Romarioele Ciao, in vista delle imminente installazione linea FTTH a 2.5/500 mi servirebbe uno switch con almeno 2 poe, cosa mi consigliate? Budget limitato.
LSan83 Romarioele Per solo due porte ti conviene uno switch normale, una ciabatta e due iniettori poe esterni allo switch.
Romarioele Per quale motivo? Poi non capisco gli iniettori esterni... di switch 1Gb con poe c'è pieno.
Daniel_e88 Romarioele Ubiquiti: https://eu.store.ui.com/products/switch-enterprise-8-poe Intellinet: https://intellinetsolutions.com/products/intellinet-en-8-port-25g-ethernet-poe-switch-561938 Netgear: https://www.netgear.com/business/wired/switches/plus/ms108eup/ Mokerlink: https://www.mokerlink.com/index.php?route=product/product&product_id=408 e poi il più cheap 8 porte: https://it.aliexpress.com/item/1005003665400990.html?spm=a2g0o.productlist.main.1.1c9c7d3fBa9PWL&algo_pvid=c1067232-aad9-4149-a755-a9907c584cf1&algo_exp_id=c1067232-aad9-4149-a755-a9907c584cf1-0&pdp_ext_f=%7B%22sku_id%22%3A%2212000026711077423%22%7D&pdp_npi=3%40dis%21EUR%21146.68%21146.68%21%21%21%21%21%402100b78b16774041862955978d0714%2112000026711077423%21sea%21IT%21778412773&curPageLogUid=ZSkhKcugNh0e 5 porte: https://it.aliexpress.com/item/1005004077757150.html?spm=a2g0o.detail.0.0.194b3425erXvfl&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.291025.0&scm_id=1007.13339.291025.0&scm-url=1007.13339.291025.0&pvid=bd7def42-fd38-41cd-b68e-9bee3a734423&_t=gps-id%3ApcDetailBottomMoreThisSeller%2Cscm-url%3A1007.13339.291025.0%2Cpvid%3Abd7def42-fd38-41cd-b68e-9bee3a734423%2Ctpp_buckets%3A668%232846%238109%231935&pdp_ext_f=%7B%22sku_id%22%3A%2212000027965633514%22%2C%22sceneId%22%3A%223339%22%7D&pdp_npi=3%40dis%21EUR%2195.32%2195.32%21%21%21%21%21%40211b801a16774101370262326e6423%2112000027965633514%21rec%21IT%21&gatewayAdapt=glo2ita STH ne ha fatto una rece: https://www.youtube.com/watch?v=-1jt6U1IWAA&t=56s
LSan83 Romarioele Per quale motivo? Poi non capisco gli iniettori esterni... di switch 1Gb con poe c'è pieno. Ma lui vuole uno switch con le porte 2,5 gigabit e POE.... Sono pochi modelli e decisamente cari. Già lo switch 2,5G senza POE costa parecchio, per solo due porte gli conviene l'iniettore esterno.
Daniel_e88 LSan83 per solo due porte gli conviene l'iniettore esterno. un injector 2.5 costa da solo sui 50 euro, 100 euro toali, conviene uno switch. https://www.broadbandbuyer.com/store/poe-switches/poe-injectors/?t=6226&sort=1
testone Conviene uno switch poe Gigabit ed un altro senza poe da 2.5. Probabilmente le periferiche alimentate poe magari lavorano non a 2.5 ma ad 1gigabit.
LSan83 testone Probabilmente le periferiche alimentate poe magari lavorano non a 2.5 ma ad 1gigabit. Gli AP Wifi6 hanno bisogno di porte 2,5G appena vai sopra ai modelli economici con antenne 2x2....
testone Se solo un AP wifi6 magari c'è una presa di corrente nei pressi così risparmi 😊. Gli switch 2.5 poe costano 200/250 euro, meglio un alimentatore
Romarioele I poe alimentano 2 videocamere, 100 mega bastano e avanzano. Era per non avere Ont+Router+Switch+Iniettori tutti alimentati oltre ad uno switch poe che mi alimenta altre 3 videocamere. Spendo meno a cambiare il mio NVR Dahua senza POE con uno con POE Ma ONT+ROUTER e uno Switch 2.5 rimangono. A sto punto quale Switch 2.5?
