NScirocco
Non ho un router Asus e non so se quel modello ci sono questi parametri, però se ci sono prova a disabilitarli uno alla volta e ripetere i test.
Two-Way IPS
To disable Two-Way IPS:
From the navigation panel, go to General > Game IPS.
From the Game IPS main page, click Network Protection.
From the Two-Way IPS pane, click ON to turn it off.
Infected Device Prevention and Blocking
To disable infected device prevention and blocking:
From the Infected Device Prevention and Blocking pane, click ON to turn it off.
