zerolight simonebortolin SpeedTestTest v0.0.1 by simonebortolin SpeedTest Best Server from Ookla Speedtest by Ookla Server: I.S.I.Line s.r.l. - Saluzzo (id = 22547) ISP: Vodafone Italia DSL Latency: 5.49 ms (0.29 ms jitter) Download: 367.19 Mbps (data used: 165.6 MB ) Upload: 206.94 Mbps (data used: 93.1 MB ) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/4c7bf97c-1833-4379-839f-2afd5b614490 SpeedTest EOLO (MI) Speedtest by Ookla Server: EOLO - Milan (id = 11427) ISP: Vodafone Italia DSL Latency: 5.09 ms (0.46 ms jitter) Download: 386.65 Mbps (data used: 184.4 MB ) Upload: 207.04 Mbps (data used: 93.9 MB ) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/ef1930c9-f1f6-497c-91cc-48cc3ba81428 SpeedTest Fastweb (MI) Speedtest by Ookla Server: Fastweb SpA - Milan (id = 7839) ISP: Vodafone Italia DSL Latency: 5.72 ms (0.13 ms jitter) Download: 357.71 Mbps (data used: 184.1 MB ) Upload: 206.95 Mbps (data used: 93.0 MB ) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/12f42030-cb88-486b-9eec-8b8b71050e2c MTR 8.8.8.8 Traccia instradamento verso dns.google [8.8.8.8] su un massimo di 30 punti di passaggio: 1 <1 ms <1 ms <1 ms vodafone.station [10.0.0.1] 2 4 ms 3 ms 3 ms net-109-116-142-1.cust.vodafonedsl.it [109.116.142.1] 3 6 ms 6 ms 6 ms 83.224.40.138 4 5 ms 5 ms 5 ms 83.224.40.137 5 5 ms 5 ms 5 ms 83.224.46.233 6 6 ms 6 ms 6 ms 108.170.245.81 7 6 ms 6 ms 5 ms 216.239.42.9 8 6 ms 6 ms 6 ms dns.google [8.8.8.8] Traccia completata. MTR 1.1.1.1 Traccia instradamento verso one.one.one.one [1.1.1.1] su un massimo di 30 punti di passaggio: 1 <1 ms <1 ms <1 ms vodafone.station [10.0.0.1] 2 4 ms 3 ms 49 ms net-109-116-142-1.cust.vodafonedsl.it [109.116.142.1] 3 7 ms 5 ms 6 ms 83.224.40.138 4 6 ms 6 ms 6 ms 83.224.40.137 5 5 ms 5 ms 6 ms 185.210.48.67 6 7 ms 6 ms 6 ms 188.114.100.5 7 6 ms 5 ms 5 ms one.one.one.one [1.1.1.1] Traccia completata. MTR hetzner.de Traccia instradamento verso hetzner.de [88.198.255.177] su un massimo di 30 punti di passaggio: 1 <1 ms <1 ms <1 ms vodafone.station [10.0.0.1] 2 3 ms 6 ms 3 ms net-109-116-142-1.cust.vodafonedsl.it [109.116.142.1] 3 9 ms 8 ms 6 ms 83.224.40.138 4 6 ms 5 ms 5 ms 83.224.40.137 5 6 ms 6 ms 7 ms 185.210.48.25 6 14 ms 14 ms 14 ms ae-2-3203.ear3.Frankfurt1.Level3.net [4.69.163.90] 7 15 ms 14 ms 16 ms 195.122.181.130 8 18 ms 17 ms 17 ms ae1-2014.nbg40.core-backbone.com [81.95.15.206] 9 18 ms 18 ms 18 ms core-backbone.hetzner.com [80.255.9.22] 10 21 ms 17 ms 18 ms 213-239-245-77.clients.your-server.de [213.239.245.77] 11 18 ms 17 ms 19 ms ex9k2.dc1.nbg1.hetzner.com [213.239.203.218] 12 17 ms 17 ms 18 ms static.88.198.255.177.clients.your-server.de [88.198.255.177] Traccia completata. PC INFO Caption : AMD64 Family 23 Model 113 Stepping 0 DeviceID : CPU0 Manufacturer : AuthenticAMD MaxClockSpeed : 3801 Name : AMD Ryzen 9 3900X 12-Core Processor SocketDesignation : AM4 TotalPhysicalMemory ------------------- 17119936512 Manufacturer : Unknown Banklabel : P0 CHANNEL A Configuredclockspeed : 3600 Devicelocator : DIMM 1 Capacity : 8589934592 Manufacturer : Unknown Banklabel : P0 CHANNEL B Configuredclockspeed : 3600 Devicelocator : DIMM 1 Capacity : 8589934592 name : Hamachi Status : Not Present speed : 0 LinkSpeed : 0 bps fullduplex : InterfaceDescription : LogMeIn Hamachi Virtual Ethernet Adapter name : ProtonVPN TUN Status : Not Present speed : 0 LinkSpeed : 0 bps fullduplex : InterfaceDescription : ProtonVPN Tunnel name : Connessione alla rete locale (LAN) Status : Not Present speed : 0 LinkSpeed : 0 bps fullduplex : InterfaceDescription : TAP-ProtonVPN Windows Adapter V9 name : Ethernet Status : Not Present speed : 0 LinkSpeed : 0 bps fullduplex : InterfaceDescription : VirtualBox Host-Only Ethernet Adapter name : Wi-Fi Status : Disconnected speed : LinkSpeed : 0 bps fullduplex : True InterfaceDescription : Intel(R) Wi-Fi 6 AX200 160MHz name : VirtualBox Status : Not Present speed : 0 LinkSpeed : 0 bps fullduplex : InterfaceDescription : VirtualBox Host-Only Ethernet Adapter name : FTTH 1Gbps Status : Up speed : 1000000000 LinkSpeed : 1 Gbps fullduplex : True InterfaceDescription : Intel(R) I211 Gigabit Network Connection name : Connessione di rete Bluetooth Status : Not Present speed : 0 LinkSpeed : 0 bps fullduplex : InterfaceDescription : Bluetooth Device (Personal Area Network)
mark129 zerolight sono da Windows 11 Solo per eccesso di zelo, puoi fare un test (speedtest, mtr) bootando da una live linux?
zerolight mark129 se va bene da virtualbox si, se devo mettermi a installare linux partizionando l'ssd eviterei
gandalf2016 zerolight no, devi solo partire da Ubuntu o altra live Linux caricandolo in RAM. Non mette nulla su disco. Come ha detto mark129 sopra
zerolight gandalf2016 nulla non riesco ad andare su Linux, riavvio il pc e faccio il boot selector ma non mi esce la chiavetta con Linux
kalipotino zerolight hai seguito la formattazione giusta della chiavetta prima di flashare l'iso? Che procedura hai fatto per metterlo nella chiavetta?
zerolight kalipotino l'ho trascinato dentro, ho pensato dopo che forse l'avrei dovuta formattare, comunque non penso che da linux cambi qualcosa, appena riesco a reperire un adattatore usb-c a ethernet provo a fare qualche speedtest da macbook, visto che su wifi mi si ferma a ~ 800mbps
nanomad simonebortolin Run as Admin File -> Backup Current Settings Connection speed su 100+ Mbit/s Spunta su Modify All Adapters Choose Settings: Optimal Apply Changes Reboot
zerolight simonebortolin nanomad ha funzionato 😃 grazie mille a tutti, ora mi manca solo capire come cavolo farmi passare alla 2,5gbit da sto maledetto callcenter vodafone, almeno un problema ora è risolto.
simonebortolin Pilloso stai meno a provare che cercare il topic. al massimo lo acquisterai i giorni successivi. Inoltre prima di dare la colpa al modem controlla eventuali settaggi di QoS che qualcosa ci ha ed le impostazioni di tcp optimizer: nanomad Run as Admin File -> Backup Current Settings Connection speed su 100+ Mbit/s Spunta su Modify All Adapters Choose Settings: Optimal Apply Changes Reboot
nanomad zerolight Domanda, c'è un file di log mi pare nella cartella di TCP Optimizer, riesci a giramelo? Anche su telegram in privato (il nick è lo stesso). Ultimamente ci sono un po' troppi casi risolti con TCP Optimizer
simonebortolin zerolight cavolo farmi passare alla 2,5gbit da sto maledetto callcenter vodafone tanto non ti cambia nulla le porte della vodafone station sono 1Gbps
zerolight nanomad sai +/- come si dovrebbe chiamare il file di log? avevo il .exe nella cartella downloads
zerolight simonebortolin lo so è da un po' che mi informo per sta cosa, pensavo di tirarli fuori o con wifi6 o usare un ubiquiti X16 come media converter, o anche solo avere i 500mbps di upload non sarebbe male
