Buonasera,
due giorni fa mi hanno attivato la fttc 200/20, ho atteso un po' che si stabilizzasse la linea ed eseguito uno speedtest:
ho provato sia da cavo che da wifi ma da sempre questo risultato. la distanza dal cabinet comunque è di 150 metri, quindi dovrebbe andare sui 120-130
pubblico anche i dati dal modem:
xDSLFwVersion: FwVer:5.12.12.0_B_A60901 HwVer:T14.F7_0.0
Line State: Up
Modulation: ITU G.993.2(VDSL2), G.998.4(G.I
Annex Mode: ANNEX_B
INP downstream: 0
INP upstream: 16512
shineGINPdownstream: 620
shineGINPupstream: 590
reinGINPdownstream: 0
reinGINPupstream: 0
TPSTC type: 64/65B PTM TC
near-end interleaved channel bit rate: 95336 kbps
near-end fast channel bit rate: 0 kbps
far-end interleaved channel bit rate: 0 kbps
far-end fast channel bit rate: 21599 kbps
near-end FEC error fast: 0
near-end FEC error interleaved: 309878149
near-end CRC error fast: 0
near-end CRC error interleaved: 0
near-end HEC error fast: 0
near-end HEC error interleaved: 0
far-end FEC error fast: 672882
far-end FEC error interleaved: 0
far-end CRC error fast: 0
far-end CRC error interleaved: 0
far-end HEC error fast: 0
far-end HEC error interleaved: 0
DSL uptime :1 day, 5:25, 40 secs
DSL activetime :0 min, 17 secs
Downstream:
relative capacity occupation: 100%
noise margin downstream: 6.4 dB
output power upstream: -14.0 dbm
attenuation downstream: 8.4 dB
Upstream:
noise margin upstream: 6.4 dB
output power downstream: 10.9 dbm
attenuation upstream: 0.1 dB
Bit table:
carrier load: number of bits per tone
tone 0- 31: 00 00 00 04 67 77 77 77 88 88 88 88 78 88 88 98
tone 32- 63: 8a ab bb bb bb bc cc cc cc cc cc cc cc cc cc cb
tone 64- 95: cb cc bc bb bb bb bb bb bb bb bb bb bb ab bb ab
tone 96-127: bb ab ba bb ba bb ba ab ba ab aa aa a9 aa a9 a9
tone 128-159: aa a9 9a 99 aa aa aa a9 aa aa 99 a9 99 99 99 9a
tone 160-191: 99 99 99 9a 99 99 9a aa a9 99 99 99 99 99 a9 9a
tone 192-223: a9 a9 99 99 99 99 99 9a a9 99 99 99 99 99 99 99
tone 224-255: 99 99 99 99 99 99 99 99 99 a9 99 99 99 99 99 99
E' un problema dovuto alla linea di casa o hanno sbagliato ad attivarmi il profilo? 🤔
