sponsored":false,"host_functional":"1"}]}
   Speedtest by Ookla
[info] server selected: 56181
[info] Server id: 56181
[info] Name: Salt Lake City, UT
[info] Country: United States
[info] Sponsor: UTOPIA Fiber
      Server: UTOPIA Fiber - Salt Lake City, UT (id: 56181)
         ISP: Dimensione
[info] Running Speedtest against host:port sh-speedtest.utopiafiber.com:8080
[info] Resolved address 1: 69.162.234.239
[info] Opening socket to '69.162.234.239'
[info] Ping 1: 141.40 ms (141.40ms min, 0.00ms jitter)
[info] Ping 2: 141.05 ms (141.05ms min, 0.35ms jitter)
[info] Ping 3: 141.07 ms (141.05ms min, 0.18ms jitter)
[info] Ping 4: 141.15 ms (141.05ms min, 0.15ms jitter)
[info] Ping 5: 141.04 ms (141.04ms min, 0.14ms jitter)
[info] Final Ping: 141.04 ms
Idle Latency:   141.09 ms   (jitter: 0.14ms, low: 141.04ms, high: 141.40ms)
info] Stage 2 completed                                     atency: 141.70 ms
[info] Smoothing graph for test with 0.801 progress, with duration of 1000 ms in 60 updates
    Download:    17.71 Mbps (data used: 25.9 MB)
                141.65 ms   (jitter: 0.22ms, low: 141.12ms, high: 143.12ms)
[info] Packet loss sent=195, received=195, dupes=0, maxId=194
      Upload: FAILED
~ took 22s
Windows PowerShell
❯ speedtest -v -v -s 63731
[2024-09-09 17:25:15.493] [info] Resolved address 1: 104.17.148.22
[2024-09-09 17:25:15.494] [info] Resolved address 2: 104.17.147.22
[2024-09-09 17:25:15.641] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=b919e86ccc9e22a2fe988d4880bb0634f661dd8d5a93a956b08388b2620c5bb8&hid=a91%2520%2520%2502%250E%2505W%250CZ&serverid=63731&sid=60aeeacd923819f5302a91b85c86c646849f1cf1dff978dd064a6c87cf9c7590&uname=Windows%20%20Microsoft%20Windows%20%5BVersion%2010.0.22621.4037%5D%20AMD64) completed with response code 200
[2024-09-09 17:25:15.646] [info] configuration content:
{"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"b191390266e8c680-Cc6f341e59f83206e-4478ec1aedafc138","license":{"message":"You may only use this Speedtest software and information generated\nfromit for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location.Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policyat:\n\n       http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"63731","host":"speed.vm.brs.marcusn.co.uk:8080","name":"London","country":"United Kingdom","sponsor":"Virgin Media","sponsored":false,"host_functional":"1"}]}
   Speedtest by Ookla
[info] server selected: 63731
[info] Server id: 63731
[info] Name: London
[info] Country: United Kingdom
[info] Sponsor: Virgin Media
      Server: Virgin Media - London (id: 63731)
         ISP: Dimensione
[info] Running Speedtest against host:port speed.vm.brs.marcusn.co.uk:8080
[info] Resolved address 1: 63.135.78.172
[info] Opening socket to '63.135.78.172'
[info] Ping 1: 43.84 ms (43.84ms min, 0.00ms jitter)
[info] Ping 2: 44.40 ms (43.84ms min, 0.56ms jitter)
[info] Ping 3: 44.84 ms (43.84ms min, 0.50ms jitter)
[info] Ping 4: 44.18 ms (43.84ms min, 0.55ms jitter)
[info] Ping 5: 44.09 ms (43.84ms min, 0.44ms jitter)
[info] Final Ping: 43.84 ms
Idle Latency:    44.22 ms   (jitter: 0.44ms, low: 43.84ms, high: 44.84ms)
info] Stage 2 completed                                     atency: 42.88 ms
[info] Smoothing graph for test with 0.988 progress, with duration of 175 ms in 10 updates
    Download:    44.33 Mbps (data used: 77.9 MB)
                 43.05 ms   (jitter: 0.49ms, low: 42.10ms, high: 44.63ms)
[info] Packet loss sent=240, received=240, dupes=0, maxId=239
      Upload: FAILED
~ took 22s
Oltre a questo, come già menzionato nell'altro thread, i trasferimenti file tramite applicazioni P2P hanno velocità sporadiche, che variano in base alla distanza dal peer connesso (generalmente sembra che più lunga sia la distanza, più lenti siano i trasferimenti, in alcuni casi parliamo di qualche KiB/s)
Non so più dove mettere le mani, non credo sia un comportamento normale ma non so neanche cos'altro fare per trovare/risolvere il problema.
    andreagdipaolo PC desktop connesso con cavo ethernet direttamente al router, NIC Realtek 2.5Gb e connessione negoziata correttamente a 2500/2500, ONT Nokia G-010G-T, quello nero di OF per la 2.5G.
      nothepin0 se hai il router zte la causa del upload failed o basso su server lontani o con ping maggiore di 20ms è lui
        LucaPerazzolo Si, il router è proprio lo ZTE H6645P V2 fornito da dimensione. Come dovrei procedere? è una cosa che posso risolvere con l'assistenza di dimensione o devo attrezzarmi io a comprare un altro router?
          nothepin0 qualche mese fa si parlava di una beta che sembrava risolvesse il problema, però non se ne è più saputo nulla.
          personalmente ci ho perso le speranze, tra questo e vari bug del router mai risolti
          nothepin0 è una cosa che posso risolvere con l'assistenza di dimensione o devo attrezzarmi io a comprare un altro router?
          potresti provare a chiedere questo aggiornamento all'assistenza o a giuseppe, oppure dovresti cercarti un router che supporti correttamente i pause frame (vedi altre discussioni a riguardo)
            nothepin0 probabilmente fai prima a cambiarlo con un flint2 ad esempio
            @giusgius scusa il disturbo, tu sai qualcosa di questo problema ed il relativo aggiornamento?
              nothepin0 @giusgius scusa il disturbo, tu sai qualcosa di questo problema ed il relativo aggiornamento?
              Ciao!
              Prova a scrivere al supporto mettendo un link a questa discussione, vediamo di fare dei test.
              Negoziando a 1Gbps il problema sparisce?
                giusgius No, negoziando 1000/1000 il problema persiste
                Ora ho inviato una mail all'assistenza, grazie
                giusgius Ma invece l'avete risolto il bug sulla 5 GHz? Ti avevo scritto qualche giorno fa, ma immagino che ti arrivano 100 mail al giorno
                  giuse56 non ci riesco a stare molto dietro, ma cerco di darti un riscontro 🤓
                    Aggiornamento: oggi mi ha chiamato l'assistenza di dimensione per caricare un firmware fornito da ZTE che doveva risolvere il problema, ma nulla. Sempre le stesse problematiche sugli stessi server sui quali avevo provato io e anche quelli dettati dal supporto. Ora dicono di dover sentire OF (presumo per scongiurare eventuali problemi di trasporto?) e poi mi sapranno dire. Assistenza da 5⭐ ma spero di riuscire ad uscirne presto perchè tra questo ed altri problemi, sta fibra mi sta sembrando un po' un calvario.
                      nothepin0 Ho provato per curiosità e anche sotto linea Fibercop e ONT Sercomm ottengo risultati molto simili. A me completa la Stage 3 dell'upload ma la velocità è ugualmente bassa e ci sono gli stessi errori di connessione.
                      Dubito che il problema sia OpenFiber, altrimenti non si verificherebbe anche a me...
                      Direi che c'è un problema sulla prima parte in carico alla rete Fastweb o semplicemente il firmware aggiornato non ha risolto nulla.
                      E:\Downloads\ookla-speedtest-1.2.0-win64>speedtest -v -v -s 56181
                      [2024-09-11 21:09:54.851] [info] Resolved address 1: 104.17.147.22
                      [2024-09-11 21:09:54.851] [info] Resolved address 2: 104.17.148.22
                      [2024-09-11 21:09:55.024] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=5489a767c9927c43f5b786bce51b445f80eea42bccfef684e1f031887823be33&hid=(n%253BgE%2515O%251C&serverid=56181&sid=e393e1763a99f0f74076a7d3ba1c8493ec33b9c627460c69e049ab2c8bd1bad4&uname=Windows%20%20Microsoft%20Windows%20%5BVersione%2010.0.22631.4037%5D%20AMD64) completed with response code 200
                      [2024-09-11 21:09:55.040] [info] configuration content:
                      {"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"75a3cba866eb6980-Cc861720ee17a64ad-3335a31c05352bab","license":{"message":"You may only use this Speedtest software and information generated\nfrom it for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location. Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policy at:\n\n http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"56181","host":"sh-speedtest.utopiafiber.com:8080","name":"Salt Lake City, UT","country":"United States","sponsor":"UTOPIA Fiber","sponsored":false,"host_functional":"1"}]}
                      [info] Configuration expiry date: 1726704000
                      Speedtest by Ookla
                      ISP: Dimensione
                      [info] Resolved address 1: 2604:9440:2300:1::5060
                      [info] Resolved address 2: 69.162.234.239
                      [info] Opening socket to '2604:9440:2300:1::5060'
                      [info] Ping 1: 144.66 ms (144.66ms min, 0.00ms jitter)
                      [info] Ping 2: 144.40 ms (144.40ms min, 0.27ms jitter)
                      [info] Ping 3: 144.81 ms (144.40ms min, 0.34ms jitter)
                      [info] Ping 4: 145.02 ms (144.40ms min, 0.30ms jitter)
                      [info] Ping 5: 144.78 ms (144.40ms min, 0.28ms jitter)
                      [info] Final Ping: 144.40 ms
                      Idle Latency: 144.76 ms (jitter: 0.28ms, low: 144.40ms, high: 145.02ms)
                      info] Stage 2 completed atency: 214.11 ms
                      [warning] Loaded latency: cannot read response.: [10053] Connessione interrotta dal software del computer host.
                      [info] Smoothing graph for test with 0.894 progress, with duration of 1000 ms in 60 updates
                      Download: 18.12 Mbps (data used: 29.6 MB)
                      215.46 ms (jitter: 70.99ms, low: 143.70ms, high: 289.22ms)
                      [info] Packet loss sent=214, received=214, dupes=0, maxId=213
                      [warning] Receive error: 10060 (Impossibile stabilire la connessione. Risposta non corretta della parte connessa dopo l'intervallo di tempo oppure mancata risposta dall'host collegato.
                      [info] Stage 3 completed
                      Upload: 76.30 Mbps (data used: 134.7 MB)
                      214.59 ms (jitter: 70.67ms, low: 142.68ms, high: 286.44ms)
                      [info] final result - serverid: 56181 ping: 144 download: 18124 upload: 76297
                      [info] latency 144ms jitter: 0.28ms packet loss 0.00%
                      [info] total download bytes: 29638957
                      [info] total download stage duration: 13408.949000 ms
                      [info] total upload bytes: 134691137
                      [info] total upload stage duration: 15010.000000 ms
                      Packet Loss: 0.0%
                      Result URL: https://www.speedtest.net/result/c/6847042f-ac9b-480d-90d4-026a0c422db3
                        nothepin0 Mi aggiorni anche a me su come va a finire e se risolvi? Così poi mi faccio fare l'aggiornamento dall'assistenza anche io.
                        Provando anche io su un server Salt Lake come te (Comcast) mi da risultati migliori dei tuoi, seppur i miei sono in WiFi https://www.speedtest.net/my-result/a/10369554073
                          giuse56 Prova su server UTOPIA fiber, sempre Salt Lake City, sembra essere quello che crea più problemi sulla connessione.
                          Le versioni web/mobile di speedtest non hanno nessun problema a terminare il test, ma suppongo che sia perché quei warning vengono ignorati e continua ad aprire nuove connessioni (?)
                          Con vodafone 5G raggiungo i 330 down 60 up, che sono comunque più di quelli che speedtest CLI riporta prima di fallire in upload (e decisamente molti di più di quelli che riporta in download)
                          Nell'attesa del supporto di dimensione, @giacomix11 riusciresti a linkarmi alcune di queste discussioni sui router? non ne trovo neanche una; oppure direttamente, se riesci, consigliami qualche router che non abbia questa problematica. Prenderei il flint2 come consigliato ma vorrei capire se ci sono alternative
                          @giusgius @giuse56 Speedtest con Flint2
                          [2024-09-15 14:18:06.974] [info] Resolved address 1: 104.17.148.22
                          [2024-09-15 14:18:06.975] [info] Resolved address 2: 104.17.147.22
                          [2024-09-15 14:18:07.183] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=b919e86ccc9e22a2fe988d4880bb0634f661dd8d5a93a956b08388b2620c5bb8&hid=a91%2520%2520%2502%250E%2505W%250CZ&serverid=56181&sid=60aeeacd923819f5302a91b85c86c646849f1cf1dff978dd064a6c87cf9c7590&uname=Windows%20%20Microsoft%20Windows%20%5BVersion%2010.0.22621.4037%5D%20AMD64) completed with response code 200
                          [2024-09-15 14:18:07.188] [info] configuration content:
                          {"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"5af9bbc766f0af80-Ce890d00a2d98daeb-e4139b5e9fe2c55d","license":{"message":"You may only use this Speedtest software and information generated\nfromit for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location.Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policyat:\n\n       http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"56181","host":"sh-speedtest.utopiafiber.com:8080","name":"Salt Lake City, UT","country":"United States","sponsor":"UTOPIA Fiber","sponsored":false,"host_functional":"1"}]}
                          [info] Configuration expiry date: 1727049600
                             Speedtest by Ookla
                                   ISP: Dimensione
                          [info] Ping 1: 144.65 ms (144.65ms min, 0.00ms jitter)
                          [info] Ping 2: 144.88 ms (144.65ms min, 0.23ms jitter)
                          [info] Ping 3: 145.27 ms (144.65ms min, 0.31ms jitter)
                          [info] Ping 4: 144.74 ms (144.65ms min, 0.38ms jitter)
                          [info] Ping 5: 144.84 ms (144.65ms min, 0.31ms jitter)
                          [info] Final Ping: 144.65 ms
                          Idle Latency:   144.82 ms   (jitter: 0.31ms, low: 144.65ms, high: 145.27ms)
                          info] Stage 2 completed                                     atency: 142.69 ms
                          [info] Smoothing graph for test with 0.707 progress, with duration of 1000 ms in 60 updates
                              Download:    16.55 Mbps (data used: 21.1 MB)
                                          142.72 ms   (jitter: 0.22ms, low: 142.23ms, high: 143.56ms)
                          [info] Packet loss sent=171, received=171, dupes=0, maxId=170
                                Upload: FAILED
                          ~ took 21s
                          Quindi il router non è il colpevole
                            nothepin0
                            Premesso che sulla mia FTTH Dimensione su rete OF con consegna Milano ed ONT ZTE F6005 l'anomalia non si riscontra (indipendentemente dal router, comunque al momento utilizzo proprio un Flint 2)
                                     ISP: Dimensione
                            Idle Latency:   144.48 ms   (jitter: 0.08ms, low: 144.38ms, high: 144.57ms)
                                Download:    16.89 Mbps (data used: 21.8 MB)
                                            218.60 ms   (jitter: 65.66ms, low: 144.67ms, high: 289.57ms)
                                  Upload:     8.97 Mbps (data used: 9.0 MB)
                                            212.32 ms   (jitter: 64.69ms, low: 141.81ms, high: 283.17ms)
                             Packet Loss:     0.0%
                            espongo una mia curiosità: in generale la possibilità che essa dipenda quanto meno dal modello ONT è già stata vagliata?
                              walt Avevo un sospetto, ma non se ne era mai parlato qui, e data la immediata risposta "è colpa dello ZTE" ho dato la colpa a lui. Il prossimo step nella catena sarebbe proprio l'ONT.
                              Non sono pratico con openwrt, ma se ci sono log più dettagliati da cui si può capire qualcosa sono disponibile a postare anche quelli
                                Che emozione !!, che nostalgia !!.. sembra di fare un salto nel passato all'epoca della connessione ADSL Alice
                                https://www.speedtest.net/result/c/81107096-4cdc-4153-bd93-2ae7f2df6f1d
                                Tornando seri mi fa sorridere come oggi tutti i player delle telecomuncazioni si riempiono la bocca con proclami di gigabit di velocità : 10 , 20 , 50 100
                                All'atto pratico poi ancora che assistiamo a collegamenti del genere nell'era dei satelliti e cavi sottomarini
                                nothepin0 Con openwrt è abbastanza semplice setuppare il tutto, con una seconda scheda di rete potresti fare una prova avviandolo live sul tuo PC e fare uno speedtest direttamente da li.
                                Potrebbe essere anche interessante usare un setup con minipc + ap con lo ZTE che hai già, sempre se sei abbastanza smanettone 😁.
                                  nothepin0 Non capisco come mai ti spunta così a te lo speedtest e non la versione normale come a walt
                                  walt sarebbe interessante a questo punto, se facessi io lo speedtest. Perché avendo ONT Nokia 2.5G probabilmente potrei avere risultati diversi dai vostri. Solo che sia il mac che l'adattatore ce l'ho nell'altra casa. Quindi al momento non posso fare nulla
                                    giuse56 Ho aggiunto due flag -v per fargli loggare tutto, se non li metto l'output è normale:
                                    ❯ speedtest -s 56181
                                       Speedtest by Ookla
                                             ISP: Dimensione
                                    Idle Latency:   144.86 ms   (jitter: 0.09ms, low: 144.61ms, high: 144.99ms)
                                        Download:    16.31 Mbps (data used: 20.7 MB)
                                                    144.09 ms   (jitter: 0.21ms, low: 143.41ms, high: 144.53ms)
                                          Upload: FAILED                                            cy: 144.21 ms
                                    Aperock qui ha lo stesso problema, ma su rete fibercop e ONT Sercomm, che potrebbe smentire i sospetti sull' ONT
                                    DragonMaz Con openwrt è abbastanza semplice setuppare il tutto
                                    Mi pare abbia chiesto lumi sui log in ambiente OpenWrt, non su eventuale differente setup 🙄
                                    giuse56
                                    Utilizza la modalità verbose:
                                    speedtest -v -v
                                      walt Se non hai openwrt però ti serve a poco, per questo ho consigliato, scusate.
                                      Il problema potrebbe essere un altro
                                      Speedtest CLI Debian (Raspberry Pi OS, Raspberry Pi 5)
                                      Server a londra:
                                      ~ $ speedtest -v -v -s 30690
                                      [2024-09-15 15:46:22.844] [info] Resolved address 1: 104.17.147.22
                                      [2024-09-15 15:46:22.844] [info] Resolved address 2: 104.17.148.22
                                      [2024-09-15 15:46:22.986] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=69a85da9bd39cc93a3ac14111bcad6130cfd6d28f99c3faac08cd8e8a995e378&hid=%2504%250FO%251E%2509%255EOG%2516C&serverid=30690&sid=ee40e4ea24332b0c6518d6818f9a76b407a7aeb373b8d458fd98ac21e37a511d&uname=Linux%206.6.31%2Brpt-rpi-2712%20%231%20SMP%20PREEMPT%20Debian%201%3A6.6.31-1%2Brpt1%20(2024-05-29)%20aarch64) completed with response code 200
                                      [2024-09-15 15:46:22.986] [info] configuration content:
                                      {"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"5af9bbc766f0af80-Cc4ca97ce9091beda-1bb55527eeb045d3","license":{"message":"You may only use this Speedtest software and information generated\nfrom it for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location. Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policy at:\n\n       http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"30690","host":"speedtest.thn.lon.network.as201838.net:8080","name":"London","country":"United Kingdom","sponsor":"Community Fibre Limited","sponsored":false,"host_functional":"1"}]}
                                         Speedtest by Ookla
                                      [info] server selected: 30690
                                      [info] Server id: 30690
                                      [info] Name: London
                                      [info] Sponsor: Community Fibre Limited
                                            Server: Community Fibre Limited - London (id: 30690)
                                               ISP: Dimensione
                                      [info] Running Speedtest against host:port speedtest.thn.lon.network.as201838.net:8080
                                      [info] Resolved address 1: 93.113.26.250
                                      [info] Resolved address 2: 2a02:6b67:ffff:fe01::2
                                      [info] Opening socket to '93.113.26.250'
                                      [info] Ping 1: 36.47 ms (36.47ms min, 0.00ms jitter)
                                      [info] Ping 2: 36.31 ms (36.31ms min, 0.16ms jitter)
                                      [info] Ping 3: 36.21 ms (36.21ms min, 0.13ms jitter)
                                      [info] Ping 4: 36.08 ms (36.08ms min, 0.13ms jitter)
                                      [info] Ping 5: 36.32 ms (36.08ms min, 0.15ms jitter)
                                      [info] Final Ping: 36.08 ms
                                      Idle Latency:    36.28 ms   (jitter: 0.15ms, low: 36.08ms, high: 36.47ms)
                                      [info] Stage 2 completed                                    atency: 37.09 ms
                                          Download:   726.24 Mbps (data used: 966.6 MB)
                                                       37.14 ms   (jitter: 2.15ms, low: 36.79ms, high: 317.94ms)
                                      [warning] Loaded latency: cannot read response.: [0] Cannot read from uninitialized socket.
                                      [info] Packet loss sent=300, received=300, dupes=0, maxId=299
                                      [info] Stage 3 completed                                    atency: 88.60 ms
                                      [info] Smoothing graph for test with 0.681 progress, with duration of 1000 ms in 60 updates
                                            Upload:   447.11 Mbps (data used: 554.3 MB)
                                                      193.86 ms   (jitter: 57.81ms, low: 37.63ms, high: 1072.03ms)
                                      [info] final result - serverid: 30690 ping: 36 download: 726242 upload: 447110
                                      [info] latency 36ms jitter: 0.15ms packet loss 0.00%
                                      [info] total download bytes: 966608864
                                      [info] total download stage duration: 15008.387000 ms
                                      [info] total upload bytes: 554278259
                                      [info] total upload stage duration: 10213.000000 ms
                                       Packet Loss:     0.0%
                                        Result URL: https://www.speedtest.net/result/c/70f1bc36-a145-4702-b619-c4b71634b68f
                                      Server UTOPIA Salt Lake City
                                      ~ $ speedtest -v -v -s 56181
                                      [2024-09-15 15:51:09.494] [info] Resolved address 1: 104.17.147.22
                                      [2024-09-15 15:51:09.494] [info] Resolved address 2: 104.17.148.22
                                      [2024-09-15 15:51:09.632] [info] HTTP request (effective url: https://cli.speedtest.net/api/cli/config?deviceId=69a85da9bd39cc93a3ac14111bcad6130cfd6d28f99c3faac08cd8e8a995e378&hid=%2504%250FO%251E%2509%255EOG%2516C&serverid=56181&sid=ee40e4ea24332b0c6518d6818f9a76b407a7aeb373b8d458fd98ac21e37a511d&uname=Linux%206.6.31%2Brpt-rpi-2712%20%231%20SMP%20PREEMPT%20Debian%201%3A6.6.31-1%2Brpt1%20(2024-05-29)%20aarch64) completed with response code 200
                                      [2024-09-15 15:51:09.632] [info] configuration content:
                                      {"suite":{"global":{"engine":{"isUploadFirst":false,"testDurationSeconds":15,"threadCount":4,"packetSizeBytes":32000000},"dynamic":{"stableStop":{"isEnabled":true},"download":{"isScalingEnabled":true,"maxConnections":32}},"loadedLatency":{"enableUdp":true,"enableTcp":true}},"testStage":{"latency":{"pingCount":5},"upload":{"isServerUploadEnabled":true,"isClientPrimaryMeasureMethod":false}}},"app":{"ispName":"Dimensione","traceLevel":2,"licenseKey":"5af9bbc766f0af80-Ce71a58309c2ba339-85985e00c8394156","license":{"message":"You may only use this Speedtest software and information generated\nfrom it for personal, non-commercial use, through a command line\ninterface on a personal computer. Your use of this software is subject\nto the End User License Agreement, Terms of Use and Privacy Policy at\nthese URLs:\n\n\thttps://www.speedtest.net/about/eula\n\thttps://www.speedtest.net/about/terms\n\thttps://www.speedtest.net/about/privacy","version":"aaa8331c62dcaeaf7cbefe8de3952b0240ccae4424412c2e498eeb1beb84b20b"},"gdpr":{"message":"Ookla collects certain data through Speedtest that may be considered\npersonally identifiable, such as your IP address, unique device\nidentifiers or location. Ookla believes it has a legitimate interest\nto share this data with internet providers, hardware manufacturers and\nindustry regulators to help them understand and create a better and\nfaster internet. For further information including how the data may be\nshared, where the data may be transferred and Ookla's contact details,\nplease see our Privacy Policy at:\n\n       http://www.speedtest.net/privacy","acceptTimeout":90},"saveTestResultUrl":"https://results.speedtest.net/reports","resultFormat":"json"},"servers":[{"id":"56181","host":"sh-speedtest.utopiafiber.com:8080","name":"Salt Lake City, UT","country":"United States","sponsor":"UTOPIA Fiber","sponsored":false,"host_functional":"1"}]}
                                         Speedtest by Ookla
                                               ISP: Dimensione
                                      [info] Resolved address 2: 2604:9440:2300:1::5060
                                      [info] Ping 1: 144.05 ms (144.05ms min, 0.00ms jitter)
                                      [info] Ping 2: 144.06 ms (144.05ms min, 0.01ms jitter)
                                      [info] Ping 3: 144.04 ms (144.04ms min, 0.01ms jitter)
                                      [info] Ping 4: 144.37 ms (144.04ms min, 0.12ms jitter)
                                      [info] Ping 5: 144.19 ms (144.04ms min, 0.14ms jitter)
                                      [info] Final Ping: 144.04 ms
                                      Idle Latency:   144.10 ms   (jitter: 0.14ms, low: 144.04ms, high: 144.37ms)
                                      [info] Stage 2 completed                                    atency: 229.70 ms
                                      [info] Smoothing graph for test with 0.721 progress, with duration of 1000 ms in 60 updates
                                          Download:    16.72 Mbps (data used: 21.5 MB)
                                                      215.13 ms   (jitter: 65.21ms, low: 143.22ms, high: 286.91ms)
                                      [info] Packet loss sent=216, received=216, dupes=0, maxId=215
                                      [info] Stage 3 completed                                    atency: 208.19 ms
                                      [info] Smoothing graph for test with 0.601 progress, with duration of 1000 ms in 60 updates
                                            Upload:     9.01 Mbps (data used: 10.0 MB)
                                                      213.80 ms   (jitter: 64.81ms, low: 141.78ms, high: 282.84ms)
                                      [info] final result - serverid: 56181 ping: 144 download: 16720 upload: 9011
                                      [info] latency 144ms jitter: 0.14ms packet loss 0.00%
                                      [info] total download bytes: 21534990
                                      [info] total download stage duration: 10812.507000 ms
                                      [info] total upload bytes: 10005120
                                      [info] total upload stage duration: 9001.000000 ms
                                       Packet Loss:     0.0%
                                        Result URL: https://www.speedtest.net/result/c/daad89c3-a365-4f6b-9c1e-f825c6abd494
                                      Sempre velocità basse su UTOPIA, ma qui i test finiscono senza problemi
                                      Facendo altri test con un mio amico in inghilterra sembra che la singola connessione sia "cappata" a ~5MB/s, che va a salire quando si aprono più connessioni (che però cadono spesso, riportando la velocità a quella della singola connessione finchè non si riaprono altre connessioni)
                                      Provato anche un trasferimento P2P con torrent privato, quello va dai 600kbps ai 3-4MB/s; ed un test iperf3, anch'esso apparentemente "cappato" alle velocità da single connection
                                      Tutto questo fatto con un Raspberry Pi 5, settato in BBR come mi era già stato consigliato nel precedente thread.
                                      Qualsiasi altra ipotesi è ben accetta, perchè non so più dove mettere le mani e dove/quale possa essere il problema.
                                      7 giorni dopo
                                      giacomix11 router che supporti correttamente i pause frame
                                      Giusto per aggiungere, il flow control/pause frame non sembra avere alcun impatto su questo problema:
                                      root@GL-MT6000:~# ethtool -a eth1
                                      Pause parameters for eth1:
                                      Autonegotiate:  off
                                      RX:             off
                                      TX:             off
                                      ❯ speedtest -s 36817
                                         Speedtest by Ookla
                                            Server: Surfshark Ltd - New York, NY (id: 36817)
                                               ISP: Dimensione
                                      Idle Latency:   101.12 ms   (jitter: 0.27ms, low: 100.90ms, high: 101.38ms)
                                          Download:  1220.81 Mbps (data used: 2.0 GB)
                                                      101.26 ms   (jitter: 4.50ms, low: 100.69ms, high: 266.82ms)
                                            Upload: FAILED                                            cy: 100.86 ms
                                      root@GL-MT6000:~# ethtool -A eth1 rx on tx on
                                      Autonegotiate:  off
                                      RX:             on
                                      TX:             on
                                      [ 4955.091271] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control rx/tx
                                         Speedtest by Ookla
                                               ISP: Dimensione
                                      Idle Latency:    96.30 ms   (jitter: 0.42ms, low: 95.94ms, high: 96.55ms)
                                          Download:  1388.81 Mbps (data used: 2.3 GB)
                                                      170.36 ms   (jitter: 35.56ms, low: 96.38ms, high: 1545.14ms)
                                            Upload: FAILED                                            cy: 102.79 ms
                                      un mese dopo
                                      Aggiornamento: ieri ho chiamato l'assistenza di dimensione per sentire se ci fossero novità, mi hanno confermato che il problema è dell'ONT (quindi presumo sia il ben noto problema con il flow control su questo modello) e che stanno aspettando un aggiornamento del firmware, ma non hanno tempistiche specifiche perchè giustamente non è una cosa in carico a loro direttamente.
                                      Domanda, sarebbe possibile richiedere ad OF un cambio di ONT con, per esempio, lo ZTE F6005v3 che risolve questo problema? Oppure devo armarmi di pazienza ed aspettare che nokia rilasci un aggiornamento (se mai lo rilasceranno, visto che il supporto mi dice che questo problema c'è da anni)? Mi sembra assurdo avere 500/1000mbit in upload e non poterli sfruttare per un bug software dell'ONT.
                                        nothepin0 sarebbe possibile richiedere ad OF un cambio di ONT con, per esempio, lo ZTE F6005v3 che risolve questo problema?
                                        Di base no.
                                        Dimensione potrebbe spingere per un cambio ma se gli approvigionamenti della ditta di zona sono carenti del v3 allora nada.
                                        nothepin0 Mi sembra assurdo avere 500/1000mbit in upload e non poterli sfruttare per un bug software dell'ONT.
                                        Non è un bug software, il nokia ha i buffer sottodimensionati.
                                        Nemmeno con flow control o QoS si sistema.
                                          TheMarsican Dimensione potrebbe spingere per un cambio ma se gli approvigionamenti della ditta di zona sono carenti del v3 allora nada.
                                          @giusgius allora credo sia meglio chiedere direttamente a te se è possibile
                                          TheMarsican Non è un bug software, il nokia ha i buffer sottodimensionati.
                                          Quindi anche con un aggiornamento software dell'ONT il problema potrebbe rimanere?
                                            nothepin0 Quindi anche con un aggiornamento software dell'ONT il problema potrebbe rimanere?
                                            Si.
                                            I Nokia sono così.
                                              Non mi torna molto questo discorso.
                                              I vecchi F6005 avevano i buffer sottodimensionati e tramite upgrade del firmware sono riusciti a risolvere/migliorare (sempre che il router lato utente supporti il flow control)
                                              Come mai con i Nokia non dovrebbe essere risolvibile?
                                                TheMarsican C'è qualche altro modo in cui, in caso dimensione non riesca a risolvere, posso risolvere il problema?
                                                  nothepin0
                                                  Dalle informazioni in mio possesso e quello che si legge nel forum con il Nokia no.
                                                  Vedi se Dimensione può spingere per un cambio ONT.
                                                    TheMarsican Provo a mandare una mail all'assistenza per sentire se è possibile, aspetto comunque che anche giuseppe risponda qui, magari riesce a seguirlo lui. Grazie mille dell'aiuto
                                                      TheMarsican
                                                      Qui dice l'opposto dando la colpa ai buffer in riferimento all'F6005: https://forum.fibra.click/d/40258-nuova-attivazione-e-prime-impressioni-a-caldo/200
                                                      Comunque di Nokia 2.5G ce ne sono due: quello nero (vecchio) e quello bianco (nuovo), stessa sigla/modello.
                                                      Probabilmente l'hardware è sempre Realtek, ma magari potrebbe esserci qualche differenza per cui non escluderei al 100% che magari riescano a migliorare un pò la situazione dopo 2 anni..🙄
