Speedtest by Ookla
Server: Dimensione - Milan (id: 9329)
ISP: Dimensione
Idle Latency: 17.34 ms (jitter: 0.11ms, low: 17.17ms, high: 17.45ms)
Download: 2166.69 Mbps (data used: 2.4 GB)
21.44 ms (jitter: 14.39ms, low: 15.26ms, high: 286.17ms)
Upload: 288.06 Mbps (data used: 508.1 MB)
16.23 ms (jitter: 0.63ms, low: 15.64ms, high: 30.85ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/a26f388e-ece4-459e-8629-62e87739407d
Ho provato anche Eolo e Vodafone
Speedtest by Ookla
Server: EOLO - Milan (id: 11427)
ISP: Dimensione
Idle Latency: 16.92 ms (jitter: 0.36ms, low: 16.52ms, high: 17.19ms)
Download: 2295.49 Mbps (data used: 3.0 GB)
22.83 ms (jitter: 26.29ms, low: 15.51ms, high: 292.47ms)
Upload: 271.84 Mbps (data used: 419.9 MB)
17.67 ms (jitter: 0.65ms, low: 16.93ms, high: 32.41ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/d1cab083-deb0-47c6-8889-94ddc9d97067
Speedtest by Ookla
Server: Vodafone IT - Milan (id: 4302)
ISP: Dimensione
Idle Latency: 17.17 ms (jitter: 0.31ms, low: 17.05ms, high: 17.58ms)
Download: 2027.80 Mbps (data used: 2.7 GB)
100.01 ms (jitter: 59.67ms, low: 15.87ms, high: 736.70ms)
Upload: 297.22 Mbps (data used: 404.1 MB)
16.69 ms (jitter: 5.65ms, low: 15.89ms, high: 247.34ms)
Packet Loss: 2.7%
Result URL: https://www.speedtest.net/result/c/966611d2-bf1d-46af-bbbe-f95b3f132741
Il ping mi è passato da 8/9 verso milano a 17ms
Esecuzione di Ping 1.1.1.1 con 32 byte di dati:
Risposta da 1.1.1.1: byte=32 durata=17ms TTL=59
Risposta da 1.1.1.1: byte=32 durata=16ms TTL=59
Statistiche Ping per 1.1.1.1:
Pacchetti: Trasmessi = 4, Ricevuti = 4,
Persi = 0 (0% persi),
Tempo approssimativo percorsi andata/ritorno in millisecondi:
Minimo = 16ms, Massimo = 17ms, Medio = 16ms
Disastro
Edit: ho rimesso l'altro router e sono rimasto con questo ping ma che cazz, provo a riavviare l'ONT
Edit2: Ping tornato a 9 con l'altro router lo ZTE
sempre up castrato anche verso l'Italia ora
Speedtest by Ookla
ISP: Dimensione
Idle Latency: 9.16 ms (jitter: 0.26ms, low: 8.88ms, high: 9.44ms)
Download: 2275.61 Mbps (data used: 2.9 GB)
24.66 ms (jitter: 18.53ms, low: 17.48ms, high: 292.09ms)
Upload: 349.55 Mbps (data used: 489.3 MB)
13.30 ms (jitter: 0.54ms, low: 12.77ms, high: 21.84ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/068adcfa-fbe6-4d8c-bce3-34f6cd36866d
Con scheda settata a 1gbps - Upload pieno
Speedtest by Ookla
ISP: Dimensione
Idle Latency: 12.09 ms (jitter: 0.12ms, low: 11.93ms, high: 12.19ms)
Download: 920.96 Mbps (data used: 1.1 GB)
64.39 ms (jitter: 6.72ms, low: 11.96ms, high: 385.49ms)
Upload: 468.57 Mbps (data used: 460.3 MB)
25.03 ms (jitter: 0.98ms, low: 13.56ms, high: 28.48ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/a711b0e2-b67e-4f5d-895a-7711ce17465d
Ho riprovato anche lo zyxel ho controllato e il qos è disattivato ma niente, stessi risultati dello ZTE ma almeno il ping è rimato a 9 questa volta.
Speedtest by Ookla
ISP: Dimensione
Idle Latency: 12.72 ms (jitter: 0.12ms, low: 12.63ms, high: 12.93ms)
Download: 2233.02 Mbps (data used: 2.7 GB)
18.79 ms (jitter: 7.55ms, low: 12.33ms, high: 274.70ms)
Upload: 332.59 Mbps (data used: 446.7 MB)
12.02 ms (jitter: 0.48ms, low: 11.62ms, high: 19.18ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/a88a12e6-acf4-4dd5-8845-7797a4e9d7fe
