break Stiamo lottando con una scarsa copertura 4G in loco. iPhone 13 mostra solo due barre per la potenza del segnale in loco e il mio test di velocità è di 4 - 7 mbps. Cosa stai suggerendo? (Sim-card modello) Se confrontiamo Huawei vs ZTE, quale va bene per un segnale 4G scadente? Nota: sto usando translate scusa per il cattivo Italiano
andreagdipaolo break you can use English if you find it easier, also translators usually work better translating to English than to Italian
break We are struggling with poor 4G coverage on site. iPhone 13 only shows two bars for on-site signal strength and my speed test is 4 - 7 mbps. What are you suggesting? (Sim-card model) If we compare Huawei vs ZTE, which one is good for a poor 4G signal?
Camel90 break Hi, before buying a 4g router you must first understand why you have these low speeds. If you are a bit practical you could post the radio stats via field tests. Otherwise you could follow this guide and post the whole thing https://forum.fibra.click/d/29155-shortenb-uno-shortcut-che-decodifica-il-cellid-della-bts-a-cui-si-e-connessi
MentalBreach break 35 km is quite a lot of distance for phone signal. Are you in Italy? If yes, you can search for a nearer BTS (maybe of another cellphone service provider) at this website: https://lteitaly.it/it/
Camel90 break Then the ideal for you is an outdoor router. A mikrotik LHGG is the best solution for you
break Camel90 Thanks but no need to suggestion. Limited devices are working here. Which one is good for a poor 4G signal? (ZTE MF286D vs Huawei B535-932)
Camel90 break None of the 2. With the devices you indicated you will have the same reception as your current iPhone. At most, Huawei is better only because you wouldn't have problems with any external antennas
break Camel90 4-7 mbps is good 🙂 I can watch Netflix SD with this speed. I will go with Huawei B535. Thanks.
