DeVisu i loro server di Perugia e Rieti
Quei due server sono chiaramente a Milano:
Server "Rieti", da Hetzner (Nurnberg):
edoardo@de01.e396.dn42:~$ traceroute 89.36.207.133
traceroute to 89.36.207.133 (89.36.207.133), 30 hops max, 60 byte packets
1 172.31.1.1 (172.31.1.1) 8.282 ms 8.090 ms 8.271 ms
2 14720.your-cloud.host (49.12.137.117) 0.322 ms 0.353 ms 0.342 ms
3 * * *
4 static.88-198-249-57.clients.your-server.de (88.198.249.57) 1.272 ms static.88-198-249-61.clients.your-server.de (88.198.249.61) 0.926 ms static.88-198-249-57.clients.your-server.de (88.198.249.57) 0.995 ms
5 core11.nbg1.hetzner.com (213.239.208.221) 0.739 ms 0.582 ms core11.nbg1.hetzner.com (85.10.250.209) 0.701 ms
6 core1.fra.hetzner.com (213.239.245.254) 3.679 ms 3.469 ms 3.448 ms
7 ae18.cr6-fra2.ip4.gtt.net (154.14.78.153) 3.754 ms 3.458 ms 3.701 ms
8 et-0-0-13.cr4-mil3.ip4.gtt.net (213.200.121.162) 19.263 ms 19.137 ms 19.059 ms
9 ip4.gtt.net (154.14.67.246) 18.704 ms 18.709 ms 18.655 ms
10 89.36.207.133 (89.36.207.133) 18.708 ms 18.484 ms 18.470 ms
Da TIM (Nord Italia):
[edoardo@edoardo-fedora ~]$ traceroute 89.36.207.133
1 _gateway (10.0.0.1) 0.112 ms 0.073 ms 0.261 ms
2 * * *
3 172.18.9.48 (172.18.9.48) 4.633 ms 4.621 ms 4.396 ms
4 172.18.8.222 (172.18.8.222) 8.019 ms 172.18.8.146 (172.18.8.146) 5.070 ms 172.18.8.222 (172.18.8.222) 5.523 ms
5 172.19.184.4 (172.19.184.4) 5.918 ms 5.907 ms 6.101 ms
6 172.19.177.28 (172.19.177.28) 9.166 ms 8.485 ms 13.268 ms
7 tecnotel.mix-it.net (217.29.66.209) 8.442 ms 8.581 ms 8.578 ms
8 89.36.207.133 (89.36.207.133) 9.100 ms 8.424 ms 8.459 ms
Per l'altro server la musica è la stessa:
[edoardo@edoardo-fedora ~]$ traceroute 89.36.207.131
traceroute to 89.36.207.131 (89.36.207.131), 30 hops max, 60 byte packets
1 _gateway (10.0.0.1) 0.092 ms 0.061 ms 0.252 ms
2 * * *
3 172.18.9.40 (172.18.9.40) 4.361 ms 172.18.9.48 (172.18.9.48) 4.147 ms 4.337 ms
4 172.18.8.222 (172.18.8.222) 6.010 ms 6.574 ms 172.18.8.146 (172.18.8.146) 5.584 ms
5 172.19.184.4 (172.19.184.4) 5.369 ms 5.564 ms 5.554 ms
6 172.19.177.28 (172.19.177.28) 8.334 ms 7.770 ms 8.162 ms
7 tecnotel.mix-it.net (217.29.66.209) 8.340 ms 8.741 ms 8.344 ms
8 89.36.207.131 (89.36.207.131) 8.530 ms 8.250 ms *
edoardo@de01.e396.dn42:~$ traceroute 89.36.207.131
1 172.31.1.1 (172.31.1.1) 4.838 ms 4.945 ms 4.913 ms
2 14720.your-cloud.host (49.12.137.117) 0.443 ms 0.434 ms 0.462 ms
3 * * *
4 static.88-198-249-61.clients.your-server.de (88.198.249.61) 1.197 ms static.88-198-249-57.clients.your-server.de (88.198.249.57) 1.116 ms 1.414 ms
5 core11.nbg1.hetzner.com (85.10.250.209) 1.658 ms core11.nbg1.hetzner.com (213.239.208.221) 0.679 ms core11.nbg1.hetzner.com (85.10.250.209) 1.636 ms
6 core1.fra.hetzner.com (213.239.245.250) 9.624 ms core1.fra.hetzner.com (213.239.245.254) 9.227 ms core1.fra.hetzner.com (213.239.245.250) 3.478 ms
7 ae18.cr6-fra2.ip4.gtt.net (154.14.78.153) 4.450 ms 4.407 ms 4.029 ms
8 et-0-0-13.cr4-mil3.ip4.gtt.net (213.200.121.162) 19.219 ms 19.086 ms 18.812 ms
9 ip4.gtt.net (154.14.67.246) 64.350 ms 62.005 ms 56.974 ms
10 89.36.207.131 (89.36.207.131) 18.754 ms 18.710 ms 18.698 ms
https://atlas.ripe.net/measurements/32174524/#map
A meno che non sia un proxy/relay ma la vedo difficile e non avrebbe molto senso.
Cambiare la location su speedtest è una cosa che fanno anche altri operatori "locali" (esempio Dimensione)
A proposito: TIM al MIX? 🥵🥵🥵🥵🥵
