stich86
Ma la procedura tua per installare OpenWrt ?
Mi sa che a colllegare e scollegare mi è saltato FDT ,. cioè tutta la Board .
Possibili consigli o link da seguire ?
U-Boot 2012.07 [Chaos Calmer 15.05.1,IPQ4019.ILQ.6.1.0.r2-00006-P-1] (May 14 2021 - 09:05:27)
smem ram ptable found: ver: 1 len: 3
DRAM: 256 MiB
machid : 0x8010001
NAND: spi_nand: spi_nand_flash_probe SF NAND ID ff:c8:d1:c8
SF: Detected GD5F1GQ4XB with page size 2 KiB, total 128 MiB
SF: Detected GD25Q16 with page size 4 KiB, total 2 MiB
ipq_spi: page_size: 0x100, sector_size: 0x1000, size: 0x200000
130 MiB
*** Warning - bad CRC, using default environment
PCI0 Link Intialized
In: serial
Out: serial
Err: serial
machid: 8010001
flash_type: 0
Uaztemain: enter into !
ZTE_InitFotaFlashPara: nand_curr_device=1
zte_getHandOffState: read data=0x20 from 0x0
Press ESC to abort autoboot in 0 seconds
Creating 1 MTD partitions on "nand1":
0x000001800000-0x000003500000 : "mtd=0"
UBI: attaching mtd2 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: attached mtd2 to ubi0
UBI: MTD device name: "mtd=0"
UBI: MTD device size: 29 MiB
UBI: number of good PEBs: 232
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 2
UBI: available PEBs: 59
UBI: total number of reserved PEBs: 173
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 1/0
Read 0 bytes from volume kernel to 84000000
No size specified -> Using max size (4317184)
Booting kernel from FIT Image at 84000000 ...
Using 'config@ap.dk04.1-c1' configuration
Trying 'kernel@1' kernel subimage
Description: ARM OpenWrt Linux-3.14.77
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x840000e4
Data Size: 3617308 Bytes = 3.4 MiB
Architecture: ARM
OS: Linux
Load Address: 0x80208000
Entry Point: 0x80208000
Hash algo: crc32
Hash value: 49c0a241
Hash algo: sha1
Hash value: c18d0ca45d033085492275a382eb04c9a4540f55
Verifying Hash Integrity ... crc32+ sha1+ OK
Flattened Device Tree from FIT Image at 84000000
Trying 'fdt@ap.dk04.1-c1' FDT blob subimage
Description: ARM OpenWrt qcom-ipq40xx-ap.dkxx device tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x843e9518
Data Size: 40402 Bytes = 39.5 KiB
Architecture: ARM
Hash algo: crc32
Hash value: eeda59d5
Hash algo: sha1
Hash value: ae0a3c9e5404507aff233137212cc3522ce2b817
Booting using the fdt blob at 0x843e9518
Uncompressing Kernel Image ... OK
Loading Device Tree to 86ff3000, end 86fffdd1 ... ERROR: fdt move failed - must RESET the board to recover.
creation failed! hanging...### ERROR ### Please RESET the board ###
