Ok grazie per il tuo aiuto!!
Non credo sia il modem perchè da circa 1 mese faceva lo stesso sulla vecchia linea e altri 2 modem
Trovato questo per le statistiche, va bene?
xDSLFwVersion: FwVer:5.12.12.0_B_A60901 HwVer:T14.F7_0.0
Line State: Up
Modulation: ITU G.993.2(VDSL2), G.998.4(G.I
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 16512
shineGINPdownstream: 620
shineGINPupstream: 590
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end interleaved channel bit rate: 93509 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 0 kbps
far-end fast channel bit rate: 21599 kbps
near-end FEC error fast: 0
near-end FEC error interleaved: 26214
near-end CRC error fast: 0
near-end CRC error interleaved: 0
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 52
far-end FEC error interleaved: 0
far-end CRC error fast: 0
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
DSL uptime :8 min, 11 secs
DSL activetime :0 min, 16 secs
Downstream:
relative capacity occupation: 100%
noise margin downstream: 6.0 dB
output power upstream: -6.6 dbm
attenuation downstream: 11.6 dB
Upstream:
noise margin upstream: 10.9 dB
output power downstream: 13.0 dbm
attenuation upstream: 2.9 dB
Bit table:
carrier load: number of bits per tone
tone 0- 31: 00 00 00 06 89 aa bb ba aa aa aa aa ab bb bb bb
tone 32- 63: cb bb cc dd de ee ef ff ff ff ff ff ff ff ff ff
tone 64- 95: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
tone 96-127: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
tone 128-159: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
tone 160-191: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
tone 192-223: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
tone 224-255: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
