Ma chi era rimasto bloccato al firmware Elisa B06, è poi riuscito ad aggiornare in qualche modo? Il mio sembra non volerne proprio sapere..
Debrand e blocco bande su ZTE MF286D TIM
sam_martello Yes , you have to connect to terminal ,and temporarly set IMEI to router orginally from Elisa.
Or other advanced tricks with communication beetween MF286D and ZTE server and substituting this part in right place
Marcin Ti ringrazio, pensavo che con questo firmware non sarebbe stato necessario smontare il modem per ricevere gli aggiornamenti.
EDIT: ho modificato la regione in "Sverige" e il router è riuscito a installare la versione B11D
I want to upgrade my router to b12. I changed the imei when the Internet was turned off with the nv set imei=866754040397403 command, saved it, it was displayed on the main page, but no updates are coming. What should I do?
update nordic mf286d firmware from ver b03 onwards
serial requirements to connect to the modem
modem with sim inserted
connect the serial port to the modem wait for the modem to finish starting up
on the gui on page 192.168.32.1 disconnect lte connection
via serial, give these three commands
nv set imei=866754043693436
nv set imei_tmp=866754043693436
nv save
these commands give a temporary imei (it resumes its original when restarted)
on the gui at page 192.168.32.1 reconnect lte connection and search for the update
it will probably go from b02 to b05 then every time you want to update to the latest b011 start over.
I did everything according to this guide, but starting with the Nordic_MF286D_B02 firmware, he does not want to look for new updates.
Does the new imei appear in the gui?
if the new imei does not appear with f5 refresh the page then look for the update
Yes, the new imei is displayed but "No new version found".
Ramil009 try these imeis
nv set imei=866754040063617
nv set imei_tmp=866754040063617
nv save
nv set imei=866754042313614
nv set imei_tmp=866754042313614
nv save
nv set imei=866754040906443
nv set imei_tmp=866754040906443
nv save
nv set imei_tmp=866754040397403
nv save
with a random password
Ramil009 You need to set the NTP to 03:00 AM.
This is the italian guide to update to Nordic B12: https://forum.fibra.click/d/15002-debrand-e-blocco-bande-su-zte-mf286d-tim/2308
MentalBreach This is if an update has already been found and in order not to wait for the night, you can change the time. For me, he just doesn't want to find new versions.
trenti60 Ho eseguito fino a due giorni fa massimo 3 giorni fa questi passaggi:
Installato nordic b02 password da seriale trovata
Inserisco imei temporaneo elencato nella guida, il, risultato è che non si aggiorna più nessun firmware.
Ecco cosa esce scritto:
Ripeto firmware 100% ufficiale nordic b02 con password - - -.rar non va più. La guida è diventata obsoleta con il seguente imei che finisce con 403
Hanno, ragione tutti quelli che lo scrivono, ho, testato altri imei in giro senza successo!
MentalBreach non funziona comunque sembra essere saltato imei da giorni a questa parte. Imei temporaneo is not working. Nordic b02 pass - - -.rar installato.
stich86 Ho eseguito fino a due giorni fa massimo 3 giorni fa questi passaggi:
Hanno ragione tutti quelli che lo scrivono, ho, testato altri imei in giro senza successo!
@stich86 inoltre voglio precisare che ho atteso più di 10 minuti con internet acceso e ho eseguito la procedura, ho cambiato anche imei originale per vedere se poteva influire. Il risultato dopo questa foto è nessuna versione trovata. Lo lasciato acceso tutta la notte per vedere se da solo faceva qualcosa con sim ho è fastweb provate. Senza successo ci sono altre dire ho provato diversi imei alcuni ho cambiato io le cifre finali, ma il risultato è sempre lo stesso nessuna versione trovata. Fino a 6 giorni fa andava tutto.
