Alessandro86
TRACEROUTE:
traceroute to 185.208.44.192 (185.208.44.192), 15 hops max, 60 byte packets
1 Blizzard Blizzard 0.318 ms 0.314 ms 0.313 ms
2 * * *
3 Blizzard Blizzard 0.995 ms 0.995 ms 0.996 ms
4 137.221.66.46 (137.221.66.46) 0.951 ms 0.965 ms 0.969 ms
5 137.221.78.68 (137.221.78.68) 517.853 ms 517.888 ms 517.896 ms
6 * * *
7 137.221.65.92 (137.221.65.92) 22.676 ms 22.687 ms 22.687 ms
8 137.221.65.34 (137.221.65.34) 22.537 ms 22.552 ms 22.551 ms
9 137.221.65.61 (137.221.65.61) 22.526 ms 22.509 ms 22.508 ms
10 137.221.82.32 (137.221.82.32) 22.747 ms 22.565 ms 22.590 ms
11 spadhausen.mix-it.net (217.29.67.36) 25.734 ms 25.767 ms 25.826 ms
12 * * *
13 * * *
14 * * *
15 * * *
19/02/2021 12:30:55 UTC
PING:
PING 185.208.44.192 (185.208.44.192) 56(84) bytes of data.
--- 185.208.44.192 ping statistics ---
4 packets transmitted, 0 received, 100% packet loss, time 3007ms
MTR:
Start: Fri Feb 19 12:30:55 2021 Blizzard 1.|-- Blizzard 0.0% 10 0.3 0.3 0.2 0.6 0.0
2.|-- 37.244.24.131 30.0% 10 302.1 296.4 276.4 315.4 12.6
3.|-- Blizzard 0.0% 10 0.8 0.7 0.6 0.8 0.0
4.|-- 137.221.66.46 0.0% 10 0.6 0.5 0.3 0.6 0.0
5.|-- 137.221.78.68 0.0% 10 1380. 637.5 34.7 1380. 464.9
6.|-- ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
7.|-- 137.221.65.92 0.0% 10 22.5 30.3 22.3 73.2 17.5
8.|-- 137.221.65.34 0.0% 10 22.6 66.0 22.4 228.9 67.0
9.|-- 137.221.65.61 0.0% 10 22.6 26.0 22.4 51.0 8.9
10.|-- 137.221.82.32 0.0% 10 22.5 24.7 22.5 35.1 4.3
11.|-- spadhausen.mix-it.net 0.0% 10 25.9 25.8 25.7 25.9 0.0
12.|-- ??? 100.0 10 0.0 0.0 0.0 0.0 0.0
Filippo94
Esecuzione di Ping 1.1.1.1 con 32 byte di dati:
Risposta da 1.1.1.1: byte=32 durata=27ms TTL=59
Risposta da 1.1.1.1: byte=32 durata=26ms TTL=59
Risposta da 1.1.1.1: byte=32 durata=25ms TTL=59
Statistiche Ping per 1.1.1.1:
Pacchetti: Trasmessi = 4, Ricevuti = 4,
Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
Minimo = 25ms, Massimo = 27ms, Medio = 26ms
Esecuzione di Ping 8.8.8.8 con 32 byte di dati:
Risposta da 8.8.8.8: byte=32 durata=27ms TTL=119
Risposta da 8.8.8.8: byte=32 durata=26ms TTL=119
Risposta da 8.8.8.8: byte=32 durata=29ms TTL=119
Statistiche Ping per 8.8.8.8:
Minimo = 26ms, Massimo = 29ms, Medio = 27ms
Traccia instradamento verso dns.google [8.8.8.8]
su un massimo di 30 punti di passaggio:
1 1 ms 1 ms <1 ms fritz.box [192.168.188.1]
2 17 ms 17 ms 15 ms 100.72.31.254
3 17 ms 17 ms 15 ms 100.127.254.37
4 17 ms 16 ms 17 ms 100.127.254.25
5 21 ms 20 ms 22 ms google.mix-it.net [217.29.66.96]
6 24 ms 21 ms 20 ms 108.170.245.65
7 20 ms 20 ms 20 ms 142.250.211.21
8 27 ms 27 ms 27 ms dns.google [8.8.8.8]
Traccia completata.
Traccia instradamento verso one.one.one.one [1.1.1.1]
1 1 ms 1 ms 1 ms fritz.box [192.168.188.1]
2 16 ms 15 ms 16 ms 100.72.31.254
3 17 ms 17 ms 17 ms 100.127.254.37
5 25 ms 24 ms 39 ms cloudflare-nap.namex.it [193.201.28.33]
6 25 ms 26 ms 27 ms one.one.one.one [1.1.1.1]
Traccia completata.
Fatemi sapere. Io sono di Alessandria, sono curioso anche io di sapere come gira.
Vi dico già però che al gigabit non ci sono ancora mai arrivato, oscillo tra i 600 ed 800. E' normale? ho un fritz 7530 con firmware 7.21
