Bisognerebbe cambiare il titolo della discussione 😉
herbert_one Effettivamente è fuorviante e mi dispiace, non penso di poterlo cambiare io. Devo scrivere ad un mod?
Ecco il log di quando inizia ad avere dei problemi la mattina. Ditemi se devo cercare qualcos'altro nel log o basta solo questo:
{System} 2024-09-16 06:26:14 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:26:18 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:26:18 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.182) to (Device.DHCPv4.Server.Pool.2.Client.183)
{System} 2024-09-16 06:26:18 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:26:24 admin (prpld) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.X_ID) from () to (4)
{System} 2024-09-16 06:26:24 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.MACAddress) from () to (1e:65:10:9f:0a:fa)
{System} 2024-09-16 06:26:24 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.X_AssociatedDeviceIPAddress) from () to (192.168.1.7)
{System} 2024-09-16 06:26:24 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.AssociationTime) from (0000-01-01T00:00:00Z) to (2024-09-16T06:26:23Z)
{System} 2024-09-16 06:26:24 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.X_SSIDConnected) from () to (Vodafone-C01300041)
{System} 2024-09-16 06:26:24 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.AuthenticationState) from (0) to (1)
{System} 2024-09-16 06:26:24 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.Active) from (0) to (1)
{System} 2024-09-16 06:26:24 admin (other) change node (*Device.LANDevice.1.Hosts.Host.8.AssociatedDevice) from () to (Device.WiFi.AccessPoint.1.AssociatedDevice.4.)
{System} 2024-09-16 06:26:24 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.8.Active) from (0) to (1)
{System} 2024-09-16 06:26:25 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.AssociationTime) from (0000-01-01T00:00:00Z) to (2024-09-16T04:26:24Z)
{System} 2024-09-16 06:26:25 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.MACAddress) from () to (1e:65:10:9f:0a:fa)
{System} 2024-09-16 06:26:25 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.AuthenticationState) from (0) to (1)
{System} 2024-09-16 06:26:25 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.Active) from (0) to (1)
{System} 2024-09-16 06:26:25 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.X_AssociatedDeviceIPAddress) from () to (192.168.1.7)
{System} 2024-09-16 06:26:25 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.X_SSIDConnected) from () to (Vodafone-C01300041)
{System} 2024-09-16 06:26:25 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.8.X_Options) from (53,55,57,61,50,51) to (53,55,57,61,51)
{System} 2024-09-16 06:26:25 admin (prpld) change node (Device.DHCPv4.Server.Poolv4.1.Client.6.X_ID) from () to (6)
{System} 2024-09-16 06:26:26 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.8.X_Options) from (53,55,57,61,51) to (53,55,57,61,50,54)
{System} 2024-09-16 06:26:27 admin (prpld) change node (Device.WiFi.AccessPoint.5.AssociatedDevice.4.X_ID) from () to (4)
{System} 2024-09-16 06:26:27 admin (other) change node (Device.WiFi.AccessPoint.5.AssociatedDevice.4.AssociationTime) from (0000-01-01T00:00:00Z) to (2024-09-16T04:26:26Z)
{System} 2024-09-16 06:26:27 admin (other) change node (Device.WiFi.AccessPoint.5.AssociatedDevice.4.MACAddress) from () to (1e:65:10:9f:0a:fa)
{System} 2024-09-16 06:26:27 admin (other) change node (Device.WiFi.AccessPoint.5.AssociatedDevice.4.AuthenticationState) from (0) to (1)
{System} 2024-09-16 06:26:27 admin (other) change node (Device.WiFi.AccessPoint.5.AssociatedDevice.4.Active) from (0) to (1)
{System} 2024-09-16 06:26:27 admin (other) change node (Device.WiFi.AccessPoint.5.AssociatedDevice.4.X_AssociatedDeviceIPAddress) from () to (192.168.1.7)
{System} 2024-09-16 06:26:27 admin (other) change node (Device.WiFi.AccessPoint.5.AssociatedDevice.4.X_SSIDConnected) from () to (Vodafone-C01300041)
{System} 2024-09-16 06:26:27 admin (other) change node (*Device.LANDevice.1.Hosts.Host.8.AssociatedDevice) from (Device.WiFi.AccessPoint.1.AssociatedDevice.4.) to (Device.WiFi.AccessPoint.5.AssociatedDevice.4.)
{System} 2024-09-16 06:26:27 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.8.Layer2Interface) from (Device.WiFi.SSID.1.) to (Device.WiFi.SSID.5.)
{System} 2024-09-16 06:26:27 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.8.Layer1Interface) from (Device.WiFi.Radio.1.) to (Device.WiFi.Radio.2.)
{System} 2024-09-16 06:26:50 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:26:54 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:26:54 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.183) to (Device.DHCPv4.Server.Pool.2.Client.184)
{System} 2024-09-16 06:26:54 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:27:03 admin (prpld) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.X_ID) from () to (4)
{System} 2024-09-16 06:27:04 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.AssociationTime) from (0000-01-01T00:00:00Z) to (2024-09-16T04:27:03Z)
{System} 2024-09-16 06:27:04 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.MACAddress) from () to (1e:65:10:9f:0a:fa)
{System} 2024-09-16 06:27:04 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.AuthenticationState) from (0) to (1)
{System} 2024-09-16 06:27:04 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.Active) from (0) to (1)
{System} 2024-09-16 06:27:04 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.X_AssociatedDeviceIPAddress) from () to (192.168.1.7)
{System} 2024-09-16 06:27:04 admin (other) change node (Device.WiFi.AccessPoint.1.AssociatedDevice.4.X_SSIDConnected) from () to (Vodafone-C01300041)
{System} 2024-09-16 06:27:04 admin (other) change node (*Device.LANDevice.1.Hosts.Host.8.AssociatedDevice) from (Device.WiFi.AccessPoint.5.AssociatedDevice.4.) to (Device.WiFi.AccessPoint.1.AssociatedDevice.4.)
{System} 2024-09-16 06:27:04 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.8.Layer2Interface) from (Device.WiFi.SSID.5.) to (Device.WiFi.SSID.1.)
{System} 2024-09-16 06:27:04 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.8.Layer1Interface) from (Device.WiFi.Radio.2.) to (Device.WiFi.Radio.1.)
{System} 2024-09-16 06:27:11 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.2.X_Options) from (53,57,50,54,55) to (53,57,55)
{System} 2024-09-16 06:27:11 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.2.X_Options) from (53,57,55) to (53,57,50,54,55)
{System} 2024-09-16 06:27:11 admin (prpld) change node (Device.DHCPv4.Server.Poolv4.1.Client.2.X_ID) from () to (2)
{System} 2024-09-16 06:27:27 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:27:31 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:27:31 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.184) to (Device.DHCPv4.Server.Pool.2.Client.185)
{System} 2024-09-16 06:27:31 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:28:03 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:28:07 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:28:07 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.185) to (Device.DHCPv4.Server.Pool.2.Client.186)
{System} 2024-09-16 06:28:07 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:28:40 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:28:43 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:28:44 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.186) to (Device.DHCPv4.Server.Pool.2.Client.187)
{System} 2024-09-16 06:28:44 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:29:01 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.8.Active) from (1) to (0)
{System} 2024-09-16 06:29:01 admin (other) change node (*Device.LANDevice.1.Hosts.Host.8.AssociatedDevice) from (Device.WiFi.AccessPoint.1.AssociatedDevice.4.) to ()
{System} 2024-09-16 06:29:16 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:29:20 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:29:20 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.187) to (Device.DHCPv4.Server.Pool.2.Client.188)
{System} 2024-09-16 06:29:20 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:29:53 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:29:56 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:29:57 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.188) to (Device.DHCPv4.Server.Pool.2.Client.189)
{System} 2024-09-16 06:29:57 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:30:29 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:30:33 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:30:33 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.189) to (Device.DHCPv4.Server.Pool.2.Client.190)
{System} 2024-09-16 06:30:33 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:31:06 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:31:09 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:31:10 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.190) to (Device.DHCPv4.Server.Pool.2.Client.191)
{System} 2024-09-16 06:31:10 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:31:42 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:31:46 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:31:46 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.191) to (Device.DHCPv4.Server.Pool.2.Client.192)
{System} 2024-09-16 06:31:46 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:32:02 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.2.X_Options) from (53,57,50,54,55) to (53,57,55)
{System} 2024-09-16 06:32:02 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.2.X_Options) from (53,57,55) to (53,57,50,54,55)
{System} 2024-09-16 06:32:02 admin (prpld) change node (Device.DHCPv4.Server.Poolv4.1.Client.2.X_ID) from () to (2)
{System} 2024-09-16 06:32:19 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:32:22 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:32:22 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.192) to (Device.DHCPv4.Server.Pool.2.Client.193)
{System} 2024-09-16 06:32:23 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:32:55 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:32:59 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:32:59 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.193) to (Device.DHCPv4.Server.Pool.2.Client.194)
{System} 2024-09-16 06:32:59 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:33:32 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:33:35 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:33:36 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.194) to (Device.DHCPv4.Server.Pool.2.Client.195)
{System} 2024-09-16 06:33:36 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:34:08 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
{System} 2024-09-16 06:34:12 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,54) to (53,61,57,55,60,12)
{System} 2024-09-16 06:34:12 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.DHCPClient) from (Device.DHCPv4.Server.Pool.2.Client.195) to (Device.DHCPv4.Server.Pool.2.Client.196)
{System} 2024-09-16 06:34:12 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,57,55,60,12) to (53,61,50,54,57,55,60,12)
{System} 2024-09-16 06:34:45 admin (smd) change node (*Device.LANDevice.1.Hosts.Host.6.X_Options) from (53,61,50,54,57,55,60,12) to (53,61,54)
[System] 2024-09-15 08:11:16 Register watchdog (syslogd)
[System] 2024-09-15 08:11:16 Register watchdog (klogd)
[GPON] 2024-09-15 08:11:16 Starting GPON interface OK.
[System] 2024-09-15 08:11:16 Register watchdog (gpon_monitor)
[System] 2024-09-15 08:11:16 Register watchdog (umcid)
[System] 2024-09-15 08:11:17 Register watchdog (kpi_d)
[GPON] 2024-09-15 08:11:17 OLT reset the OMCI mib.
[System] 2024-09-15 08:11:18 Register watchdog (network_manager)
[System] 2024-09-15 08:11:18 Register watchdog (uevent)
[LAN] 2024-09-15 08:11:18 LAN Port [2] link is down.
[Firewall] 2024-09-15 08:11:20 Firewall Block Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 IP Spoof Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 UDP Per IP Flood Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 ICMP Per IP Flood Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 TCP SYN Per IP Flood Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 TCP FIN Per IP Flood Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 Port Scan Per IP Flood Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 IP Land Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 IP Broadcast Source Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 TCP Syn With Data Detect has been enabled.
[Firewall] 2024-09-15 08:11:20 TCP Syn With Data Detect has been disabled.
[WIFI] 2024-09-15 08:11:20 auth_url:https://acm-device-auth-ap.wifi-doctor.org/oauth/token
[LAN] 2024-09-15 08:11:21 LAN Port [2] connected, Link Speed: [100M F].
[WIFI] 2024-09-15 08:11:21 [wifi-doctor]driver fail on add mac of working wl0.1
[WIFI] 2024-09-15 08:11:21 [wifi-doctor]Failed opening /mnt/2/data/airties/station_power_list file for reading
[System] 2024-09-15 08:11:26 Stopping SSH OK.
[System] 2024-09-15 08:11:26 DNSMasq proxy server enable
[System] 2024-09-15 08:11:26 Starting DNSMasq proxy server OK.
[System] 2024-09-15 08:11:26 Starting DNS proxy Server OK.
[System] 2024-09-15 08:11:26 Register watchdog (cwmp_monitor)
[System] 2024-09-15 08:11:26 Register watchdog (diagnose_server)
[System] 2024-09-15 08:11:26 Register watchdog (chronyd)
[IPTV] 2024-09-15 08:11:26 Start IPTV OK
[System] 2024-09-15 08:11:26 Register watchdog (mcast_daemon)
[System] 2024-09-15 08:11:27 Register watchdog (dnsmasq)
[IPTV] 2024-09-15 08:11:27 LAN send out a general query.
[System] 2024-09-15 08:11:27 Register watchdog (vgw_app)
[VoIP] 2024-09-15 08:11:27 VoCS: Change service mode from NET to GSM
[System] 2024-09-15 08:11:28 Starting VoIP OK..
[System] 2024-09-15 08:11:28 Starting WiFi interface OK.
[System] 2024-09-15 08:11:28 Register watchdog (voip_monitor)
[WIFI] 2024-09-15 08:11:29 WiFi Init..
[WIFI] 2024-09-15 08:11:29 wlssk start and init
[System] 2024-09-15 08:11:30 Register watchdog (wifi_radar)
[System] 2024-09-15 08:11:30 SmartApp is enabled.
[System] 2024-09-15 08:11:30 Register watchdog (temp_monitor)
[System] 2024-09-15 08:11:30 Register watchdog (plugind)
[System] 2024-09-15 08:11:30 Register watchdog (optical_monitor)
[System] 2024-09-15 08:11:30 RX Power (-40.00)dbm is lower than the threshold (-28.00)dbm
[System] 2024-09-15 08:11:30 TX Power (-2147483.75)dbm is lower than the threshold (0.50)dbm
[System] 2024-09-15 08:11:30 Register watchdog (rtmd)
[System] 2024-09-15 08:11:30 SmartApp Notification Server register FAIL.
[System] 2024-09-15 08:11:31 Register watchdog (radvd_0)
[System] 2024-09-15 08:11:31 Register watchdog (radvd_1)
[WIFI] 2024-09-15 08:11:32 auth_url:https://acm-device-auth-ap.wifi-doctor.org/oauth/token
[WIFI] 2024-09-15 08:11:32 wifi-doctor is running, kill it
[System] 2024-09-15 08:11:33 Register watchdog (klogd)
[Firewall] 2024-09-15 08:11:33 Firewall Level has been set to Low.
[System] 2024-09-15 08:11:33 Register watchdog (networkmap)
[Firewall] 2024-09-15 08:11:33 Local UDP Flood Detect has been enabled on LAN.
[Firewall] 2024-09-15 08:11:33 Local ICMP Flood Detect has been enabled on LAN.
[Firewall] 2024-09-15 08:11:33 Local Winnuke Detect has been enabled on LAN.
[Firewall] 2024-09-15 08:11:33 Local LAN Source Detect has been enabled.
[Firewall] 2024-09-15 08:11:33 Local Smurf Detect has been enabled on LAN.
[VoIP] 2024-09-15 08:11:34 Starting VoIP OK.
[VoIP] 2024-09-15 08:11:34 VoIP call manager v02.01.00_01.13a.2024-06-23,17:06
[VoIP] 2024-09-15 08:11:34 VoIP service running at Jan 1 08:00:38 1970
[Firewall] 2024-09-15 08:11:34 Local GUEST Flood Detect has been enabled on LAN.
[Firewall] 2024-09-15 08:11:34 Local Fragment Flood Detect has been enabled on LAN.
[System] 2024-09-15 08:11:34 Starting LAN interface OK.
[System] 2024-09-15 08:11:34 Starting DHCP server OK.
[LAN] 2024-09-15 08:11:34 DHCP Server Started
[System] 2024-09-15 08:11:34 Register watchdog (udhcpd)
[System] 2024-09-15 08:11:37 Stopping HTTP OK.
[System] 2024-09-15 08:11:41 Register watchdog (dhcp6s_1)
[System] 2024-09-15 08:11:41 Register watchdog (dhcp6s_0)
[WIFI] 2024-09-15 08:11:42 channel score,channel 40/160(0xe932):bss20 intf0 intfadj0 txpwr100 bgn6 txop50 cns-85 adj0 dfs5 total181
[WIFI] 2024-09-15 08:11:42 channel score,channel 44/160(0xea32):bss20 intf0 intfadj0 txpwr100 bgn6 txop50 cns-85 adj0 dfs5 total181
[WIFI] 2024-09-15 08:11:42 channel score,channel 48/160(0xeb32):bss20 intf0 intfadj0 txpwr100 bgn6 txop50 cns-85 adj0 dfs5 total181
[WIFI] 2024-09-15 08:11:42 channel score,channel 52/160(0xec32):bss10 intf0 intfadj0 txpwr100 bgn6 txop50 cns-85 adj0 dfs5 total171
[WIFI] 2024-09-15 08:11:42 channel score,channel 56/160(0xed32):bss10 intf0 intfadj0 txpwr100 bgn6 txop50 cns-85 adj0 dfs5 total171
[WIFI] 2024-09-15 08:11:42 channel score,channel 60/160(0xee32):bss20 intf0 intfadj0 txpwr100 bgn6 txop50 cns-85 adj0 dfs5 total181
[WIFI] 2024-09-15 08:11:42 channel score,channel 64/160(0xef32):bss20 intf0 intfadj0 txpwr100 bgn6 txop50 cns-85 adj0 dfs5 total181
[WIFI] 2024-09-15 08:11:42 5G select auto channel :52
[WIFI] 2024-09-15 08:11:43 wifi-doctor still exists, kill it with killall -9
[WIFI] 2024-09-15 08:11:43 ACSD: Timestamp(ms): 47 ACS-Trigger:INIT Selected Channel:#52/160 (0xec32)
[WIFI] 2024-09-15 08:11:43 [wifi-doctor]Failed opening /mnt/2/data/airties/station_power_list file for reading
[WIFI] 2024-09-15 08:11:47 channel score,channel 1(0x1001):bss100 busy32 intf22 bgn10 txop550 cns-73 dfs0 total714
[WIFI] 2024-09-15 08:11:47 channel score,channel 2(0x1002):bss10 busy8 intf22 bgn10 txop350 cns-74 dfs0 total400
[WIFI] 2024-09-15 08:11:47 channel score,channel 3(0x1003):bss0 busy5 intf19 bgn2 txop350 cns-93 dfs0 total376
[WIFI] 2024-09-15 08:11:47 channel score,channel 5(0x1005):bss10 busy5 intf26 bgn1 txop350 cns-94 dfs0 total392
[WIFI] 2024-09-15 08:11:47 channel score,channel 6(0x1006):bss50 busy20 intf9 bgn0 txop350 cns-97 dfs0 total429
[WIFI] 2024-09-15 08:11:47 channel score,channel 9(0x1009):bss10 busy7 intf16 bgn0 txop250 cns-96 dfs0 total283
[WIFI] 2024-09-15 08:11:47 channel score,channel 10(0x100a):bss20 busy5 intf13 bgn0 txop250 cns-96 dfs0 total288
[WIFI] 2024-09-15 08:11:47 channel score,channel 11(0x100b):bss20 busy10 intf25 bgn0 txop450 cns-95 dfs0 total505
[WIFI] 2024-09-15 08:11:47 channel score,channel 12(0x100c):bss10 busy7 intf13 bgn0 txop250 cns-97 dfs0 total280
[WIFI] 2024-09-15 08:11:47 2.4G select auto channel :12
[WIFI] 2024-09-15 08:11:47 ACSD: Timestamp(ms): 51 ACS-Trigger:INIT Selected Channel:#12 (0x100c)
[System] 2024-09-15 08:11:47 Starting HTTP OK.
[WIFI] 2024-09-15 08:11:47 [wifi-doctor][exec] request https://acm-device-auth-ap.wifi-doctor.org/oauth/token - 0:6=Couldn't resolve host name
[WIFI] 2024-09-15 08:11:47 [wifi-doctor][fhc_common] Trying to publish MQTT message when fhc state is "UNINITIALIZED"
[WIFI] 2024-09-15 08:11:47 [wifi-doctor][mqtt] MQTT error 4: in publish - The client is not currently connected.
[WIFI] 2024-09-15 08:11:47 [wifi-doctor][fhc] Failed sending infra object
[WIFI] 2024-09-15 08:11:47 [wifi-doctor][main] Failed dispatching update done
[WIFI] 2024-09-15 08:11:47 [wifi-doctor][fhc] Failed sending stats object
[WIFI] 2024-09-15 08:11:47 [wifi-doctor]interface 'wl0.2' probe
[WIFI] 2024-09-15 08:11:47 [wifi-doctor]interface 'wl0.3' probe
[WIFI] 2024-09-15 08:11:47 [wifi-doctor]interface 'wl0.4' probe
[WIFI] 2024-09-15 08:11:47 [wifi-doctor]interface 'wl0.5' probe
[WIFI] 2024-09-15 08:11:47 [wifi-doctor]interface 'wl0.6' probe
[WIFI] 2024-09-15 08:11:47 [wifi-doctor]interface 'wl0.7' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor][fhc_common] Trying to publish MQTT message when fhc state is "UNINITIALIZED"
[WIFI] 2024-09-15 08:11:48 [wifi-doctor][mqtt] MQTT error 4: in publish - The client is not currently connected.
[WIFI] 2024-09-15 08:11:48 [wifi-doctor][fhc] Failed sending infra object
[WIFI] 2024-09-15 08:11:48 [wifi-doctor][main] Failed dispatching update done
[WIFI] 2024-09-15 08:11:48 [wifi-doctor]interface 'wl1.2' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor]interface 'wl1.3' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor]interface 'wl1.4' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor]interface 'wl1.5' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor]interface 'wl1.6' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor]interface 'wl1.7' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor]radio 'wl2' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor]radio 'wl3' probe
[WIFI] 2024-09-15 08:11:48 [wifi-doctor][fhc] Failed sending stats object
[IPTV] 2024-09-15 08:11:48 LAN send out a general query.
[WIFI] 2024-09-15 08:11:49 [wifi-doctor][fhc_common] Trying to publish MQTT message when fhc state is "UNINITIALIZED"
[WIFI] 2024-09-15 08:11:49 [wifi-doctor][fhc] Failed sending stats object
[System] 2024-09-15 08:11:50 Stopping UPnP OK.
