matteocontrini LucaTheHacker Non proibiscono video in autoplay, a quanto ricordi, semplicemente non puoi usarli fare live. "Use of the Services for serving video [...] is prohibited" LucaTheHacker Penso che il transcoding di un video 4k@160mbps potrebbe essere problematico per un server senza GPU, però boh. Non ho intenzione di farlo sul server infatti... 🙂 D'accordo sul resto.
LucaTheHacker matteocontrini "Use of the Services for serving video [...] is prohibited" riga/link? matteocontrini Non ho intenzione di farlo sul server infatti... Sul client? Te lo bypassano Su CF? Non dovevi lasciarli?
rieges LucaTheHacker riga/link? https://www.cloudflare.com/it-it/terms/ 2.8 Limitation on Serving Non-HTML Content The Services are offered primarily as a platform to cache and serve web pages and websites. Unless explicitly included as part of a Paid Service purchased by you, you agree to use the Services solely for the purpose of (i) serving web pages as viewed through a web browser or other functionally equivalent applications, including rendering Hypertext Markup Language (HTML) or other functional equivalents, and (ii) serving web APIs subject to the restrictions set forth in this Section 2.8. Use of the Services for serving video or a disproportionate percentage of pictures, audio files, or other non-HTML content is prohibited, unless purchased separately as part of a Paid Service or expressly allowed under our Supplemental Terms for a specific Service. If we determine you have breached this Section 2.8, we may immediately suspend or restrict your use of the Services, or limit End User access to certain of your resources through the Services. *Grassetto mio.
handymenny LucaTheHacker Sul client? Te lo bypassano Nessuno ti vieta di controllare il flusso video a posteriori, che poi forse basta settare una dimensione massima ragionevole. rieges Tra l'altro, da quello che ho visto, quando ti bannano in base a quella clausola lo fanno anche senza preavviso Comunque anche io penso sia meglio consentire solo video muti
Veehxia Ottima idea ma io proporrei di farlo esternamente, invece che integrati nel messaggio come le immagini. Una scritta verde, come i link, con scritto VIDEO che clickandola fa aprire il video in una nuova scheda per me sarebbe l'ideale. Oppure aggiungere una funzione spoiler e metterci i video all'interno.
DrGix Saremo inondati di videobestemmie in 4k ma i video (magari anche youtube/vimeo/etx embed) potrebbero essere utili in molti casi. Si può sempre fare una prova per qualche giorno e vedere come va 😁
spnick LucaTheHacker secondo me nelle discussioni relative a quell’operatore, i moderatori dovranno controllare bene i video 😂
