stich86 seguo la tua guida per aggiornare il firmware del modem da OpenWrt, sono su B03 quindi uso i file nell'archivio imageB03naB06.zip, il modem si riavvia poi lo riavvio io ma il comando ati mi mostra sempre la versione B03. 😫
  • stich86 ha risposto a questo messaggio
    Maybe you have Elisa , and took files from Telia/Nordic ? Or vice versa...
    rewri tirati giù il file update.log con adb:
    adb pull /cache/update.log
    e vediamo cosa c'è dentro.
    Stai copiando bene i file sotto /cache/? Il comando at+fotactr=5 ti restituire la size dell'update che hai copiato?
    • rewri ha risposto a questo messaggio
      stich86
      08:37:25 139 UP>>delta.bin not exist
      08:37:25 140 UP>>Enter power_fail_protection
      08:37:26 098 UP>>recv validate
      08:37:26 198 UP>>Enter validate_pack
      08:37:26 332 UP>>byts_to_rd = -32 end calc
      08:37:26 334 UP>>MD5_CALC = 89713a8da74fd9ca581d6ed04adb1fb5
      08:39:26 250 UP>>Begin zte_topsw_dua ...
      08:39:26 251 UP>>delta.bin not exist
      08:39:26 252 UP>>Enter power_fail_protection
      08:40:02 042 UP>>recv update
      08:40:02 051 UP>>Enter pre_update_stage
      08:40:03 188 UP>>Lighten network led
      08:40:03 214 UP>>Enter scout_stage
      08:40:03 215 UP>>Enter zte_file_verify
      08:40:03 217 UP>>zte_hash_calc the size of /cache/delta.bin is 8141419.
      08:40:03 597 UP>>Enter save_sha_sign
      08:40:03 761 UP>>verify image /cache/delta.bin success.
      08:40:05 386 UP>>mount=/mnt/recoveryfs,/mnt/recoveryfs/
      08:40:05 415 UP>>available space=50884608
      08:40:05 416 UP>>available space=15241216
      08:40:05 560 UP>>available space=50884608
      08:40:05 561 UP>>update recoveryfs failed with fffffeb2
      08:40:05 580 UP>>umount /mnt/recoveryfs successful
      08:40:05 585 UP>>scout recoveryfs failed.
      08:40:05 586 UP>>scout failed.
      08:40:05 587 UP>>Enter scout_fail
      08:40:05 589 UP>>remove /cache/init_6.flg failed with 2 (No such file or directory)
      08:40:05 771 UP>>scout failed, reboot now
      08:40:05 772 UP>>Enter dua_reboot
      00:00:01 901 UP>>Begin zte_topsw_dua ...
      00:00:01 960 UP>>delta.bin not exist
      00:00:01 962 UP>>Enter power_fail_protection
      00:00:02 099 UP>>Begin zte_topsw_dua ...
      00:00:02 114 UP>>delta.bin not exist
      00:00:02 116 UP>>Enter power_fail_protection
      00:00:02 050 UP>>Begin zte_topsw_dua ...
      00:00:02 088 UP>>delta.bin not exist
      00:00:02 090 UP>>Enter power_fail_protection
      Ecco il finale di update.log
      Sono certo che i 2 file sono stati caricati su /tmp di OpenWrt e poi pushati con adb su /cache del modem.
      Il comando at+fotactr=5 restituisce il numero dei bytes.
        rewri non riesce ad aggiornare recoveryfs..
        Posti un ATI fatto su ttyUSB1 o 2 ovviamente omettendo IMEI
          stich86 Eccolo:
          ATI
          Manufacturer: ZTE CORPORATION
          Model: MF286DMODULE
          Revision: BD_MF286DMODV1.0.0B03
          SVN: 01
          IMEI: 866754*********
          +GCAP: +CGSM
          OK
            rewri ma non è TELIA/NORDIC..
            Perciò ti fallisce
            Mi pare più in modulo passato sotto Maxis
              stich86 la sua storia è Tim -> Elisa -> Nordic -> OpenWrt
              è passato a B11 quando era con Elisa ed è rimasto cosi anche con nordic, poi con OpenWrt è tornato B03.
              Mi sfugge qualcosa che significa che non è TELIA/NORDIC?
                rewri il modem NORDIC si presenta così come versione firmware:
                BD_TELIAMF286DV1.0.0BXX
                nel tuo caso invece sembra non essere un NORDIC
                Ti consiglio di riflashare con un framework, in caso usare il fake IMEI per andare in B12
                  stich86 ma sono differenze software o hardware?
                  se poi lo aggiorno con framework e fake imei quando rimetto openwrt ritorna alla B03
                    rewri scusa ma come lo hai messo OpenWRT via seriale o tramite il framework modificato?
                    B03 è impossibile… stock è B02 (anche sul fantomatico B11)
                    • kabubi ha messo mi piace.
                      stich86 Allora OpenWrt l'ho messo con framework modificato, partendo da Nordic B11.
                      Mi sono ritrovato il modem con firmware B03
                        rewri che non mi pare esista nativo…
                        Bel film… hai la seriale?
                          stich86 non ho mai provato se la seriale va. Su questo modem non ci sto capendo nulla...
                            kabubi io non riesco. Proverò domani. Sotto rete mobile l hai fatto l'update?
                            • kabubi ha risposto a questo messaggio
                              Ok. Quando avrete capito come aggiornare via framework a B12 (compreso la parte modem) fatemi un fischio che via seriale propio non mi va di smontare la scatoletta e saldare cavetti e spoofare imei, col rischio pure di sputtanare tutto, Manco mi pagassero per fare sta cosa...
                                Massimo_Salvati nessuno ti obbliga ad aggiornare se non hai problemi..
                                Se ti funziona tutto resta così e basta 😉
                                rewri è l’unico modo, perché devi comunque spoofare la versione firmware per “ri-aggiornare”
                                  stich86 Per spoofare intendi che devo far credere a qualche entita online che ho un altro imei cosi mi invia l'aggiornamento firmware?
                                  Se fosse cosi attendo volentieri che la cosa si possa fare da OpenWrt (anche perche io voglio restare con Openwrt).
                                  Piuttosto quali sono, se posso chiedere, le fonti di informazione? Dove hai trovato quei file per aggiornare il Telia?
                                    rewri No, il problema è che ora tu hai un firmware sul modem che è "generico", il framework funziona SOLO con determinate versioni, quindi anche se tu sopra restori "Nordic_B11", per poterlo riaggiornare devi spoofarlo come TIM od ELISA ad esempio, solo così l'aggiornamento ti parte.
                                    Da OpenWRT purtroppo non puoi flashare il modem da zero.
                                    I file sono estrapolati usando il firmware originale ad ogni OTA
