edofullo Il carico sembra distribuirsi in maniera abbastanza equa fra tutti i 12 thread.
[cancellato] La scheda di rete è l'unica scheda PCI e sta nel primo slot... per precisione, è questa: https://www.amazon.it/gp/product/B079QVHHH1/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1
E' una 1x, ma stando a quanto detto li, ed alle recensioni per quel modello, sembra essere in grado di gestire 1Gb su entrambe le porte.
I log di sistema hanno una sfilza di errori, però:
Mon Dec 13 00:50:03 2021 kern.warn kernel: [ 416.269225] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:03 2021 kern.warn kernel: [ 416.302671] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:04 2021 kern.warn kernel: [ 417.270038] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:04 2021 kern.warn kernel: [ 417.270668] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:04 2021 kern.warn kernel: [ 417.303640] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:05 2021 kern.warn kernel: [ 418.271171] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:05 2021 kern.warn kernel: [ 418.271824] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:05 2021 kern.warn kernel: [ 418.304711] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:06 2021 kern.warn kernel: [ 419.272247] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:06 2021 kern.warn kernel: [ 419.272424] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:06 2021 kern.warn kernel: [ 419.305338] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:07 2021 kern.warn kernel: [ 420.273412] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:07 2021 kern.warn kernel: [ 420.273616] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:07 2021 kern.warn kernel: [ 420.306426] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:08 2021 kern.warn kernel: [ 421.274669] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:08 2021 kern.warn kernel: [ 421.274899] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:08 2021 kern.warn kernel: [ 421.306456] [nat46] Could not translate v4->v6
Mon Dec 13 00:50:09 2021 kern.warn kernel: [ 422.275848] [nat46] Could not translate v4->v6
Non ci sono riferimenti a questo errore da nessuna parte se non su github, nel file sorgente da cui proviene:
https://github.com/ayourtch/nat46/blob/master/nat46/modules/nat46-core.c
if(!pairs_xlate_v4_to_v6_outer(nat46, hdr4, having_l4 ? &sport : NULL, having_l4 ? &dport : NULL, v6saddr, v6daddr)) {
nat46debug(0, "[nat46] Could not translate v4->v6");
goto done;
