documibozu
Fri Nov 21 14:00:52 2025 daemon.info gl-repeater[4697]: (repeater.lua:1776) interface wan status offline
Fri Nov 21 14:00:54 2025 daemon.info pppd[16106]: No response to 5 echo-requests
Fri Nov 21 14:00:54 2025 daemon.notice pppd[16106]: Serial link appears to be disconnected.
Fri Nov 21 14:00:54 2025 daemon.info pppd[16106]: Connect time 107.8 minutes.
Fri Nov 21 14:00:54 2025 daemon.info pppd[16106]: Sent 12938998 bytes, received 17104487 bytes.
Fri Nov 21 14:00:54 2025 daemon.info avahi-daemon[7825]: Interface pppoe-wan.IPv4 no longer relevant for mDNS.
Fri Nov 21 14:00:54 2025 daemon.info avahi-daemon[7825]: Leaving mDNS multicast group on interface pppoe-wan.IPv4 with address 188.217.72.251.
Fri Nov 21 14:00:54 2025 daemon.notice netifd: Network device 'pppoe-wan' link is down
Fri Nov 21 14:00:54 2025 daemon.info avahi-daemon[7825]: Withdrawing address record for 188.217.72.251 on pppoe-wan.
Fri Nov 21 14:00:54 2025 daemon.notice netifd: Interface 'wan' has lost the connection
Fri Nov 21 14:00:54 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Fri Nov 21 14:00:54 2025 kern.debug kernel: [1986157.162992] kmwan: Delete node:wan
Fri Nov 21 14:00:54 2025 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Nov 21 14:00:58 2025 user.notice ddns-scripts[17488]: glddns: PID '17488' terminated by 'SIGTERM' at 2025-11-21 14:00
Fri Nov 21 14:00:59 2025 user.notice ddns-scripts[23741]: ddns: PID '23741' started at 2025-11-21 14:00
Fri Nov 21 14:00:59 2025 user.notice ddns-scripts[23744]: glddns: PID '23744' started at 2025-11-21 14:00
Fri Nov 21 14:00:59 2025 user.warn ddns-scripts[23741]: ddns: Service section disabled! - TERMINATE
Fri Nov 21 14:00:59 2025 user.warn ddns-scripts[23741]: ddns: PID '23741' exit WITH ERROR '1' at 2025-11-21 14:00
Fri Nov 21 14:01:00 2025 daemon.notice pppd[16106]: Connection terminated.
Fri Nov 21 14:01:00 2025 daemon.info pppd[16106]: Sent PADT
Fri Nov 21 14:01:00 2025 daemon.notice pppd[16106]: Modem hangup
Fri Nov 21 14:01:00 2025 daemon.info pppd[16106]: Exit.
Fri Nov 21 14:01:00 2025 daemon.notice netifd: Interface 'wan' is now down
Fri Nov 21 14:01:00 2025 kern.info kernel: [1986163.140727] device eth1 left promiscuous mode
Fri Nov 21 14:01:00 2025 user.warn ddns-scripts[23744]: glddns: NO valid IP found
Fri Nov 21 14:01:00 2025 kern.info kernel: [1986163.182614] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Fri Nov 21 14:01:00 2025 daemon.notice netifd: Interface 'wan' is disabled
Fri Nov 21 14:01:01 2025 kern.info kernel: [1986163.541454] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY]
Fri Nov 21 14:01:01 2025 kern.info kernel: [1986163.551176] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/1000base-x link mode
Fri Nov 21 14:01:01 2025 kern.info kernel: [1986163.561275] device eth1 entered promiscuous mode
Fri Nov 21 14:01:01 2025 daemon.notice netifd: Interface 'wan' is enabled
Fri Nov 21 14:01:01 2025 daemon.notice netifd: Interface 'wan' is setting up now
Fri Nov 21 14:01:01 2025 daemon.notice netifd: VLAN 'eth1.1036' link is down
Fri Nov 21 14:01:01 2025 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Nov 21 14:01:01 2025 daemon.notice netifd: Network device 'eth1' link is down
Fri Nov 21 14:01:02 2025 daemon.notice netifd: Interface 'wan' is now down
Fri Nov 21 14:01:02 2025 kern.info kernel: [1986164.591764] device eth1 left promiscuous mode
Fri Nov 21 14:01:02 2025 daemon.notice netifd: Interface 'wan' is disabled
Fri Nov 21 14:01:02 2025 kern.info kernel: [1986164.977446] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY]
Fri Nov 21 14:01:02 2025 kern.info kernel: [1986164.987105] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/1000base-x link mode
Fri Nov 21 14:01:02 2025 daemon.notice netifd: Interface 'wan' is enabled
Fri Nov 21 14:01:02 2025 kern.info kernel: [1986164.997913] device eth1 entered promiscuous mode
Fri Nov 21 14:01:02 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Fri Nov 21 14:01:02 2025 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Nov 21 14:01:03 2025 user.notice ddns-scripts[23744]: glddns: PID '23744' terminated by 'SIGTERM' at 2025-11-21 14:01
Fri Nov 21 14:01:04 2025 user.notice ddns-scripts[26765]: ddns: PID '26765' started at 2025-11-21 14:01
Fri Nov 21 14:01:04 2025 user.notice ddns-scripts[26768]: glddns: PID '26768' started at 2025-11-21 14:01
Fri Nov 21 14:01:04 2025 user.warn ddns-scripts[26765]: ddns: Service section disabled! - TERMINATE
Fri Nov 21 14:01:04 2025 user.warn ddns-scripts[26765]: ddns: PID '26765' exit WITH ERROR '1' at 2025-11-21 14:01
Fri Nov 21 14:01:05 2025 daemon.notice netifd: Network device 'eth1' link is up
Fri Nov 21 14:01:05 2025 daemon.notice netifd: VLAN 'eth1.1036' link is up
Fri Nov 21 14:01:05 2025 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Nov 21 14:01:05 2025 daemon.notice netifd: Interface 'wan' is setting up now
Fri Nov 21 14:01:05 2025 kern.info kernel: [1986167.837923] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Fri Nov 21 14:01:05 2025 user.warn ddns-scripts[26768]: glddns: NO valid IP found
Fri Nov 21 14:01:20 2025 kern.notice kernel: [1986182.620218] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - a0:d8:07:03:9b:07
Fri Nov 21 14:01:20 2025 kern.notice kernel: [1986182.629720] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ReASSOC Send ReASSOC response (Status=0)...
Fri Nov 21 14:01:20 2025 kern.notice kernel: [1986182.639363] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Nov 21 14:01:20 2025 kern.notice kernel: [1986182.645595] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Nov 21 14:01:20 2025 kern.notice kernel: [1986182.757422] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Nov 21 14:01:20 2025 kern.notice kernel: [1986182.771544] 7986@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Fri Nov 21 14:01:20 2025 kern.notice kernel: [1986182.778317] 7986@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Fri Nov 21 14:01:20 2025 kern.notice kernel: [1986182.787116] 7986@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Fri Nov 21 14:01:20 2025 kern.warn kernel: [1986182.798750] 7986@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=29 from a0:d8:07:03:9b:07
Fri Nov 21 14:01:33 2025 kern.warn kernel: [1986196.335438] 7986@C08L2,ap_peer_disassoc_action() 3645: ASSOC - 1 receive DIS-ASSOC request
Fri Nov 21 14:01:33 2025 kern.warn kernel: [1986196.343968] 7986@C01L2,wifi_sys_disconn_act() 1002: wdev_idx=0
Fri Nov 21 14:01:33 2025 kern.notice kernel: [1986196.350299] 7986@C08L3,hw_ctrl_flow_v2_disconnt_act() 172: wdev_idx=0
Fri Nov 21 14:01:33 2025 kern.warn kernel: [1986196.357458] 7986@C13L2,MacTableDeleteEntry() 1938: Del Sta:a0:d8:07:03:9b:07
Fri Nov 21 14:01:35 2025 daemon.err insmod: module is already loaded - slhc
Fri Nov 21 14:01:35 2025 daemon.err insmod: module is already loaded - ppp_generic
Fri Nov 21 14:01:35 2025 daemon.err insmod: module is already loaded - pppox
Fri Nov 21 14:01:35 2025 daemon.err insmod: module is already loaded - pppoe
Fri Nov 21 14:01:35 2025 daemon.info pppd[27535]: Plugin rp-pppoe.so loaded.
Fri Nov 21 14:01:35 2025 daemon.info pppd[27535]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Fri Nov 21 14:01:35 2025 daemon.notice pppd[27535]: pppd 2.4.8 started by root, uid 0
Fri Nov 21 14:01:36 2025 kern.debug kernel: [1986198.757784] entrytb_aid_aquire(): found non-occupied aid:31, allocated from:4
Fri Nov 21 14:01:36 2025 kern.warn kernel: [1986198.765110] 7986@C13L2,MacTableInsertEntry() 1577: New Sta:a0:d8:07:03:9b:07
Fri Nov 21 14:01:36 2025 kern.notice kernel: [1986198.775915] 7986@C08L3,ap_cmm_peer_assoc_req_action() 1714: Recv Assoc from STA - a0:d8:07:03:9b:07
Fri Nov 21 14:01:36 2025 kern.notice kernel: [1986198.785367] 7986@C08L3,ap_cmm_peer_assoc_req_action() 2241: ASSOC Send ASSOC response (Status=0)...
Fri Nov 21 14:01:36 2025 kern.notice kernel: [1986198.794608] 7986@C01L3,wifi_sys_conn_act() 1115: wdev idx = 0
Fri Nov 21 14:01:36 2025 kern.notice kernel: [1986198.800772] 7986@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=0
Fri Nov 21 14:01:36 2025 kern.notice kernel: [1986198.929305] 7986@C15L3,WPABuildPairMsg1() 5310: <=== send Msg1 of 4-way
Fri Nov 21 14:01:36 2025 kern.notice kernel: [1986198.936571] 7986@C15L3,PeerPairMsg2Action() 6303: ===>Receive msg 2
Fri Nov 21 14:01:36 2025 kern.notice kernel: [1986198.943331] 7986@C15L3,WPABuildPairMsg3() 5595: <=== send Msg3 of 4-way
Fri Nov 21 14:01:36 2025 kern.notice kernel: [1986198.951055] 7986@C15L3,PeerPairMsg4Action() 6734: ===>Receive msg 4
Fri Nov 21 14:01:36 2025 kern.warn kernel: [1986198.962785] 7986@C15L2,PeerPairMsg4Action() 7098: AP SETKEYS DONE(ra0) - AKMMap=WPA2PSK, PairwiseCipher=AES, GroupCipher=AES, wcid=28 from a0:d8:07:03:9b:07
Fri Nov 21 14:01:36 2025 daemon.info dnsmasq-dhcp[3188]: DHCPDISCOVER(br-lan) a0:d8:07:03:9b:07
Fri Nov 21 14:01:36 2025 daemon.info dnsmasq-dhcp[3188]: DHCPOFFER(br-lan) 192.168.1.134 a0:d8:07:03:9b:07
Fri Nov 21 14:01:36 2025 daemon.info dnsmasq-dhcp[3188]: DHCPREQUEST(br-lan) 192.168.1.134 a0:d8:07:03:9b:07
Fri Nov 21 14:01:36 2025 daemon.info dnsmasq-dhcp[3188]: DHCPACK(br-lan) 192.168.1.134 a0:d8:07:03:9b:07 HUAWEI_P30_Pro-2d09f9d287
Fri Nov 21 14:01:40 2025 user.notice root: mtk-sdk eth halted detected, now reset it...
Fri Nov 21 14:01:40 2025 kern.info kernel: [1986202.970966] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Fri Nov 21 14:01:40 2025 daemon.notice netifd: Network device 'eth1' link is down
Fri Nov 21 14:01:40 2025 daemon.notice netifd: VLAN 'eth1.1036' link is down
Fri Nov 21 14:01:40 2025 daemon.err pppd[27535]: error receiving pppoe packet: Network is down
Fri Nov 21 14:01:40 2025 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Nov 21 14:01:40 2025 daemon.err pppd[27535]: select (waitForPADO): Interrupted system call
Fri Nov 21 14:01:40 2025 daemon.warn pppd[27535]: Timeout waiting for PADO packets
Fri Nov 21 14:01:40 2025 daemon.err pppd[27535]: Unable to complete PPPoE Discovery
Fri Nov 21 14:01:40 2025 daemon.info pppd[27535]: Exit.
Fri Nov 21 14:01:40 2025 daemon.notice netifd: Interface 'wan' is now down
Fri Nov 21 14:01:40 2025 daemon.notice netifd: Interface 'wan' is disabled
Fri Nov 21 14:01:40 2025 kern.info kernel: [1986203.421214] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY]
Fri Nov 21 14:01:40 2025 kern.info kernel: [1986203.430935] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/1000base-x link mode
Fri Nov 21 14:01:40 2025 kern.info kernel: [1986203.439256] device eth1 left promiscuous mode
Fri Nov 21 14:01:40 2025 kern.info kernel: [1986203.445515] device eth1 entered promiscuous mode
Fri Nov 21 14:01:40 2025 daemon.notice netifd: Interface 'wan' is enabled
Fri Nov 21 14:01:40 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Fri Nov 21 14:01:40 2025 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Nov 21 14:01:44 2025 daemon.notice netifd: Network device 'eth1' link is up
Fri Nov 21 14:01:44 2025 daemon.notice netifd: VLAN 'eth1.1036' link is up
Fri Nov 21 14:01:44 2025 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Nov 21 14:01:44 2025 daemon.notice netifd: Interface 'wan' is setting up now
Fri Nov 21 14:01:44 2025 kern.info kernel: [1986206.712731] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Fri Nov 21 14:01:44 2025 user.notice ddns-scripts[26768]: glddns: PID '26768' terminated by 'SIGTERM' at 2025-11-21 14:01
Fri Nov 21 14:01:45 2025 user.notice ddns-scripts[29190]: ddns: PID '29190' started at 2025-11-21 14:01
Fri Nov 21 14:01:45 2025 user.notice ddns-scripts[29193]: glddns: PID '29193' started at 2025-11-21 14:01
Fri Nov 21 14:01:45 2025 user.warn ddns-scripts[29190]: ddns: Service section disabled! - TERMINATE
Fri Nov 21 14:01:45 2025 user.warn ddns-scripts[29190]: ddns: PID '29190' exit WITH ERROR '1' at 2025-11-21 14:01
Fri Nov 21 14:01:47 2025 user.warn ddns-scripts[29193]: glddns: NO valid IP found
Fri Nov 21 14:01:58 2025 kern.warn kernel: [1986221.115364] IN=br-lan OUT= MAC=94:83:c4:a8:a1:80:c0:91:b9:76:6c:c4:08:00 SRC=192.168.1.145 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=30226 DF PROTO=ICMP TYPE=8 CODE=0 ID=56026 SEQ=52890 MARK=0x8000
Fri Nov 21 14:02:14 2025 daemon.err insmod: module is already loaded - slhc
Fri Nov 21 14:02:14 2025 daemon.err insmod: module is already loaded - ppp_generic
Fri Nov 21 14:02:14 2025 daemon.err insmod: module is already loaded - pppox
Fri Nov 21 14:02:14 2025 daemon.err insmod: module is already loaded - pppoe
Fri Nov 21 14:02:14 2025 daemon.info pppd[29997]: Plugin rp-pppoe.so loaded.
Fri Nov 21 14:02:14 2025 daemon.info pppd[29997]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Fri Nov 21 14:02:14 2025 daemon.notice pppd[29997]: pppd 2.4.8 started by root, uid 0
Fri Nov 21 14:02:19 2025 user.notice root: mtk-sdk eth halted detected, now reset it...
Fri Nov 21 14:02:19 2025 kern.info kernel: [1986241.848218] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Fri Nov 21 14:02:19 2025 daemon.notice netifd: Network device 'eth1' link is down
Fri Nov 21 14:02:19 2025 daemon.notice netifd: VLAN 'eth1.1036' link is down
Fri Nov 21 14:02:19 2025 daemon.err pppd[29997]: error receiving pppoe packet: Network is down
Fri Nov 21 14:02:19 2025 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Nov 21 14:02:19 2025 daemon.err pppd[29997]: select (waitForPADO): Interrupted system call
Fri Nov 21 14:02:19 2025 daemon.warn pppd[29997]: Timeout waiting for PADO packets
Fri Nov 21 14:02:19 2025 daemon.err pppd[29997]: Unable to complete PPPoE Discovery
Fri Nov 21 14:02:19 2025 daemon.info pppd[29997]: Exit.
Fri Nov 21 14:02:19 2025 daemon.notice netifd: Interface 'wan' is now down
Fri Nov 21 14:02:19 2025 daemon.notice netifd: Interface 'wan' is disabled
Fri Nov 21 14:02:19 2025 kern.info kernel: [1986242.300982] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY]
Fri Nov 21 14:02:19 2025 kern.info kernel: [1986242.310621] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/1000base-x link mode
Fri Nov 21 14:02:19 2025 kern.info kernel: [1986242.318941] device eth1 left promiscuous mode
Fri Nov 21 14:02:19 2025 daemon.notice netifd: Interface 'wan' is enabled
Fri Nov 21 14:02:19 2025 kern.info kernel: [1986242.324938] device eth1 entered promiscuous mode
Fri Nov 21 14:02:19 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Fri Nov 21 14:02:19 2025 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Nov 21 14:02:23 2025 daemon.notice netifd: Network device 'eth1' link is up
Fri Nov 21 14:02:23 2025 daemon.notice netifd: VLAN 'eth1.1036' link is up
Fri Nov 21 14:02:23 2025 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Nov 21 14:02:23 2025 daemon.notice netifd: Interface 'wan' is setting up now
Fri Nov 21 14:02:23 2025 kern.info kernel: [1986245.727999] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Fri Nov 21 14:02:23 2025 user.notice ddns-scripts[29193]: glddns: PID '29193' terminated by 'SIGTERM' at 2025-11-21 14:02
Fri Nov 21 14:02:24 2025 user.notice ddns-scripts[31604]: ddns: PID '31604' started at 2025-11-21 14:02
Fri Nov 21 14:02:24 2025 user.notice ddns-scripts[31607]: glddns: PID '31607' started at 2025-11-21 14:02
Fri Nov 21 14:02:24 2025 kern.warn kernel: [1986247.331600] IN=br-lan OUT= MAC=94:83:c4:a8:a1:80:d8:be:65:51:35:19:08:00 SRC=192.168.1.121 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=17618 DF PROTO=ICMP TYPE=8 CODE=0 ID=56026 SEQ=61774 MARK=0x8000
Fri Nov 21 14:02:24 2025 user.warn ddns-scripts[31604]: ddns: Service section disabled! - TERMINATE
Fri Nov 21 14:02:24 2025 user.warn ddns-scripts[31604]: ddns: PID '31604' exit WITH ERROR '1' at 2025-11-21 14:02
Fri Nov 21 14:02:25 2025 user.warn ddns-scripts[31607]: glddns: NO valid IP found
Fri Nov 21 14:02:33 2025 kern.warn kernel: [1986256.191635] IN=br-lan OUT= MAC=94:83:c4:a8:a1:80:d8:fb:d6:02:41:0f:08:00 SRC=192.168.1.122 DST=192.168.1.1 LEN=28 TOS=0x00 PREC=0x00 TTL=64 ID=11303 DF PROTO=ICMP TYPE=8 CODE=0 ID=29366 SEQ=0 MARK=0x8000
Fri Nov 21 14:02:53 2025 daemon.err insmod: module is already loaded - slhc
Fri Nov 21 14:02:53 2025 daemon.err insmod: module is already loaded - ppp_generic
Fri Nov 21 14:02:53 2025 daemon.err insmod: module is already loaded - pppox
Fri Nov 21 14:02:53 2025 daemon.err insmod: module is already loaded - pppoe
Fri Nov 21 14:02:53 2025 daemon.info pppd[32287]: Plugin rp-pppoe.so loaded.
Fri Nov 21 14:02:53 2025 daemon.info pppd[32287]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Fri Nov 21 14:02:53 2025 daemon.notice pppd[32287]: pppd 2.4.8 started by root, uid 0
Fri Nov 21 14:02:58 2025 user.notice root: mtk-sdk eth halted detected, now reset it...
Fri Nov 21 14:02:58 2025 kern.info kernel: [1986280.860422] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Fri Nov 21 14:02:58 2025 daemon.notice netifd: Network device 'eth1' link is down
Fri Nov 21 14:02:58 2025 daemon.notice netifd: VLAN 'eth1.1036' link is down
Fri Nov 21 14:02:58 2025 daemon.err pppd[32287]: error receiving pppoe packet: Network is down
Fri Nov 21 14:02:58 2025 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Nov 21 14:02:58 2025 daemon.err pppd[32287]: select (waitForPADO): Interrupted system call
Fri Nov 21 14:02:58 2025 daemon.warn pppd[32287]: Timeout waiting for PADO packets
Fri Nov 21 14:02:58 2025 daemon.err pppd[32287]: Unable to complete PPPoE Discovery
Fri Nov 21 14:02:58 2025 daemon.info pppd[32287]: Exit.
Fri Nov 21 14:02:58 2025 daemon.notice netifd: Interface 'wan' is now down
Fri Nov 21 14:02:58 2025 daemon.notice netifd: Interface 'wan' is disabled
Fri Nov 21 14:02:58 2025 kern.info kernel: [1986281.292747] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY]
Fri Nov 21 14:02:58 2025 kern.info kernel: [1986281.302441] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/1000base-x link mode
Fri Nov 21 14:02:58 2025 kern.info kernel: [1986281.310758] device eth1 left promiscuous mode
Fri Nov 21 14:02:58 2025 daemon.notice netifd: Interface 'wan' is enabled
Fri Nov 21 14:02:58 2025 kern.info kernel: [1986281.317798] device eth1 entered promiscuous mode
Fri Nov 21 14:02:58 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Fri Nov 21 14:02:58 2025 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Nov 21 14:03:02 2025 daemon.notice netifd: Network device 'eth1' link is up
Fri Nov 21 14:03:02 2025 daemon.notice netifd: VLAN 'eth1.1036' link is up
Fri Nov 21 14:03:02 2025 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Nov 21 14:03:02 2025 daemon.notice netifd: Interface 'wan' is setting up now
Fri Nov 21 14:03:02 2025 kern.info kernel: [1986284.612597] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Fri Nov 21 14:03:02 2025 user.notice ddns-scripts[31607]: glddns: PID '31607' terminated by 'SIGTERM' at 2025-11-21 14:03
Fri Nov 21 14:03:03 2025 user.notice ddns-scripts[1578]: ddns: PID '1578' started at 2025-11-21 14:03
Fri Nov 21 14:03:03 2025 user.notice ddns-scripts[1581]: glddns: PID '1581' started at 2025-11-21 14:03
Fri Nov 21 14:03:03 2025 user.warn ddns-scripts[1578]: ddns: Service section disabled! - TERMINATE
Fri Nov 21 14:03:03 2025 user.warn ddns-scripts[1578]: ddns: PID '1578' exit WITH ERROR '1' at 2025-11-21 14:03
Fri Nov 21 14:03:04 2025 user.warn ddns-scripts[1581]: glddns: NO valid IP found
Fri Nov 21 14:03:29 2025 kern.warn kernel: [1986312.046531] IN=br-lan OUT= MAC=94:83:c4:a8:a1:80:0c:43:f9:27:0a:01:08:00 SRC=192.168.1.101 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=39186 DF PROTO=ICMP TYPE=8 CODE=0 ID=56026 SEQ=9152 MARK=0x8000
Fri Nov 21 14:03:32 2025 daemon.err insmod: module is already loaded - slhc
Fri Nov 21 14:03:32 2025 daemon.err insmod: module is already loaded - ppp_generic
Fri Nov 21 14:03:32 2025 daemon.err insmod: module is already loaded - pppox
Fri Nov 21 14:03:32 2025 daemon.err insmod: module is already loaded - pppoe
Fri Nov 21 14:03:32 2025 daemon.info pppd[2275]: Plugin rp-pppoe.so loaded.
Fri Nov 21 14:03:32 2025 daemon.info pppd[2275]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Fri Nov 21 14:03:32 2025 daemon.notice pppd[2275]: pppd 2.4.8 started by root, uid 0
Fri Nov 21 14:03:37 2025 user.notice root: mtk-sdk eth halted detected, now reset it...
Fri Nov 21 14:03:37 2025 kern.info kernel: [1986319.744661] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Fri Nov 21 14:03:37 2025 daemon.notice netifd: Network device 'eth1' link is down
Fri Nov 21 14:03:37 2025 daemon.err pppd[2275]: error receiving pppoe packet: Network is down
Fri Nov 21 14:03:37 2025 daemon.notice netifd: VLAN 'eth1.1036' link is down
Fri Nov 21 14:03:37 2025 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Nov 21 14:03:37 2025 daemon.err pppd[2275]: select (waitForPADO): Interrupted system call
Fri Nov 21 14:03:37 2025 daemon.warn pppd[2275]: Timeout waiting for PADO packets
Fri Nov 21 14:03:37 2025 daemon.err pppd[2275]: Unable to complete PPPoE Discovery
Fri Nov 21 14:03:37 2025 daemon.info pppd[2275]: Exit.
Fri Nov 21 14:03:37 2025 daemon.notice netifd: Interface 'wan' is now down
Fri Nov 21 14:03:37 2025 daemon.notice netifd: Interface 'wan' is disabled
Fri Nov 21 14:03:37 2025 kern.info kernel: [1986320.180513] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY]
Fri Nov 21 14:03:37 2025 kern.info kernel: [1986320.190233] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/1000base-x link mode
Fri Nov 21 14:03:37 2025 kern.info kernel: [1986320.198554] device eth1 left promiscuous mode
Fri Nov 21 14:03:37 2025 daemon.notice netifd: Interface 'wan' is enabled
Fri Nov 21 14:03:37 2025 kern.info kernel: [1986320.204674] device eth1 entered promiscuous mode
Fri Nov 21 14:03:37 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Fri Nov 21 14:03:37 2025 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Nov 21 14:03:41 2025 daemon.notice netifd: Network device 'eth1' link is up
Fri Nov 21 14:03:41 2025 daemon.notice netifd: VLAN 'eth1.1036' link is up
Fri Nov 21 14:03:41 2025 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Nov 21 14:03:41 2025 daemon.notice netifd: Interface 'wan' is setting up now
Fri Nov 21 14:03:41 2025 kern.info kernel: [1986323.624533] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Fri Nov 21 14:03:41 2025 user.notice ddns-scripts[1581]: glddns: PID '1581' terminated by 'SIGTERM' at 2025-11-21 14:03
Fri Nov 21 14:03:42 2025 user.notice ddns-scripts[3883]: ddns: PID '3883' started at 2025-11-21 14:03
Fri Nov 21 14:03:42 2025 user.notice ddns-scripts[3886]: glddns: PID '3886' started at 2025-11-21 14:03
Fri Nov 21 14:03:42 2025 user.warn ddns-scripts[3883]: ddns: Service section disabled! - TERMINATE
Fri Nov 21 14:03:42 2025 user.warn ddns-scripts[3883]: ddns: PID '3883' exit WITH ERROR '1' at 2025-11-21 14:03
Fri Nov 21 14:03:43 2025 user.warn ddns-scripts[3886]: glddns: NO valid IP found
Fri Nov 21 14:03:53 2025 kern.warn kernel: [1986335.908980] IN=br-lan OUT= MAC=94:83:c4:a8:a1:80:b4:e4:54:06:a6:3c:08:00 SRC=192.168.1.129 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=14550 DF PROTO=ICMP TYPE=8 CODE=0 ID=56026 SEQ=34388 MARK=0x8000
Fri Nov 21 14:04:11 2025 daemon.err insmod: module is already loaded - slhc
Fri Nov 21 14:04:11 2025 daemon.err insmod: module is already loaded - ppp_generic
Fri Nov 21 14:04:11 2025 daemon.err insmod: module is already loaded - pppox
Fri Nov 21 14:04:11 2025 daemon.err insmod: module is already loaded - pppoe
Fri Nov 21 14:04:11 2025 daemon.info pppd[4716]: Plugin rp-pppoe.so loaded.
Fri Nov 21 14:04:11 2025 daemon.info pppd[4716]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Fri Nov 21 14:04:11 2025 daemon.notice pppd[4716]: pppd 2.4.8 started by root, uid 0
Fri Nov 21 14:04:16 2025 user.notice root: mtk-sdk eth halted detected, now reset it...
Fri Nov 21 14:04:16 2025 kern.info kernel: [1986358.756312] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Fri Nov 21 14:04:16 2025 daemon.notice netifd: Network device 'eth1' link is down
Fri Nov 21 14:04:16 2025 daemon.notice netifd: VLAN 'eth1.1036' link is down
Fri Nov 21 14:04:16 2025 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Nov 21 14:04:16 2025 daemon.err pppd[4716]: error receiving pppoe packet: Network is down
Fri Nov 21 14:04:16 2025 daemon.err pppd[4716]: select (waitForPADO): Interrupted system call
Fri Nov 21 14:04:16 2025 daemon.warn pppd[4716]: Timeout waiting for PADO packets
Fri Nov 21 14:04:16 2025 daemon.err pppd[4716]: Unable to complete PPPoE Discovery
Fri Nov 21 14:04:16 2025 daemon.info pppd[4716]: Exit.
Fri Nov 21 14:04:16 2025 daemon.notice netifd: Interface 'wan' is now down
Fri Nov 21 14:04:16 2025 daemon.notice netifd: Interface 'wan' is disabled
Fri Nov 21 14:04:16 2025 kern.info kernel: [1986359.200279] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY]
Fri Nov 21 14:04:16 2025 kern.info kernel: [1986359.209999] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/1000base-x link mode
Fri Nov 21 14:04:16 2025 kern.info kernel: [1986359.218558] device eth1 left promiscuous mode
Fri Nov 21 14:04:16 2025 daemon.notice netifd: Interface 'wan' is enabled
Fri Nov 21 14:04:16 2025 kern.info kernel: [1986359.224583] device eth1 entered promiscuous mode
Fri Nov 21 14:04:16 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Fri Nov 21 14:04:16 2025 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Nov 21 14:04:19 2025 daemon.notice netifd: Network device 'eth1' link is up
Fri Nov 21 14:04:19 2025 daemon.notice netifd: VLAN 'eth1.1036' link is up
Fri Nov 21 14:04:19 2025 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Nov 21 14:04:19 2025 daemon.notice netifd: Interface 'wan' is setting up now
Fri Nov 21 14:04:19 2025 kern.info kernel: [1986362.490285] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Fri Nov 21 14:04:20 2025 user.notice ddns-scripts[3886]: glddns: PID '3886' terminated by 'SIGTERM' at 2025-11-21 14:04
Fri Nov 21 14:04:21 2025 user.notice ddns-scripts[6324]: ddns: PID '6324' started at 2025-11-21 14:04
Fri Nov 21 14:04:21 2025 user.notice ddns-scripts[6327]: glddns: PID '6327' started at 2025-11-21 14:04
Fri Nov 21 14:04:21 2025 user.warn ddns-scripts[6324]: ddns: Service section disabled! - TERMINATE
Fri Nov 21 14:04:21 2025 user.warn ddns-scripts[6324]: ddns: PID '6324' exit WITH ERROR '1' at 2025-11-21 14:04
Fri Nov 21 14:04:22 2025 user.warn ddns-scripts[6327]: glddns: NO valid IP found
Fri Nov 21 14:04:26 2025 kern.warn kernel: [1986369.515418] IN=br-lan OUT= MAC=94:83:c4:a8:a1:80:98:22:6e:e8:48:11:08:00 SRC=192.168.1.126 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=37339 DF PROTO=ICMP TYPE=8 CODE=0 ID=56026 SEQ=55420 MARK=0x8000
Fri Nov 21 14:04:49 2025 daemon.err insmod: module is already loaded - slhc
Fri Nov 21 14:04:49 2025 daemon.err insmod: module is already loaded - ppp_generic
Fri Nov 21 14:04:49 2025 daemon.err insmod: module is already loaded - pppox
Fri Nov 21 14:04:49 2025 daemon.err insmod: module is already loaded - pppoe
Fri Nov 21 14:04:49 2025 daemon.info pppd[7005]: Plugin rp-pppoe.so loaded.
Fri Nov 21 14:04:49 2025 daemon.info pppd[7005]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Fri Nov 21 14:04:50 2025 daemon.notice pppd[7005]: pppd 2.4.8 started by root, uid 0
Fri Nov 21 14:04:55 2025 user.notice root: mtk-sdk eth halted detected, now reset it...
Fri Nov 21 14:04:55 2025 kern.info kernel: [1986397.623113] mtk_soc_eth 15100000.ethernet eth1: Link is Down
Fri Nov 21 14:04:55 2025 daemon.notice netifd: Network device 'eth1' link is down
Fri Nov 21 14:04:55 2025 daemon.notice netifd: VLAN 'eth1.1036' link is down
Fri Nov 21 14:04:55 2025 daemon.err pppd[7005]: error receiving pppoe packet: Network is down
Fri Nov 21 14:04:55 2025 daemon.notice netifd: Interface 'wan' has link connectivity loss
Fri Nov 21 14:04:55 2025 daemon.err pppd[7005]: select (waitForPADO): Interrupted system call
Fri Nov 21 14:04:55 2025 daemon.warn pppd[7005]: Timeout waiting for PADO packets
Fri Nov 21 14:04:55 2025 daemon.err pppd[7005]: Unable to complete PPPoE Discovery
Fri Nov 21 14:04:55 2025 daemon.info pppd[7005]: Exit.
Fri Nov 21 14:04:55 2025 daemon.notice netifd: Interface 'wan' is now down
Fri Nov 21 14:04:55 2025 daemon.notice netifd: Interface 'wan' is disabled
Fri Nov 21 14:04:55 2025 kern.info kernel: [1986398.052044] mtk_soc_eth 15100000.ethernet eth1: PHY [mdio-bus:01] driver [RTL8221B-VB-CG 2.5Gbps PHY]
Fri Nov 21 14:04:55 2025 kern.info kernel: [1986398.061759] mtk_soc_eth 15100000.ethernet eth1: configuring for phy/1000base-x link mode
Fri Nov 21 14:04:55 2025 kern.info kernel: [1986398.070080] device eth1 left promiscuous mode
Fri Nov 21 14:04:55 2025 daemon.notice netifd: Interface 'wan' is enabled
Fri Nov 21 14:04:55 2025 kern.info kernel: [1986398.076106] device eth1 entered promiscuous mode
Fri Nov 21 14:04:55 2025 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Fri Nov 21 14:04:55 2025 user.notice firewall: Reloading firewall due to ifdown of wan ()
Fri Nov 21 14:04:58 2025 daemon.notice netifd: Network device 'eth1' link is up
Fri Nov 21 14:04:58 2025 daemon.notice netifd: VLAN 'eth1.1036' link is up
Fri Nov 21 14:04:58 2025 daemon.notice netifd: Interface 'wan' has link connectivity
Fri Nov 21 14:04:58 2025 daemon.notice netifd: Interface 'wan' is setting up now
Fri Nov 21 14:04:58 2025 kern.info kernel: [1986401.310422] mtk_soc_eth 15100000.ethernet eth1: Link is Up - 2.5Gbps/Full - flow control off
Fri Nov 21 14:04:59 2025 user.notice ddns-scripts[6327]: glddns: PID '6327' terminated by 'SIGTERM' at 2025-11-21 14:04
Fri Nov 21 14:05:00 2025 user.notice ddns-scripts[8722]: ddns: PID '8722' started at 2025-11-21 14:05
Fri Nov 21 14:05:00 2025 user.notice ddns-scripts[8725]: glddns: PID '8725' started at 2025-11-21 14:05
Fri Nov 21 14:05:00 2025 user.warn ddns-scripts[8722]: ddns: Service section disabled! - TERMINATE
Fri Nov 21 14:05:00 2025 user.warn ddns-scripts[8722]: ddns: PID '8722' exit WITH ERROR '1' at 2025-11-21 14:05
Fri Nov 21 14:05:01 2025 user.warn ddns-scripts[8725]: glddns: NO valid IP found
Fri Nov 21 14:05:04 2025 user.warn ddns-scripts[8725]: glddns: Get current IP via 'web' failed - retry 1/0 in 60 seconds
Fri Nov 21 14:05:09 2025 kern.warn kernel: [1986411.673244] IN=br-lan OUT= MAC=94:83:c4:a8:a1:80:78:6c:84:9b:d8:25:08:00 SRC=192.168.1.123 DST=192.168.1.1 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=55008 DF PROTO=ICMP TYPE=8 CODE=0 ID=56026 SEQ=32168 MARK=0x8000
Fri Nov 21 14:05:28 2025 daemon.err insmod: module is already loaded - slhc
Fri Nov 21 14:05:28 2025 daemon.err insmod: module is already loaded - ppp_generic
Fri Nov 21 14:05:28 2025 daemon.err insmod: module is already loaded - pppox
Fri Nov 21 14:05:28 2025 daemon.err insmod: module is already loaded - pppoe
Fri Nov 21 14:05:28 2025 daemon.info pppd[9398]: Plugin rp-pppoe.so loaded.
