Buongiorno, dopo un po di giorni ho fatto tornare il tecnico come mi avete suggerito (la linea era ulteriormente peggiorata) ed ha constatato che la coppia su cui mi avevano messo era degradata. Con il nuovo cambio ora aggancio questi valori strani:
Status: Showtime
Number of Cuts: 0
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 21171 Kbps, Downstream rate = 31883 Kbps
Bearer: 0, Upstream rate = 10799 Kbps, Downstream rate = 31178 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U😮N /D😮N
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (d😎: 12.1 11.6
Attn(d😎: 21.5 0.0
Pwr(dBm): 14.5 10.1
VDSL2 framing
Bearer 0
MSGc: -6 -6
B: 227 49
M: 1 1
T: 0 0
R: 10 12
S: 0.2326 0.1439
L: 8186 3447
D: 4 4
I: 238 62
N: 238 62
Q: 4 4
V: 0 3
RxQueue: 121 195
TxQueue: 11 15
G.INP Framing: 18 18
G.INP lookback: 11 15
RRC bits: 24 24
Bearer 1
MSGc: 90 58
B: 0 0
M: 2 2
T: 2 2
R: 16 16
S: 10.6667 16.0000
L: 24 16
D: 3 1
I: 32 32
N: 32 32
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 0
OHFErr: 0 0
RS: 265729288 431187453
RSCorr: 411 71
RSUnCorr: 0 0
Bearer 1
OHF: 965789 969466
OHFErr: 0 0
RS: 5794366 3877864
RSCorr: 66 22
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 209 120
rtx_c: 169 56
rtx_uc: 0 0
G.INP Counters
LEFTRS: 0 0
minEFTR: 31172 10795
errFreeBits: 7368675 2543804
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 930109485 0
Data Cells: 21941170 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 0 0
SES: 0 0
UAS: 30 30
AS: 15513
Bearer 0
INP: 101.00 103.00
INPRein: 4.00 4.00
delay: 0 0
PER: 0.00 0.00
OR: 0.01 0.01
AgR: 31246.14 11076.08
Bearer 1
INP: 8.00 4.00
INPRein: 8.00 4.00
delay: 5 0
PER: 16.06 16.06
OR: 47.81 31.87
AgR: 47.81 31.87
Bitswap: 2/2 1/1
Total time = 4 hours 19 min 3 sec
ReceiveBlocks: 0
Transmitblocks: 0
FEC: 411 71
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 30 30
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
HostInitRetr: 0
FailedRetr: 0
Latest 15 minutes time = 4 min 3 sec
ReceiveBlocks: 0
Transmitblocks: 0
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
HostInitRetr: 0
FailedRetr: 0
Previous 15 minutes time = 15 min 0 sec
ReceiveBlocks: 0
Transmitblocks: 0
FEC: 33 7
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: N/A
HostInitRetr: N/A
FailedRetr: N/A
Latest 1 day time = 4 hours 19 min 3 sec
ReceiveBlocks: 0
Transmitblocks: 0
FEC: 411 71
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 30 30
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
HostInitRetr: 0
FailedRetr: 0
Previous 1 day time = 0 sec
ReceiveBlocks: 0
Transmitblocks: 0
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
HostInitRetr: 0
FailedRetr: 0
Since Link time = 4 hours 18 min 31 sec
ReceiveBlocks: 1313815125
Transmitblocks: 977547040
FEC: 411 71
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
HostInitRetr: 0
FailedRetr: 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
Il tecnico mi ha detto di provare la linea (essendo che comunque con la precedente coppia agganciavo 20mbps in up) e di richiamarlo lunedi in caso di problemi. Quello che non mi spiego, e ci ho fatto caso solo dopo, mi ha impostato un profilo SOS 12db? Perchè è salito così il margine...
