Ciao a tutti, da un paio di giorni ho problemi in upload ho notato degli errori crc a cosa sono dovuti in questo caso? inoltre ho notato che l'SNR in upload cambia continuamente valore è normale? Posso fare qualcosa ? inoltre vorrei sapere se è possibile richiedere a tiscali la sostituzione dello Zyxel VMG8825-T50 visto che il wifi 5ghz salta continuamente e soprattutto online lagga spesso ? grazie
xDSLFwVersion: FwVer:5.12.22.0_B_A60901 HwVer:T14.F7_0.0
Line State: Up
Modulation: ITU G.993.2(VDSL2), G.998.4(G.I
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 16512
shineGINPdownstream: 530
shineGINPupstream: 590
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end interleaved channel bit rate: 107386 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 0 kbps
far-end fast channel bit rate: 15025 kbps
near-end FEC error fast: 0
near-end FEC error interleaved: 15940
near-end CRC error fast: 0
near-end CRC error interleaved: 15
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 1253046
far-end FEC error interleaved: 0
far-end CRC error fast: 2456
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
DSL uptime :2 days, 17:52, 11 secs
DSL activetime :0 min, 17 secs
Downstream:
relative capacity occupation: 100%
noise margin downstream: 6.0 dB
output power upstream: -21.2 dbm
attenuation downstream: 5.3 dB
Upstream:
noise margin upstream: 10.6 dB
output power downstream: 14.5 dbm
attenuation upstream: 0.0 dB
Bit table:
carrier load: number of bits per tone
tone 0- 31: 00 00 00 03 56 67 87 78 88 88 88 88 88 89 88 99
tone 32- 63: 90 00 00 22 20 22 33 34 44 44 45 55 56 65 66 67
tone 64- 95: 77 77 77 77 77 77 77 77 77 77 77 76 77 76 76 66
tone 96-127: 66 66 66 66 66 66 56 66 55 55 55 55 55 54 54 44
tone 128-159: 45 44 44 44 43 44 44 44 43 34 44 44 44 45 45 55
tone 160-191: 55 55 66 55 66 66 77 66 77 77 77 77 77 78 99 aa
tone 192-223: bb bc cc cc cd dd dd dd dd dd dd dd dd dd dd dd
tone 224-255: dd dd dd dd dd dd dd dd dd dd dd cd dd dd dd dd
