xfm
Se imposti la scheda di rete ad 1G la velocità in upload a quanto arriva?
Sei in area bianca o nera? OLT ZTE o Nokia?
xfm
Stesso ont. Router ZTE H6645P.
Server: Deutsche Telekom - Berlin (id: 30907)
ISP: Dimensione
Idle Latency: 38.81 ms (jitter: 0.35ms, low: 38.51ms, high: 39.15ms)
Download: 2145.34 Mbps (data used: 3.6 GB)
39.88 ms (jitter: 0.58ms, low: 39.25ms, high: 45.27ms)
Upload: FAILED cy: 38.74 ms
[error] Cannot read:
Server: BT Ireland - Dublin (id: 38190)
ISP: Dimensione
Idle Latency: 42.08 ms (jitter: 0.38ms, low: 41.75ms, high: 42.63ms)
Download: 2213.93 Mbps (data used: 2.8 GB)
42.07 ms (jitter: 4.51ms, low: 40.62ms, high: 345.95ms)
Upload: FAILED cy: 43.30 ms
Server: i3D.net - Stockholm (id: 44597)
ISP: Dimensione
Idle Latency: 46.87 ms (jitter: 0.13ms, low: 46.71ms, high: 46.93ms)
Download: 1857.91 Mbps (data used: 2.4 GB)
46.50 ms (jitter: 0.73ms, low: 45.94ms, high: 50.06ms)
Upload: FAILED cy: 43.28 ms
Finchè l'upload va arriva al max intorno ai 150 mbps, poi intorno al 70% si interrompe. Su server dimensione velocità piena.
MiloZ Se imposti la scheda di rete ad 1G la velocità in upload a quanto arriva?
Speedtest by Ookla
ISP: Dimensione
Idle Latency: 41.19 ms (jitter: 0.07ms, low: 41.04ms, high: 41.26ms)
Download: 944.80 Mbps (data used: 1.2 GB)
118.94 ms (jitter: 37.17ms, low: 38.20ms, high: 171.35ms)
Upload: 446.76 Mbps (data used: 435.2 MB)
48.51 ms (jitter: 2.16ms, low: 43.92ms, high: 106.48ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/9295e51f-bfc2-4b05-9f57-805b531b2d9d
Speedtest by Ookla
ISP: Dimensione
Idle Latency: 44.49 ms (jitter: 0.06ms, low: 44.47ms, high: 44.62ms)
Download: 934.81 Mbps (data used: 1.3 GB)
125.72 ms (jitter: 39.59ms, low: 43.68ms, high: 184.30ms)
Upload: 440.67 Mbps (data used: 801.9 MB)
42.56 ms (jitter: 3.39ms, low: 40.57ms, high: 342.67ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/ceded6a9-2bb2-418e-99fa-35112d1e7bd6
Speedtest by Ookla
ISP: Dimensione
Idle Latency: 46.61 ms (jitter: 0.07ms, low: 46.55ms, high: 46.76ms)
Download: 939.55 Mbps (data used: 1.2 GB)
142.68 ms (jitter: 46.22ms, low: 56.81ms, high: 205.21ms)
Upload: 417.57 Mbps (data used: 407.0 MB)
88.52 ms (jitter: 15.97ms, low: 57.01ms, high: 136.53ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/d262215e-525f-435d-843f-a2c870f34991
Con la scheda impostata a 1 Gb/s ottengo praticamente il massimo come puoi vedere
MiloZ Sei in area bianca o nera? OLT ZTE o Nokia?
Area Bianca, per quanto riguarda l'OLT come posso scoprirlo?
Probabilmente Nokia come OLT essendo area bianca.
Se provi uno speedtest anche su server leggermente piu lontani (sempre con scheda di rete impostata ad 1G) che risultati ottieni?
Tipo qui: -s3682
MiloZ Tipo qui: -s3682
Speedtest by Ookla
Server: Rostelecom - Moscow (id: 3682)
ISP: Dimensione
Idle Latency: 58.62 ms (jitter: 0.14ms, low: 58.47ms, high: 58.71ms)
Download: 946.69 Mbps (data used: 1.3 GB)
145.93 ms (jitter: 48.11ms, low: 63.09ms, high: 217.99ms)
Upload: 365.35 Mbps (data used: 498.8 MB)
95.80 ms (jitter: 22.05ms, low: 63.09ms, high: 138.22ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/9dfd8f5c-3820-49ea-9235-ce21365fde91
Il realtà su questo non noto parecchia differenza
Speedtest by Ookla
ISP: Dimensione
Idle Latency: 58.84 ms (jitter: 0.08ms, low: 58.71ms, high: 58.86ms)
Download: 1882.57 Mbps (data used: 3.2 GB)
89.23 ms (jitter: 16.77ms, low: 58.54ms, high: 398.17ms)
Upload: 324.84 Mbps (data used: 584.2 MB)
94.73 ms (jitter: 22.48ms, low: 62.55ms, high: 426.33ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/717e7eb8-7773-452a-809e-4215560edfdb
giuse56 Dovresti provare con un router con flow control funzionante prima di dare la colpa all'ONT. Quindi asus gt AX6000 (ad esempio)
Al momento non ho un a disposizione un router a 2.5G con flow control funzionante. In ogni caso l'hardware è lo stesso dello ZTE F6005 ma quello è stato aggiornato questo invece no.
Informativa privacy
Informativa cookie
Termini e condizioni
Regolamento
Disclaimer
