simonebortolin
/etc/config/network:
`config interface 'loopback'
option device 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd17:ef7d:2f6f::/48'
option packet_steering '1'
config device
option name 'br-lan'
option type 'bridge'
list ports 'lan1'
list ports 'lan2'
list ports 'lan3'
list ports 'lan4'
config interface 'lan'
option device 'br-lan'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option ip6assign '60'
config device
option name 'wan'
option macaddr '62:38:e0:10:a7:3f'
option mtu6 '1520'
config interface 'wan'
option device 'wan'
option proto 'dhcp'
option auto '0'
config interface 'wan6'
option device 'wan'
option proto 'dhcpv6'
option auto '0'
option reqaddress 'try'
option reqprefix 'auto'
config device
option type '8021q'
option ifname 'wan'
option vid '101'
option name 'wan.101'
config interface 'sky'
option device 'wan.101'
option reqprefix 'auto'`
Cosa intendi per area bianca o nera? xD
Responso dell'analyzer:
`« SpeedGuide.net TCP Analyzer Results »
Tested on: 2022.02.16 11:17
IP address: 101.58.xxx.xx
Client OS/browser: Windows 10 (Chrome 98.0.4758.82)
TCP options string: 020405a00103030801010402
MSS: 1440
MTU: 1480
TCP Window: 263424 (not multiple of MSS)
RWIN Scaling: 8 bits (28=256)
Unscaled RWIN : 1029
Recommended RWINs: 63360, 126720, 253440, 506880, 1013760
BDP limit (200ms): 1054 Mbps (105 Megabytes/s)
BDP limit (500ms): 421 Mbps (42 Megabytes/s)
MTU Discovery: OFF
TTL: 112
Timestamps: OFF
SACKs: ON
IP ToS: 00000000 (0)
La velocità è sugli 800 mbps (la stessa che ottenevo con lo skyhub in cascata).
Ho appena notato questo errore nel log: [ 8823.048170] mvneta f1070000.ethernet eth0: bad rx status 0cc50000 (max frame length error), size=1536 (ce ne sono una marea)
