Ho fatto prove tutta la notte con i ragazzi sulla IRC di Asterisk e Freepbx.
Risolto 0.
Riavvio, delle volte per scaramanzia riavviavo pure la macchina.
fracarza No la risposta dovrebbe essere 401 non 403. Cosa dice nel log pjsip?
Poi ti mando il log, ma alla fine è +/- sempre lo stesso solo che invece del errore trasporto si pianta sul 403 unauthorized. Ma almeno apre la connessione verso Sky.
EDIT, Eccolo:
freepbx*CLI> pjsip set logger on
PJSIP Logging enabled
[2021-05-15 11:00:14] DEBUG[24426]: res_pjsip_registrar.c:1291 check_expiration_thread: Woke up at 1621069214 Interval: 30
[2021-05-15 11:00:14] DEBUG[24426]: res_pjsip_registrar.c:1298 check_expiration_thread: Expiring 0 contacts
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip_outbound_registration.c:686 handle_client_registration: Outbound REGISTER attempt 3 to 'sip:voip.sky.it' with client 'sip:XXXXXXXXXXXXXXXX@voip.sky.it'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:479 sip_resolve: Performing SIP DNS resolution of target 'voip.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:506 sip_resolve: Transport type for target 'voip.it.isp.sky' is 'Unspecified'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:549 sip_resolve: [0x7f16582ed5c8] Created resolution tracking for target 'voip.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'voip.it.isp.sky' with record type '35', transport 'Unspecified', and port '0'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target '_sips._tcp.voip.it.isp.sky' with record type '33', transport 'TLS transport', and port '5061'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target '_sip._tcp.voip.it.isp.sky' with record type '33', transport 'TCP transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target '_sip._udp.voip.it.isp.sky' with record type '33', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'voip.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'voip.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:620 sip_resolve: [0x7f16582ed5c8] Starting initial resolution using parallel queries for target 'voip.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:277 sip_resolve_callback: [0x7f16582ed5c8] All parallel queries completed
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:373 sip_resolve_callback: [0x7f16582ed5c8] NAPTR record received on target 'voip.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target '_sip._udp.voip.glb.it.isp.sky' with record type '33', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:415 sip_resolve_callback: [0x7f16582ed5c8] New queries added, performing parallel resolution again
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:349 sip_resolve_callback: [0x7f16582ed5c8] SRV record received on target '_sip._udp.voip.glb.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'sbc.rmle1.voip.glb.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'sbc.rmle1.voip.glb.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'sbc.mid41.voip.glb.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'sbc.mid41.voip.glb.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'sbc.rmtp1.voip.glb.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'sbc.rmtp1.voip.glb.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'sbc.mica1.voip.glb.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582ed5c8] Added target 'sbc.mica1.voip.glb.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:332 sip_resolve_callback: [0x7f16582ed5c8] AAAA record received on target 'sbc.rmle1.voip.glb.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:332 sip_resolve_callback: [0x7f16582ed5c8] AAAA record received on target 'sbc.mid41.voip.glb.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:332 sip_resolve_callback: [0x7f16582ed5c8] AAAA record received on target 'sbc.rmtp1.voip.glb.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:332 sip_resolve_callback: [0x7f16582ed5c8] AAAA record received on target 'sbc.mica1.voip.glb.it.isp.sky'
[2021-05-15 11:00:14] DEBUG[24425]: res_pjsip/pjsip_resolver.c:421 sip_resolve_callback: [0x7f16582ed5c8] Resolution completed - 4 viable targets
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:201 sip_resolve_invoke_user_callback: [0x7f16582ed5c8] Address '0' is [2a0e:402:100::7]:5060 with transport 'UDP IPv6 transport'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:201 sip_resolve_invoke_user_callback: [0x7f16582ed5c8] Address '1' is [2a0e:402:100:300::7]:5060 with transport 'UDP IPv6 transport'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:201 sip_resolve_invoke_user_callback: [0x7f16582ed5c8] Address '2' is [2a0e:402:100:100::7]:5060 with transport 'UDP IPv6 transport'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:201 sip_resolve_invoke_user_callback: [0x7f16582ed5c8] Address '3' is [2a0e:402:100:200::7]:5060 with transport 'UDP IPv6 transport'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_resolver.c:207 sip_resolve_invoke_user_callback: [0x7f16582ed5c8] Invoking user callback with '4' addresses
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip/pjsip_message_filter.c:289 filter_on_tx_message: Re-wrote Contact URI host/port to 2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx:5060 (this may be re-written again later)
[May 15 11:00:14] <--- Transmitting SIP request (650 bytes) to UDP:[2a0e:402:100::7]:5060 --->
[May 15 11:00:14] REGISTER sip:voip.it.isp.sky SIP/2.0
[May 15 11:00:14] Via: SIP/2.0/UDP [2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx]:5060;rport;branch=z9hG4bKPjf4c4bf95-acd7-47e5-8944-5748704087ce
[May 15 11:00:14] From: <sip:XXXXXXXXXXXXXXXX@voip.sky.it>;tag=320f4a43-452d-48aa-90f3-3559cecc24d7
[May 15 11:00:14] To: <sip:XXXXXXXXXXXXXXXX@voip.sky.it>
[May 15 11:00:14] Call-ID: ca519d9b-caa1-40ec-bf15-c8cea03695da
[May 15 11:00:14] CSeq: 36620 REGISTER
[May 15 11:00:14] Contact: <sip:s@[2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx]:5060;line=lwcmbvq>
[May 15 11:00:14] Expires: 3600
[May 15 11:00:14] Allow: OPTIONS, REGISTER, SUBSCRIBE, NOTIFY, PUBLISH, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, MESSAGE, REFER
[May 15 11:00:14] Route: <sip:voip.sky.it>
[May 15 11:00:14] Max-Forwards: 70
[May 15 11:00:14] User-Agent: FPBX-14.0.16.4(18.3.0)
[May 15 11:00:14] Content-Length: 0
[May 15 11:00:14]
[May 15 11:00:14]
[May 15 11:00:14] <--- Received SIP response (471 bytes) from UDP:[2a0e:402:100::7]:5060 --->
[May 15 11:00:14] SIP/2.0 403 Forbidden
[May 15 11:00:14] Via: SIP/2.0/UDP [2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx]:5060;received=2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx;branch=z9hG4bKPjf4c4bf95-acd7-47e5-8944-5748704087ce;rport=5060
[May 15 11:00:14] To: <sip:XXXXXXXXXXXXXXXX@voip.sky.it>;tag=6099bdaa-609f8d9e2fedadc7
[May 15 11:00:14] Date: Sat, 15 May 2021 09:00:14 GMT
[May 15 11:00:14]
[May 15 11:00:14]
[2021-05-15 11:00:14] DEBUG[24414]: res_pjsip/pjsip_distributor.c:520 distributor: No dialog serializer for Response msg 403/REGISTER/cseq=36620 (rdata0x7f1670013858). Using request transaction as basis.
[2021-05-15 11:00:14] DEBUG[24414]: res_pjsip/pjsip_distributor.c:128 find_request_serializer: Found transaction tsx0x7f1658006a88 for Response msg 403/REGISTER/cseq=36620 (rdata0x7f1670013858).
[2021-05-15 11:00:14] DEBUG[24414]: res_pjsip/pjsip_distributor.c:138 find_request_serializer: Found serializer pjsip/outreg/SkyWifi-0000005d on transaction tsx0x7f1658006a88
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip_outbound_registration.c:1235 sip_outbound_registration_response_cb: Received REGISTER response 403(Forbidden)
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip_outbound_registration.c:1073 handle_registration_response: Processing REGISTER response 403 from server 'sip:voip.sky.it' for client 'sip:XXXXXXXXXXXXXXXX@voip.sky.it'
[2021-05-15 11:00:14] DEBUG[24415]: res_pjsip_outbound_registration.c:732 schedule_registration: Scheduling outbound registration to server 'sip:voip.sky.it' from client 'sip:XXXXXXXXXXXXXXXX@voip.sky.it' in 10 seconds
[2021-05-15 11:00:14] WARNING[24415]: res_pjsip_outbound_registration.c:1171 handle_registration_response: 403 Forbidden fatal response received from 'sip:voip.sky.it' on registration attempt to 'sip:XXXXXXXXXXXXXXXX@voip.sky.it', retrying in '10' seconds
[2021-05-15 11:00:14] DEBUG[24532]: manager.c:6200 match_filter: Examining AMI event:
Event: Registry
Privilege: system,all
ChannelType: PJSIP
Username: sip:XXXXXXXXXXXXXXXX@voip.sky.it
Domain: sip:voip.sky.it
Status: Rejected
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip_outbound_registration.c:686 handle_client_registration: Outbound REGISTER attempt 4 to 'sip:voip.sky.it' with client 'sip:XXXXXXXXXXXXXXXX@voip.sky.it'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:479 sip_resolve: Performing SIP DNS resolution of target 'voip.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:506 sip_resolve: Transport type for target 'voip.it.isp.sky' is 'Unspecified'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:549 sip_resolve: [0x7f16582edb68] Created resolution tracking for target 'voip.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'voip.it.isp.sky' with record type '35', transport 'Unspecified', and port '0'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target '_sips._tcp.voip.it.isp.sky' with record type '33', transport 'TLS transport', and port '5061'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target '_sip._tcp.voip.it.isp.sky' with record type '33', transport 'TCP transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target '_sip._udp.voip.it.isp.sky' with record type '33', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'voip.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'voip.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:620 sip_resolve: [0x7f16582edb68] Starting initial resolution using parallel queries for target 'voip.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:277 sip_resolve_callback: [0x7f16582edb68] All parallel queries completed
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:373 sip_resolve_callback: [0x7f16582edb68] NAPTR record received on target 'voip.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target '_sip._udp.voip.glb.it.isp.sky' with record type '33', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:415 sip_resolve_callback: [0x7f16582edb68] New queries added, performing parallel resolution again
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:349 sip_resolve_callback: [0x7f16582edb68] SRV record received on target '_sip._udp.voip.glb.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'sbc.rmle1.voip.glb.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'sbc.rmle1.voip.glb.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'sbc.mid41.voip.glb.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'sbc.mid41.voip.glb.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'sbc.rmtp1.voip.glb.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'sbc.rmtp1.voip.glb.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'sbc.mica1.voip.glb.it.isp.sky' with record type '28', transport 'UDP IPv6 transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:177 sip_resolve_add: [0x7f16582edb68] Added target 'sbc.mica1.voip.glb.it.isp.sky' with record type '1', transport 'UDP transport', and port '5060'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:332 sip_resolve_callback: [0x7f16582edb68] AAAA record received on target 'sbc.rmle1.voip.glb.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:332 sip_resolve_callback: [0x7f16582edb68] AAAA record received on target 'sbc.mid41.voip.glb.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:332 sip_resolve_callback: [0x7f16582edb68] AAAA record received on target 'sbc.rmtp1.voip.glb.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:332 sip_resolve_callback: [0x7f16582edb68] AAAA record received on target 'sbc.mica1.voip.glb.it.isp.sky'
[2021-05-15 11:00:24] DEBUG[24425]: res_pjsip/pjsip_resolver.c:421 sip_resolve_callback: [0x7f16582edb68] Resolution completed - 4 viable targets
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:201 sip_resolve_invoke_user_callback: [0x7f16582edb68] Address '0' is [2a0e:402:100::7]:5060 with transport 'UDP IPv6 transport'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:201 sip_resolve_invoke_user_callback: [0x7f16582edb68] Address '1' is [2a0e:402:100:300::7]:5060 with transport 'UDP IPv6 transport'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:201 sip_resolve_invoke_user_callback: [0x7f16582edb68] Address '2' is [2a0e:402:100:100::7]:5060 with transport 'UDP IPv6 transport'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:201 sip_resolve_invoke_user_callback: [0x7f16582edb68] Address '3' is [2a0e:402:100:200::7]:5060 with transport 'UDP IPv6 transport'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_resolver.c:207 sip_resolve_invoke_user_callback: [0x7f16582edb68] Invoking user callback with '4' addresses
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip/pjsip_message_filter.c:289 filter_on_tx_message: Re-wrote Contact URI host/port to 2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx:5060 (this may be re-written again later)
[May 15 11:00:24] <--- Transmitting SIP request (650 bytes) to UDP:[2a0e:402:100::7]:5060 --->
[May 15 11:00:24] REGISTER sip:voip.it.isp.sky SIP/2.0
[May 15 11:00:24] Via: SIP/2.0/UDP [2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx]:5060;rport;branch=z9hG4bKPj24f46213-2458-4b26-81d4-059363ecfdea
[May 15 11:00:24] From: <sip:XXXXXXXXXXXXXXXX@voip.sky.it>;tag=bb7bd24f-faed-4cd8-ad2b-1bc869ee1d73
[May 15 11:00:24] To: <sip:XXXXXXXXXXXXXXXX@voip.sky.it>
[May 15 11:00:24] Call-ID: ca519d9b-caa1-40ec-bf15-c8cea03695da
[May 15 11:00:24] CSeq: 36621 REGISTER
[May 15 11:00:24] Contact: <sip:s@[2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx]:5060;line=lwcmbvq>
[May 15 11:00:24] Expires: 3600
[May 15 11:00:24] Allow: OPTIONS, REGISTER, SUBSCRIBE, NOTIFY, PUBLISH, INVITE, ACK, BYE, CANCEL, UPDATE, PRACK, MESSAGE, REFER
[May 15 11:00:24] Route: <sip:voip.sky.it>
[May 15 11:00:24] Max-Forwards: 70
[May 15 11:00:24] User-Agent: FPBX-14.0.16.4(18.3.0)
[May 15 11:00:24] Content-Length: 0
[May 15 11:00:24]
[May 15 11:00:24]
[May 15 11:00:24] <--- Received SIP response (471 bytes) from UDP:[2a0e:402:100::7]:5060 --->
[May 15 11:00:24] SIP/2.0 403 Forbidden
[May 15 11:00:24] Via: SIP/2.0/UDP [2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx]:5060;received=2a0e:xxxx:xxxx:0:xxxx:xxff:fexx:xxxx;branch=z9hG4bKPj24f46213-2458-4b26-81d4-059363ecfdea;rport=5060
[May 15 11:00:24] To: <sip:XXXXXXXXXXXXXXXX@voip.sky.it>;tag=6099bdaa-609f8da8352df9ec
[May 15 11:00:24] Date: Sat, 15 May 2021 09:00:24 GMT
[May 15 11:00:24]
[May 15 11:00:24]
[2021-05-15 11:00:24] DEBUG[24414]: res_pjsip/pjsip_distributor.c:520 distributor: No dialog serializer for Response msg 403/REGISTER/cseq=36621 (rdata0x7f16700037c8). Using request transaction as basis.
[2021-05-15 11:00:24] DEBUG[24414]: res_pjsip/pjsip_distributor.c:128 find_request_serializer: Found transaction tsx0x7f1658006a88 for Response msg 403/REGISTER/cseq=36621 (rdata0x7f16700037c8).
[2021-05-15 11:00:24] DEBUG[24414]: res_pjsip/pjsip_distributor.c:138 find_request_serializer: Found serializer pjsip/outreg/SkyWifi-0000005d on transaction tsx0x7f1658006a88
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip_outbound_registration.c:1235 sip_outbound_registration_response_cb: Received REGISTER response 403(Forbidden)
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip_outbound_registration.c:1073 handle_registration_response: Processing REGISTER response 403 from server 'sip:voip.sky.it' for client 'sip:XXXXXXXXXXXXXXXX@voip.sky.it'
[2021-05-15 11:00:24] DEBUG[24415]: res_pjsip_outbound_registration.c:732 schedule_registration: Scheduling outbound registration to server 'sip:voip.sky.it' from client 'sip:XXXXXXXXXXXXXXXX@voip.sky.it' in 10 seconds
[2021-05-15 11:00:24] WARNING[24415]: res_pjsip_outbound_registration.c:1171 handle_registration_response: 403 Forbidden fatal response received from 'sip:voip.sky.it' on registration attempt to 'sip:XXXXXXXXXXXXXXXX@voip.sky.it', retrying in '10' seconds
[2021-05-15 11:00:24] DEBUG[24532]: manager.c:6200 match_filter: Examining AMI event:
Event: Registry
ChannelType: PJSIP
Status: Rejected
fracarza Questo route dovrebbe essere voip.it.isp.sky, server_uri rimane sip:voip.sky.it e outbound_proxy sip:voip.it.isp.sky?
Booh, io vi mando nuovamente la config che uso per il log di cui copra.
[SkyWifi]
type=aor
qualify_frequency=61
contact=sip:<redacted>@voip.sky.it
outbound_proxy=sip:voip.it.isp.sky
[SkyWifi]
type=auth
password=<redacted>
auth_type=userpass
username=<redacted>
[SkyWifi]
type=endpoint
context=from-pstn
disallow=all
allow=ulaw,alaw
aors=SkyWifi
language=it
outbound_proxy=sip:voip.it.isp.sky\;lr
outbound_auth=SkyWifi
from_domain=voip.sky.it
user_eq_phone=no
t38_udptl=no
t38_udptl_ec=none
fax_detect=no
trust_id_inbound=no
t38_udptl_nat=no
direct_media=no
rtp_symmetric=yes
dtmf_mode=auto
[SkyWifi]
type=identify
endpoint=SkyWifi
match=voip.sky.it
[SkyWifi]
type=registration
retry_interval=60
fatal_retry_interval=0
forbidden_retry_interval=10
max_retries=10
expiration=3600
line=yes
endpoint=SkyWifi
auth_rejection_permanent=yes
server_uri=sip:voip.sky.it
client_uri=sip:<redacted>@voip.sky.it
gandalf2016 All’outbound proxy sostituisci
gandalf2016 prova col loose routing.
Allora con il /;le
non cambia nulla.
L'unico modo che ho trovato per fargli mandare un frame sip è togliere il trasporto dalla config. Il che significa che la configurazione non passa per Freepbx e quindi diventa un casino da gestire.
Il fatto è che il dannato SIP avrebbe bisogno di 4 parametri:
- L'uri
- il server outbound, se il dominio e il server sono diversi
- il dominio
- i parametri user e password per l'autenticazione.
L'uri non te lo danno quindi vai te a sapere cosa diamine devo passargli. dal modem Sky non si vede niente.
Io poi che ho fatto la migrazione che numero avrei da passare il mio o quello temporaneo. Ci va il +39 o il 0039? Booh?
Loro si limitano a darti username e password oltre alle informazioni che già hanno pubblicato. (outbound e domain)
gandalf2016 Nel contact s non va bene, dovresti mettere il numero di telefono/username.
Il parametro da settare è contact user.
Gli ho provato a passare il numero di telefono e l'username. Non cambia una ceppa.
Quel numero non lo uso, il mio numero è con eutelia/clouditalia e non uso nemmeno quello.
Mi sa che per un po' mi arrendo. Ci ho buttato sopra più di 12 ore.
Non si sa come mai ma heiweb, Eutelia e compagnia bella funzionano sempre al primo colpo, mentre i voip degli ISP invece ogni santa volta fanno i capricci, vedi Wind che non gli piaceva l'user agent di Asterisk.
Bah...
