Aggiornamento: da LuCI ho cambiato l'impostazione del packet steering da "Enabled" a "Enabled (all CPUs)" e ora la situazione pare essere migliorata
Speedtest by Ookla
Server: CDA Net - Barrafranca (id: 55923)
ISP: Aruba Broadband
Idle Latency: 25.89 ms (jitter: 0.19ms, low: 25.63ms, high: 26.05ms)
Download: 1793.01 Mbps (data used: 2.2 GB)
52.19 ms (jitter: 34.24ms, low: 24.69ms, high: 421.16ms)
Upload: 1021.98 Mbps (data used: 1.1 GB)
51.12 ms (jitter: 4.98ms, low: 25.63ms, high: 116.74ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/b90440cf-a1d6-4eec-86d6-f1f21d31eb32
Speedtest by Ookla
Server: Fastweb SpA - Milan (id: 7839)
Idle Latency: 24.46 ms (jitter: 0.09ms, low: 24.41ms, high: 24.54ms)
Download: 1591.10 Mbps (data used: 1.7 GB)
56.29 ms (jitter: 36.74ms, low: 23.42ms, high: 545.98ms)
Upload: 1029.64 Mbps (data used: 1.2 GB)
53.47 ms (jitter: 5.10ms, low: 24.22ms, high: 111.35ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/a9e3ca41-4048-4484-b4cf-02d45b0e5163
Speedtest by Ookla
Idle Latency: 24.46 ms (jitter: 0.20ms, low: 24.36ms, high: 24.76ms)
Download: 1574.26 Mbps (data used: 1.9 GB)
84.19 ms (jitter: 43.88ms, low: 23.67ms, high: 550.37ms)
Upload: 1031.34 Mbps (data used: 1.2 GB)
48.38 ms (jitter: 4.71ms, low: 24.39ms, high: 106.66ms)
Packet Loss: 0.5%
Result URL: https://www.speedtest.net/result/c/84e81f8e-9acb-4150-b4aa-f58696709781
Speedtest by Ookla
Server: TILab - Naples (id: 45277)
Idle Latency: 38.44 ms (jitter: 0.05ms, low: 38.37ms, high: 38.52ms)
Download: 1364.22 Mbps (data used: 1.7 GB)
35.30 ms (jitter: 5.92ms, low: 33.21ms, high: 316.89ms)
Upload: 1027.35 Mbps (data used: 1.3 GB)
83.77 ms (jitter: 15.59ms, low: 35.04ms, high: 136.61ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/e7df9c93-21ca-4a15-94aa-29c277d11ac6
Quest'ultimo test con AdGuard di nuovo disattivato:
Speedtest by Ookla
Idle Latency: 24.01 ms (jitter: 0.24ms, low: 23.92ms, high: 24.36ms)
Download: 1264.61 Mbps (data used: 1.3 GB)
58.76 ms (jitter: 36.74ms, low: 23.32ms, high: 484.37ms)
Upload: 1031.48 Mbps (data used: 1.2 GB)
67.81 ms (jitter: 8.26ms, low: 24.07ms, high: 112.05ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/1e91b57d-87f4-48b6-bd60-c208871823ac
