simonebortolin
stiamo parlando di due cose diverse! 😃
sto parlando del changelog di oggi del firmware MA5671A sul form cinese, principalmente del punto 1, se poi l'image del 19 luglio va bene uguale, poco importa, anzi!
Tra l'altro, a che mtd2 si associa quell'image?
【2022.08.25】The main changes in this update are as follows:
1. Thanks to the netizen @shakesui-sam for providing the repair onu driver, which solves the problem that the stick cannot go online again after being offline when docking with a specific OLT (the stick can be online only after restarting the stick).
2. Thanks to the information provided by netizen @小yan, the option to force the creation of PVID has been added. If you cannot dial after setting the PVID in some areas, you can try to check this option.
3. A new script is added to reset the env and root passwords (the specific operation is: after connecting the fiber, unplug the fiber 5 times at an interval of 1 second, the fifth time the fiber is unplugged, and the default ip and mac can be restored , root password and other information, if the optical fiber is plugged in again after the fifth unplug, it will be regarded as giving up the reset).
fabio1999ita
fondamentalmente stanno sistemando la stabilità del tutto, da quello che ho capito
