ImACrab
le righe DA MODIFICARE
<Value Name="NGPON_PLOAM_PASSWD" Value="METTI IL GPON SERIAL VFS6"/>
<Value Name="GPON_PLOAM_PASSWD" Value="METTI LA TUA PLOAM"/>
<Value Name="MacAddr" Value="INSERIRE MAC ADDRESS"/>
Parte con info di default, eventualmente cambiati IP e User e PWD, parte da 192.168.100.1 user e pwd di default del Leox.
Ti elenco il contenuto del file che ti salverai come config.xml e carichi sul Leox come ripristino configurazione. E' il mio con serial e ploam da inserire
Config Name="ROOT">
<Dir Name="MIB_TABLE">
<Value Name="LAN_NEGOCIATE_CONFIG" Value="06"/>
<Value Name="PROVINCE_TRAP_PPPOE_TRAFFIC" Value="0"/>
<Value Name="PROVINCE_TR143_SPEED_UP" Value="0"/>
<Value Name="DEVICE_NAME" Value="LXT-010H-D"/>
<Value Name="RTK_DEVINFO_HWVER" Value=""/>
<Value Name="RTK_DEVINFO_SWVER" Value=""/>
<Value Name="RTK_DEVINFO_SPECVER" Value=""/>
<Value Name="RTK_DEVID_PRODUCTCLASS" Value=""/>
<Value Name="RTK_DEVID_OUI" Value=""/>
<Value Name="RTK_DEVID_MANUFACTURER" Value=""/>
<Value Name="NTP_EXT_ITF" Value="65535"/>
<Value Name="DHCP_PORT_FILTER" Value="0"/>
<Value Name="PON_CUSTOM_SDK" Value="0"/>
<Value Name="OMCI_LOGFILE_MASK" Value="0"/>
<Value Name="OMCI_TM_OPT" Value="2"/>
<Value Name="OMCC_VER" Value="134"/>
<Value Name="OMCI_SW_VER2" Value="V1R007C00S001"/>
<Value Name="OMCI_SW_VER1" Value="V1R007C00S001"/>
<Value Name="OMCI_OLT_MODE" Value="1"/>
<Value Name="VLAN_MANU_TAG_PRI" Value="255"/>
<Value Name="VLAN_MANU_TAG_VID" Value="65535"/>
<Value Name="VLAN_MANU_MODE" Value="0"/>
<Value Name="VLAN_CFG_TYPE" Value="0"/>
<Value Name="RTK_IGMP_TAGDECISION" Value="0"/>
<Value Name="RTK_IGMP_VIDTYPE" Value="0"/>
<Value Name="RTK_IGMP_DROPV1" Value="0"/>
<Value Name="RTK_IGMP_DBGEN" Value="0"/>
<Value Name="OMCI_VEIP_SLOT_ID" Value="255"/>
<Value Name="OMCI_FAKE_OK" Value="1"/>
<Value Name="OMCI_VENDOR_PRODUCT_CODE" Value="0"/>
<Value Name="OMCI_CUSTOM_ME" Value="851968"/>
<Value Name="OMCI_CUSTOM_MCAST" Value="0"/>
<Value Name="OMCI_CUSTOM_RDP" Value="0"/>
<Value Name="OMCI_CUSTOM_BDP" Value="10"/>
<Value Name="DUAL_MGMT_MODE" Value="0"/>
<Value Name="OMCI_PORT_TYPE" Value="1"/>
<Value Name="OMCI_LOGFILE" Value="0"/>
<Value Name="OMCI_DBGLVL" Value="0"/>
<Value Name="LOID_PASSWD_OLD" Value="user"/>
<Value Name="LOID_OLD" Value="user"/>
<Value Name="LOID_PASSWD" Value="user"/>
<Value Name="LOID" Value="user"/>
<Value Name="NETDEV_MTU" Value="1500"/>
<Value Name="MIB_WLAN_MAC_CTRL" Value="0"/>
<Value Name="MIB_ETH_MAC_CTRL" Value="0"/>
<Value Name="ADSLDBG" Value="0"/>
<Value Name="MAXLOGLEN" Value="16384"/>
<Value Name="SYSLOG" Value="0"/>
<Value Name="ADSL_HIGH_INP" Value="0"/>
<Value Name="DIRECT_BRIDGE_MODE" Value="1"/>
<Value Name="ADSL_TONE" Value="00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00"/>
<Value Name="SUSER_PASSWORD" Value="leolabs_7"/>
<Value Name="SUSER_NAME" Value="leox"/>
<Value Name="SYSLOG_DISPLAY_LEVEL" Value="0"/>
<Value Name="SYSLOG_LOG_LEVEL" Value="0"/>
<Value Name="UPNP_EXT_ITF" Value="255"/>
<Value Name="UPNP" Value="0"/>
<Value Name="BOOT_FILENAME" Value=""/>
<Value Name="POSIX_TZ_STRING" Value=""/>
<Value Name="TFTP_SERVER_ADDR" Value="tftp://0.0.0.0"/>
<Value Name="MULTI_LINGUAL_STATE" Value="en"/>
<Value Name="MP_FIN" Value="1"/>
<Value Name="SPC_IPTYPE" Value="0"/>
<Value Name="SPC_ENABLED" Value="0"/>
<Value Name="FW_GRADE" Value="0"/>
<Value Name="FW_ENABLE" Value="0"/>
<Value Name="MP_MODE" Value="4"/>
<Value Name="BR_STP_ENABLED" Value="0"/>
<Value Name="BR_AGEING_TIME" Value="7200"/>
<Value Name="VC_AUTOSEARCH" Value="0"/>
<Value Name="SNMP_SYS_NAME" Value="LXT-010H-D"/>
<Value Name="INIT_SCRIPT" Value="1"/>
<Value Name="INIT_LINE" Value="1"/>
<Value Name="DEVICE_TYPE" Value="0"/>
<Value Name="USER_PASSWORD" Value="user"/>
<Value Name="USER_NAME" Value="user"/>
<Value Name="ADSL_OLR" Value="3"/>
<Value Name="ADSL_MODE" Value="83"/>
<Value Name="DNS3" Value="0.0.0.0"/>
<Value Name="DNS2" Value="0.0.0.0"/>
<Value Name="DNS1" Value="0.0.0.0"/>
<Value Name="DNS_MODE" Value="0"/>
<Value Name="LAN_AUTOSEARCH" Value="0"/>
<Value Name="LAN_RIP" Value="0"/>
<Value Name="LAN_SUBNET2" Value="255.255.255.0"/>
<Value Name="LAN_IP_ADDR2" Value="192.168.1.1"/>
<Value Name="LAN_ENABLE_IP2" Value="0"/>
<Value Name="LAN_SUBNET" Value="255.255.255.0"/>
<Value Name="LAN_IP_ADDR" Value="192.168.100.1"/>
<Value Name="WAN_MODE" Value="7"/>
</Dir>
<Dir Name="DHCP_RESERVED_IPADDR_TBL"> </Dir>
<Dir Name="RIP_TBL"> </Dir>
<Dir Name="PPPOE_SESSION_TBL"> </Dir>
<Dir Name="AUTO_PVC_SEARCH_TBL">
<!-- index=0 -->
<Value Name="VCI" Value="35"/>
<Value Name="VPI" Value="0"/>
</Dir>
<!-- index=1 -->
<Value Name="VPI" Value="8"/>
</Dir>
<!-- index=2 -->
<Value Name="VCI" Value="43"/>
</Dir>
<!-- index=3 -->
<Value Name="VCI" Value="51"/>
</Dir>
<!-- index=4 -->
<Value Name="VCI" Value="59"/>
</Dir>
<!-- index=5 -->
</Dir>
<!-- index=6 -->
</Dir>
<!-- index=7 -->
</Dir>
<Dir Name="MAC_BASE_DHCP_TBL"> </Dir>
<Dir Name="SW_PORT_TBL">
<!-- index=0 -->
<Value Name="Enable" Value="1"/>
<Value Name="Speed" Value="3"/>
<Value Name="Duplex" Value="2"/>
<Value Name="VID" Value="0"/>
<Value Name="VLAN on LAN InterfaceGroup" Value="0"/>
<Value Name="VLAN on LAN Enabled" Value="0"/>
<Value Name="LinkMode" Value="4"/>
<Value Name="PVID" Value="0"/>
<Value Name="InterfaceGroup" Value="0"/>
<Value Name="PVCInterface" Value="65535"/>
</Dir>
<!-- index=1 -->
<Value Name="PVID" Value="1"/>
</Dir>
<Dir Name="ATM_VC_TBL">
<!-- index=0 -->
<Value Name="applicationtype" Value="2"/>
<Value Name="WanName" Value=""/>
<Value Name="cpeIpIndex" Value="0"/>
<Value Name="cpePppIfIndex" Value="0"/>
<Value Name="mVid" Value="0"/>
<Value Name="itfGroupNum" Value="0"/>
<Value Name="itfGroup" Value="0"/>
<Value Name="vpass" Value="0"/>
<Value Name="vprio" Value="0"/>
<Value Name="vid" Value="0"/>
<Value Name="vlan" Value="0"/>
<Value Name="DNSV4IPAddr2" Value="0.0.0.0"/>
<Value Name="DNSV4IPAddr1" Value="0.0.0.0"/>
<Value Name="DNSMode" Value="0"/>
<Value Name="Ipunnum" Value="0"/>
<Value Name="SubnetMask" Value="0.0.0.0"/>
<Value Name="ChannelStatus" Value="1"/>
<Value Name="MTU" Value="1500"/>
<Value Name="DefaultGW" Value="0"/>
<Value Name="RemoteIPAddr" Value="0.0.0.0"/>
<Value Name="LocalIPAddr" Value="0.0.0.0"/>
<Value Name="RIP" Value="0"/>
<Value Name="ChannelAddrType" Value="0"/>
<Value Name="enableMLD" Value="0"/>
<Value Name="enableIGMP" Value="0"/>
<Value Name="pppLcpEchoRetry" Value="0"/>
<Value Name="pppLcpEcho" Value="0"/>
<Value Name="pppIdleTime" Value="0"/>
<Value Name="pppConnectType" Value="0"/>
<Value Name="pppServiceName" Value=""/>
<Value Name="pppACName" Value=""/>
<Value Name="pppAuth" Value="0"/>
<Value Name="pppPasswd" Value=""/>
<Value Name="pppUser" Value=""/>
<Value Name="BridgeType" Value="0"/>
<Value Name="ChannelMode" Value="0"/>
<Value Name="NAPT" Value="1"/>
<Value Name="Encap" Value="1"/>
<Value Name="CDVT" Value="0"/>
<Value Name="MBS" Value="0"/>
<Value Name="SCR" Value="0"/>
<Value Name="PCR" Value="6000"/>
<Value Name="QoS" Value="0"/>
<Value Name="VPI" Value="5"/>
<Value Name="ifIndex" Value="130816"/>
</Dir>
</Config>
