Buongiorno, ho collegato il modem direttamente alla morsettiera Telecom e sotto posto i risultati. Da tener presente che il test è durato esattamente 60 minuti ma tra le 7,47 e le 8,47 di questa mattina e quindi in un'ora di scarso traffico.
Alle 7,52 ho fatto anche uno speedtest da speedtest.net ed avevo Ping 20ms, Download 28,79 Mbps, Upload 12,56 Mbps.
Con il modem collegato alla presa telefonica dentro l'appartamento perdevo circa 1 Mbps in upload ma il resto era quasi ugiuale
xDSLFwVersion: FwVer:5.12.12.0_B_A60901 HwVer:T14.F7_0.0
Line State: Up
Modulation: ITU G.993.2(VDSL2), G.998.4(G.I
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 16512
shineGINPdownstream: 570
shineGINPupstream: 560
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end interleaved channel bit rate: 30763 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 0 kbps
far-end fast channel bit rate: 13423 kbps
near-end FEC error fast: 0
near-end FEC error interleaved: 53450129
near-end CRC error fast: 0
near-end CRC error interleaved: 0
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 22
far-end FEC error interleaved: 0
far-end CRC error fast: 0
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
DSL uptime : 1:00, 9 secs
DSL activetime :0 min, 15 secs
Downstream:
relative capacity occupation: 100%
noise margin downstream: 6.2 dB
output power upstream: 8.4 dbm
attenuation downstream: 16.8 dB
Upstream:
noise margin upstream: 5.7 dB
output power downstream: 11.7 dbm
attenuation upstream: 1.3 dB
Bit table:
carrier load: number of bits per tone
tone 0- 31: 00 00 00 0b cd ee ff ff ff ff fe ee ff ff fe ed
tone 32- 63: d4 55 66 67 77 77 78 88 89 99 9a a9 aa ab bb cc
tone 64- 95: cc cc cc cc cc bc cc cc cc cc cc cc cc cb cc cb
tone 96-127: bb cb bc bb bb bc bb bb bb bb bb ab bb bb ba ab
tone 128-159: aa aa aa aa aa aa aa 9a aa 99 99 99 99 99 98 88
tone 160-191: 88 88 87 78 87 77 77 77 77 77 66 66 55 66 55 45
tone 192-223: 55 44 44 44 44 44 33 33 33 33 33 33 33 33 33 33
tone 224-255: 33 33 33 33 34 44 44 34 44 44 44 34 44 44 44 44
