2.5Gb da singolo dispositivo [Techdigital]
Ecco la guida di cui avevi bisogno @Alukino , è sul zyxel Armor G5
Link: https://telegra.ph/Modifiche-Zyxel-Armor-G5-su-firmware-stock-06-13
Gentilmente offerta dal gruppo Telegram Fibraclick Bar da Mattia (tiarap00 su telegram)
Queste sono le modifiche per il file network, i campi da modificare in base al proprio operatore sono username e password sotto WAN
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config interface 'wan_vlan'
option ifname 'eth4'
option vid '835'
option mtu '1492'
option proto 'none'
config interface 'lan'
option ifname 'eth0 eth1 eth2 eth3 eth5'
option type 'bridge'
option ipaddr '192.168.123.1'
option netmask '255.255.255.0'
option stp '0'
option vid '1'
option priority '0'
option dns1 'ISP,'
option dns2 'ISP,'
option dns3 'ISP,'
option dnsv6_1 'ISP,'
option dnsv6_2 'ISP,'
option dnsv6_3 'ISP,'
option mtu '1492'
option hairpin '1'
option hostname 'NBG7815'
option multicast_querier '0'
option igmp_snooping '0'
config interface 'wan'
option ifname 'eth4.835'
option proto 'pppoe'
option username 'timadsl'
option password 'VOSTRO_FISSO_DA_SOSTITUIRE'
option ipv6 'auto'
option mtu '1492'
option dns 'ISP'
option dns1 'ISP'
config interface 'wan6rd'
config interface 'wan6in4'
config interface 'wan6to4'
config network 'general'
option backup_lan_ip '192.168.123.1'
option backup_lan_mask '255.255.255.0'
option backup_aplan_proto 'dhcp'
option backup_wan_proto 'dhcp'
option backup_wan_mtu '1492'
option IPv6ConfFlag '1'
option wan6rd_enable '0'
option wan6to4_enable '0'
option wan6in4_enable '0'
option dhcpv6pd '1'
option linkLocalOnly '0'
option v6lanstatic '0'
option ULA '0'
option auto_ip_change '0'
config interface 'guest'
option ipaddr '192.168.141.1'
option ieee1905managed '1'
option ipv6 '0'
option stp '1'
config interface 'visitor'
option ipaddr '192.168.142.1'
option ipv6 '0'
option stp '1'
config globals 'globals'
option ula_prefix 'auto'
config alias 'alias'
option proto 'none'
option ipaddr '192.168.123.2'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '0 1 2 3 5'
option vid '1'
config interface 'ipoe'
option mtu '1500'
option ipv6 '0'
ChristianV
Che roba è?
Posso dirti che in qualunque ora [parlo per i test classici su internet Eolo oakla .... Non cambia di mezza virgola dal lunedì a sabato e domenica indipendentemente dalla ora.
Però c e da dire che nel mio paese 800 900 abitanti sono l unico con questa rete [che corre in alto nei cavi Enel quindi non segue le altre linee]. E uno dei pochi anche con openfiber in tutto il paese.
Techdigital sentita oggi per chiedere se fornissero un modulo sfp o possibilità di connessione con sfp [tentare non nuoce] <ma pur troppo no, solo Wan.
Però mi hanno proposto una connessione a 10 gbps non ancora presente sul sito loro ma disponibile nella mia zona [stimati 9.7] a 49.99 al mese ci sto pensando. mi spaventa il costo del modem e della scheda di rete che dovrei mettere.
mi sa che rimarrò con la 2.5. ma se qualcuno è interessato
Alukino È il codice per completare quella guida dell'Armor G5
FezVrasta
Ho un PC nuovo cambiato 4-5 settimane fa
I7 13700k
Gammax l360
Z790 non ricordo modello cmq con porta 2.5
Chiaramente ne ho 2 perché avevo una scheda 2.5 nulla di che 30 euro su Amazon aquistata per il precedente pc
128 GB DDR5 6600
SSD 2tb nmve 7000 mb al secondo lettura 6600 scrittura
Rtx 4090
Ali 1000w
Come pc credo potrei enere anche una 10gbps
Ma dopo potrei prendere solo il
TP-Link Archer AXE300 se nn ho capito male
ChristianV Ciao Christian,
questa configurazione e' abilitata anche per IPV6?
panasonic83
Premetto che ne so 0 di connessioni so che l opzione c e ma abilitata Bo nn ho idea.
panasonic83
Non saprei, nel codice della wan c'è option ipv6 'auto'
ma bisognerebbe provare
ChristianV quando mi arriva (fine giugno) provero'
- TechDigital
panasonic83 vedendo dai traceroute è abilitata già in ipv6
Alukino nel caso avessi bisogno di aiuto con la configurazione puoi tranquillamente contattarci
giuse19101
gentilissimo ma ho combinato non era difficile un po strano rispetto al solito modem (diciamo un mini windows (sistema operativo)) una 50ina di opzioni in piu
aggiungo l unico modem che quando (apro le porte (con open nat o manuali) e poi testo la porta risulta veramente open.
ecco la connessione il nuovo test parte da 2200 mr circa 2300 a volte poi scende stabilizzandosi a 1700 1600 alcune volte.
so che è un test cosi cosi ma non avevo palle di ripetere tutto poi non credo cambi molto a livello di ms o ping
una curiosità da cosa dipende che io ho 1700 o 2300 di picco e altri con la stessa connessione 2.5 hanno 600 mb dalle cabine vecchie.....da quanta gente c e ....
dopo mesi c e l ho fatta preso modem serio da 2.5 gbps e riesco a usare la connessione al 100% del suo potenziale
