"Screen: P-OLED, 6.55 inches, 2400×1080 pixels, one billion shades 10 bit, 20:9 aspect ratio, 144 Hz refresh rate, HDR10+ support, 1100 nits peak brightness, built-in fingerprint sensor, Corning Gorilla Glass 5 protection
Processor: Qualcomm SM8350 Snapdragon 888+ 5G (5 nm), Octa-core (1×2.99 GHz Cortex-X1 & 3×2.42 GHz Cortex-A78 & 4×1.80 GHz Cortex-A55), Adreno 660 video chip
Memory: 8/128, 8/256, 12/256, 12/512 GB, type of RAM – LPDDR5, type of permanent memory – UFS 3.1, no support for memory cards
Battery: 4400 mAh, 68 W fast charging (50% in 10 minutes)
Main camera:
50 megapixels, f/1.8, 1/1.55″, 1.0µm, phase detection autofocus, optical stabilization
13 megapixel 120˚ wide-angle lens, f/2.2, 1.12µm, autofocus
2 megapixels, f/2.4 (depth sensor)
Video recording: 8K@30fps, 4K@30fps, 1080p@30/60/120fps, 720p@960fps, gyro-EIS
Front camera: 32 megapixels, f/2.5, 1/2.8″, 0.8µm, AF
Data transmission: 5G, tri-band Wi-Fi 802.11 a/b/g/n/ac/ax/6e, Bluetooth 5.2, NFC, GPS, A-GPS, GLONASS, BDS, Galileo, USB Type-C 3.1, ReadyFor PC connection mode
OS: Android 12
Dimensions and weight: 158.5 × 72.0 × 7.5 mm, 168 g"
