stich86 yes but I don't know how to write my IMEI on the dummy file (dummy_IMEI_vfde.qcn) for me to then be able to restore it... I already tried backing it up successfully just in case.
I tried using the EFS professional program which is mentioned in the recovery guide but I found no instructions there on how to do it or the program doesn't work for me...
I don't know at this point... I could send u my IMEI on personal message if you are able to write it in the dummy file, but still... I should learn somehow to do it by myself
I even tried finding mine in Hex editor from the backup that I made and then type it in the exact place on the dummy file but I couldn't even find that...
UPDATE: I tried booting it to QMI mode via the AT commands but it doesn't seem to be able to boot back there.. (that also means I can't have adb access yet) and checking info via ATI command shows that
It seems like a bad sign to me... unless it's because I have to restore my IMEI (if flash.cmd broke it) or restore the config file...
Thank you for the help so far! I am waiting for your reply because I am stuck on this step so I can't use the device till I proceed further.
