enricoz
Ciao, grazie per avermi risposto. Il post non credo possa essere modificato. Allego di seguito.
Grazie.
WiFi - MacOS da MB Pro con Chip M3 Pro da Terminale 2.4ghz
1. Speedtest by Ookla
Server: Dimensione - Campobasso (id: 51808)
ISP: Dimensione
Idle Latency: 21.75 ms (jitter: 0.48ms, low: 21.54ms, high: 22.28ms)
Download: 149.30 Mbps [==- ] 12% - latency: 115.76 ms Download: 154.69 Mbps (data used: 149.9 MB)
99.92 ms (jitter: 22.73ms, low: 53.72ms, high: 153.96ms)
Upload: 140.71 Mbps [=- ] 5% - latency: 145.73 ms Upload: 161.39 Mbps (data used: 291.5 MB)
170.66 ms (jitter: 57.28ms, low: 70.01ms, high: 286.54ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/0c42dba8-4e9c-4766-acc2-27e016c286ab
2. Speedtest by Ookla
Server: Dimensione - Rome (id: 59211)
ISP: Dimensione
Idle Latency: 12.95 ms (jitter: 0.03ms, low: 12.91ms, high: 12.97ms)
Download: 115.99 Mbps (data used: 67.8 MB)
17.66 ms (jitter: 5.89ms, low: 12.26ms, high: 45.93ms)
Upload: 142.92 Mbps [/ ] 4% - latency: 134.58 ms Upload: 154.57 Mbps (data used: 135.3 MB)
163.07 ms (jitter: 54.30ms, low: 36.76ms, high: 335.95ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/b202768a-304e-42f2-943d-ea521eef715c
(base)
Da OOKLA web
1. https://www.speedtest.net/it/result/18213492514 CB
2. https://www.speedtest.net/it/result/18213487274 RM
WiFi - MacOS da MB Pro con Chip M3 Pro da Terminale 5ghz
Server: wiber - Aversa (id: 65226)
ISP: Dimensione
Idle Latency: 13.04 ms (jitter: 0.30ms, low: 12.66ms, high: 13.17ms)
Download: 727.40 Mbps (data used: 355.3 MB)
15.43 ms (jitter: 2.76ms, low: 12.02ms, high: 34.66ms)
Upload: 931.63 Mbps (data used: 1.0 GB)
21.37 ms (jitter: 3.54ms, low: 12.23ms, high: 69.82ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/cbc706b5-b03f-4021-adf4-786fa8d30f68
ISP: Dimensione
Idle Latency: 20.05 ms (jitter: 0.16ms, low: 19.88ms, high: 20.24ms)
Download: 1574.49 Mbps [=====\ ] 28% - latency: 125.42 ms Download: 1650.91 Mbps (data used: 2.0 GB)
87.20 ms (jitter: 33.55ms, low: 18.98ms, high: 634.05ms)
Upload: 912.97 Mbps (data used: 1.2 GB)
38.19 ms (jitter: 9.53ms, low: 19.64ms, high: 538.92ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/1ab6e3ab-ae04-4978-8523-d2539d9aa48c
3. Speedtest by Ookla
ISP: Dimensione
Idle Latency: 11.96 ms (jitter: 0.16ms, low: 11.82ms, high: 12.06ms)
Download: 1718.85 Mbps (data used: 2.2 GB)
43.21 ms (jitter: 13.55ms, low: 12.09ms, high: 299.48ms)
Upload: 933.36 Mbps (data used: 956.0 MB)
22.13 ms (jitter: 3.43ms, low: 14.34ms, high: 74.06ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/5f1d8b58-7667-4417-8ee6-93e516595da6
Da OOKLA web
1. https://www.speedtest.net/it/result/18213433649 CB
2. https://www.speedtest.net/it/result/18213430832 RM
Speedtest via cavo da Terminale
ISP: Dimensione
Idle Latency: 9.80 ms (jitter: 0.15ms, low: 9.47ms, high: 10.01ms)
Download: 939.23 Mbps [==========/ ] 52% - latency: 131.32 ms Download: 927.51 Mbps [==========- ] 53% - latency: 131.32 ms Download: 949.71 Mbps [==========\ ] 54% - latency: 131.32 ms Download: 941.25 Mbps [==========| ] 54% - latency: 131.32 ms Download: 928.73 Mbps [===========/ ] 55% - latency: 131.32 ms Download: 936.47 Mbps (data used: 969.7 MB)
65.74 ms (jitter: 10.48ms, low: 39.51ms, high: 342.05ms)
Upload: 935.81 Mbps (data used: 928.2 MB)
12.87 ms (jitter: 0.15ms, low: 10.34ms, high: 14.92ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/fd671f5e-1936-4656-97e0-fa864d4236a9
ISP: Dimensione
Idle Latency: 17.97 ms (jitter: 0.20ms, low: 17.65ms, high: 18.06ms)
Download: 948.38 Mbps (data used: 1.1 GB)
89.81 ms (jitter: 12.77ms, low: 57.30ms, high: 123.34ms)
Upload: 935.79 Mbps (data used: 1.0 GB)
21.42 ms (jitter: 0.16ms, low: 17.63ms, high: 23.79ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/11a1060e-43e1-4ff0-953f-5357e1f645df
Da OOKLA Web
1. https://www.speedtest.net/it/result/18213480396 CB
2. https://www.speedtest.net/it/result/18213478481 RM
nPerf da sito dimensione
1. https://www.nperf.com/r/3599620019359307-AIGJrplH RM
2. https://www.nperf.com/r/3599620198707015-EKlqJ5pP CB
