Ciao, ho configurato un server wireguard su una vps, dal client sul mio PC connette e tutto a posto, ma il mio router wrt non ne vuole sapere di avviare il client
Questo è il primo errore che ho avuto:
Sun Sep 10 15:23:56 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Sun Sep 10 15:23:57 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Sep 10 15:23:58 2023 daemon.notice netifd: wgclient (10535): RTNETLINK answers: Permission denied
Questo sopra l'ho risolto abilitando ipv6 nel router, ma ora sono fermo qua:
Sun Sep 10 15:30:29 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Sep 10 15:32:21 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-GIVEUP SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Sun Sep 10 15:32:26 2023 daemon.notice netifd: wgclient (24636): [!] Section @forwarding[0] is disabled, ignoring section
Sun Sep 10 15:32:26 2023 daemon.notice netifd: wgclient (24636): [!] Section @forwarding[1] is disabled, ignoring section
Sun Sep 10 15:32:26 2023 daemon.notice netifd: wgclient (24636): [!] Section gls2s option 'reload' is not supported by fw4
Sun Sep 10 15:32:26 2023 daemon.notice netifd: wgclient (24636): [!] Section gls2s specifies unreachable path '/var/etc/gls2s.include', ignoring section
Sun Sep 10 15:32:26 2023 daemon.notice netifd: wgclient (24636): [!] Section glblock option 'reload' is not supported by fw4
Sun Sep 10 15:32:26 2023 daemon.notice netifd: wgclient (24636): [!] Section vpn_server_policy option 'reload' is not supported by fw4
Sun Sep 10 15:32:26 2023 daemon.notice netifd: wgclient (24636): [!] Automatically including '/usr/share/nftables.d/chain-pre/mangle_output/01-process_mark.nft'
Sun Sep 10 15:32:26 2023 daemon.notice netifd: wgclient (24636): [!] Automatically including '/usr/share/nftables.d/chain-post/mangle_output/out_conn_mark_restore.nft'
Sun Sep 10 15:32:28 2023 daemon.notice netifd: wgclient (24636): DROP all opt -- in * out * 0.0.0.0/0 -> 0.0.0.0/0 match-set GL_MAC_BLOCK src
Sun Sep 10 15:32:29 2023 daemon.notice netifd: wgclient (24636): Failed to parse json data: unexpected character
Sun Sep 10 15:32:29 2023 daemon.notice netifd: wgclient (24636): uci: Entry not found
Sun Sep 10 15:32:29 2023 daemon.notice netifd: wgclient (24636): cat: can't open '/tmp/run/wg_resolved_ip': No such file or directory
Sun Sep 10 15:32:29 2023 daemon.notice netifd: Interface 'wgclient' is now down
Sun Sep 10 15:32:29 2023 daemon.notice netifd: Interface 'wgclient' is setting up now
Sun Sep 10 15:32:31 2023 user.notice mwan3[24817]: Execute ifdown event on interface wgclient (unknown)
Sun Sep 10 15:32:35 2023 user.notice firewall: Reloading firewall due to ifdown of wgclient ()
Qualcuno sa qualocsa? Grazie
Il software del router GLINET AR300M16 si basa su OpenWrt 22.03.4
