Magnus471
Nessun problema ci mancherebbe, chiedevo solo per capire meglio.
Intanto ho fatto un pò di test con la Marvell. anche questa eccellente, con l'unica pecca che la velocità di picco arriva a circa 847MB\s (negli speedtest si traduce a 6.5Gbps), sicuramente a causa di qualche sorta di limitazione nello slot a cui l'ho dovuta relegare.
A parte questo ottima:
C:\Users\User>speedtest -s68988
Speedtest by Ookla
Server: Mynet - Milano (id: 68988)
ISP: Dimensione
Idle Latency: 7.98 ms (jitter: 0.09ms, low: 7.96ms, high: 8.33ms)
Download: 6539.87 Mbps (data used: 7.5 GB)
12.08 ms (jitter: 7.11ms, low: 7.53ms, high: 281.50ms)
Upload: 2032.91 Mbps (data used: 2.8 GB)
7.53 ms (jitter: 0.58ms, low: 6.83ms, high: 11.32ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/53e46db0-ea63-4519-b651-68cd8ee7785c
C:\Users\User>speedtest -s50954
Speedtest by Ookla
Server: Sky Wifi - Milano (id: 50954)
ISP: Dimensione
Idle Latency: 5.79 ms (jitter: 0.31ms, low: 5.55ms, high: 5.97ms)
Download: 6504.31 Mbps (data used: 7.8 GB)
9.20 ms (jitter: 0.68ms, low: 5.01ms, high: 22.29ms)
Upload: 2004.42 Mbps (data used: 1.7 GB)
7.48 ms (jitter: 0.43ms, low: 6.93ms, high: 12.51ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/7fa697c1-a942-4059-b2db-871811ff081e
C:\Users\User>speedtest -s38731
Speedtest by Ookla
Server: Fiberwide S.p.A. - Milan (id: 38731)
ISP: Dimensione
Idle Latency: 6.46 ms (jitter: 0.05ms, low: 6.42ms, high: 6.54ms)
Download: 6505.95 Mbps (data used: 7.3 GB)
9.97 ms (jitter: 4.32ms, low: 5.74ms, high: 308.88ms)
Upload: 2047.35 Mbps (data used: 2.5 GB)
7.37 ms (jitter: 0.42ms, low: 6.96ms, high: 14.62ms)
Packet Loss: 0.7%
Result URL: https://www.speedtest.net/result/c/a12d37b0-57b2-42a0-9b69-68fcdc888d73
C:\Users\User>speedtest -s27363
Speedtest by Ookla
Server: Wind Tre - Milano (id: 27363)
ISP: Dimensione
Idle Latency: 16.50 ms (jitter: 0.04ms, low: 16.47ms, high: 16.60ms)
Download: 6515.48 Mbps (data used: 7.6 GB)
12.34 ms (jitter: 0.70ms, low: 8.51ms, high: 29.80ms)
Upload: 2103.71 Mbps (data used: 1.6 GB)
8.79 ms (jitter: 0.73ms, low: 8.12ms, high: 15.36ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/acd3c785-428a-4ef3-ad96-3f42bfc322ce
C:\Users\User>speedtest -s42070
Speedtest by Ookla
Server: PVDataNet - Milano (id: 42070)
ISP: Dimensione
Idle Latency: 6.82 ms (jitter: 0.23ms, low: 6.69ms, high: 7.11ms)
Download: 6514.64 Mbps (data used: 7.2 GB)
10.86 ms (jitter: 0.59ms, low: 6.89ms, high: 17.96ms)
Upload: 2004.54 Mbps (data used: 2.1 GB)
8.18 ms (jitter: 0.44ms, low: 7.72ms, high: 15.01ms)
Packet Loss: Not available.
Result URL: https://www.speedtest.net/result/c/5a79d953-bba3-4821-bddf-3b0e0816d170
Un paio di speedterst fuori Italia al volo:
C:\Users\User>speedtest -s59135
Speedtest by Ookla
Server: Grain Connect - Manchester (id: 59135)
ISP: Dimensione
Idle Latency: 35.51 ms (jitter: 0.08ms, low: 35.47ms, high: 35.70ms)
Download: 5769.98 Mbps (data used: 10.0 GB)
36.14 ms (jitter: 0.22ms, low: 35.73ms, high: 40.41ms)
Upload: 2068.77 Mbps (data used: 3.0 GB)
36.27 ms (jitter: 1.53ms, low: 35.33ms, high: 43.76ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/c5e3f4e6-a794-4e87-be17-f8c242cb28e7
C:\Users\User>speedtest -s11769
Speedtest by Ookla
Server: Vialis - Strasbourg (id: 11769)
ISP: Dimensione
Idle Latency: 32.17 ms (jitter: 0.14ms, low: 31.99ms, high: 32.39ms)
Download: 6172.92 Mbps (data used: 10.4 GB)
30.48 ms (jitter: 0.43ms, low: 29.97ms, high: 46.38ms)
Upload: 2009.84 Mbps (data used: 2.9 GB)
28.09 ms (jitter: 1.54ms, low: 27.02ms, high: 35.87ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/bba7e8cf-87ed-4e1e-b5ad-a76a6aaedf99
Uno screenshot a dimostrazione del "blocco" sulla velocità che non supera quella soglia:
Singola sessione TCP eccezionale, salvo il solito blocco intorno agli 850MB\s:
