Ciao a tutti, su linea tim ftth tim 1000/300Mb/s con modem router a noleggio TIM HUB+, da qualche settimana ,si verificano frequenti disconnessioni sulla parte internet che obbligano al riavvio di quest'ultimo per il ripristino del servizio.
Questo è quanto rilevato sui log del router al momento della caduta di connessione:
Sun Dec 22 21:06:32 2024 kern.crit kernel: [459682.414003] eth4 (Int switch port: 0) (Logical Port: 0) (phyId: 6) Link DOWN.
Sun Dec 22 21:06:32 2024 daemon.notice wansensing: (L3UpSense) runs L3UpMain.check(SFP,network_device_eth4_down)
Sun Dec 22 21:06:32 2024 kern.info kernel: [459682.419405] br-lan: port 8(waneth4) entered disabled state
Sun Dec 22 21:06:32 2024 daemon.notice netifd: Network device 'eth4' link is down
Sun Dec 22 21:06:32 2024 daemon.notice netifd: Interface 'sfp' has link connectivity loss
Sun Dec 22 21:06:32 2024 daemon.notice netifd: 8021q 'waneth4' link is down
Sun Dec 22 21:06:32 2024 daemon.notice netifd: Interface 'wan' has link connectivity loss
Sun Dec 22 21:06:32 2024 daemon.notice wansensing: WAN Sensing L3 Up Checking
Sun Dec 22 21:06:32 2024 daemon.notice netifd: 8021q 'iptveth4' link is down
Sun Dec 22 21:06:33 2024 daemon.info pppd[907]: Terminating on signal 15
Sun Dec 22 21:06:33 2024 daemon.notice pppd[907]: Connection state changed to disconnecting (phase 9)
Sun Dec 22 21:06:33 2024 daemon.info pppd[907]: Connect time 5055.4 minutes.
Sun Dec 22 21:06:33 2024 daemon.info pppd[907]: Sent 2090602077 bytes, received 3614188369 bytes.
Sun Dec 22 21:06:33 2024 daemon.notice netifd: Network device 'pppoe-wan' link is down
Sun Dec 22 21:06:33 2024 daemon.notice netifd: Network alias 'pppoe-wan' link is down
Sun Dec 22 21:06:33 2024 daemon.notice netifd: Interface 'wan6' has link connectivity loss
.....cut firewall event....
per poi andare in loop su questa serie di errori, fino al restart dell'apparato:
Sun Dec 22 21:06:51 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:06:56 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:06:56 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:01 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:02 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:07 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:07 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:12 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:13 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:16 2024 daemon.info cwmpd[10993]: PROT_TRACE: Events are waiting, need to contact ACS
Sun Dec 22 21:07:16 2024 daemon.info cwmpd[10993]: CONNECTION: Connecting to server retry 3.
Sun Dec 22 21:07:16 2024 daemon.err cwmpd[10993]: APP_TRACE: bad address 'trm.regman-tl.interbusiness.it'
Sun Dec 22 21:07:16 2024 daemon.crit cwmpd[10993]: CONNECTION: Failed to resolve.
Sun Dec 22 21:07:16 2024 daemon.info cwmpd[10993]: PROT_TRACE: Nb of retries 4
Sun Dec 22 21:07:16 2024 daemon.info cwmpd[10993]: PROT_TRACE: Min retry wait time 40
Sun Dec 22 21:07:16 2024 daemon.info cwmpd[10993]: PROT_TRACE: Max retry wait time 80
Sun Dec 22 21:07:16 2024 daemon.info cwmpd[10993]: PROT_TRACE: Effective retry wait time 78
Sun Dec 22 21:07:16 2024 daemon.info cwmpd[10993]: PROT_TRACE: LAST STATE: <Idle>
Sun Dec 22 21:07:18 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:18 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:23 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:24 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:29 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:29 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:34 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:35 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:40 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:40 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:45 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:46 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:51 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:51 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:07:56 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:07:58 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:03 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:03 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:08 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:09 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:14 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:14 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:19 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:20 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:25 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:25 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:30 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:31 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:33 2024 daemon.info cwmpd[10993]: PROT_TRACE: Events are waiting, need to contact ACS
Sun Dec 22 21:08:33 2024 daemon.info cwmpd[10993]: CONNECTION: Connecting to server retry 4.
Sun Dec 22 21:08:33 2024 daemon.err cwmpd[10993]: APP_TRACE: bad address 'trm.regman-tl.interbusiness.it'
Sun Dec 22 21:08:33 2024 daemon.crit cwmpd[10993]: CONNECTION: Failed to resolve.
Sun Dec 22 21:08:33 2024 daemon.info cwmpd[10993]: PROT_TRACE: Nb of retries 5
Sun Dec 22 21:08:33 2024 daemon.info cwmpd[10993]: PROT_TRACE: Min retry wait time 80
Sun Dec 22 21:08:33 2024 daemon.info cwmpd[10993]: PROT_TRACE: Max retry wait time 160
Sun Dec 22 21:08:33 2024 daemon.info cwmpd[10993]: PROT_TRACE: Effective retry wait time 115
Sun Dec 22 21:08:33 2024 daemon.info cwmpd[10993]: PROT_TRACE: LAST STATE: <Idle>
Sun Dec 22 21:08:36 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:36 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:41 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:42 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:47 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:47 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:52 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:53 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:08:58 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:08:58 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:03 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:04 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:09 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:09 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:14 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:15 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:20 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:20 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:25 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:26 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:31 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:31 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:36 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:37 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:42 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:42 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:47 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:48 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:53 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:53 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:09:58 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:09:59 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:10:04 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:10:04 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:10:09 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Sun Dec 22 21:10:10 2024 daemon.notice wansensing: WAN Sensing Mobile: 1
Sun Dec 22 21:10:15 2024 daemon.notice wansensing: (L2Sense) runs L2Main.check(timeout)
Secondo voi è più probabile un guasto all'apparato oppure alla linea? Da pannello amministrativo del router, l'accesso ad internet per la parte PPP resta sempre arancione con connessione in corso.
