Marcin Good to know, but know people that wanna test it ask to us every time how to configure it, I never tried your tool, but a guy have tested your software and he got the modem version of Telia B02, and like we know, is not a good version and it should be updated up to B11.
B02 of Telia not support UL_CA so if people get this version must be update to B05+ to have the features.
I ask to all people, if you wanna try openwrt you had to know:
Known bugs on MF286D:
- WAN interface can be loose the IP randomically
- WireGuard not booting up if ntp server not give the correct time
- NTP client not sync the time with the servers through the wan (if you use a vpn, it should be updated manually through an cron job pointing the wwan0 interface)
- WIFI 5 performance is different of the stock Firmware, the cause is the offloading (You've to expecting a low performance, max 100/130Mbps)
- Another thing, the support for this modem is not a stable version, is a snapshot version, you can experiencing some bugs
I advice to all to testing it to a secondary modem, is requested a minimum of experience in openwrt, adb, and AT commands.
We take no responsibility for any problems you may cause to your modem.
