EnzoLorio
Somone else received this update B11D on Elisa ? I'm waiting and nothing...
    pawol ok thank you
    GioAda ciao grazie... riproverò questa sera!
    Hi pawol I have read the entire thread but my non technically gifted mind can't seem to wrap my head around it.
    Im guessing this is the required step?
    https://eko.one.pl/forum/viewtopic.php?pid=260342#p260342 As this is the only tutorial i see. There seems to be a jump from "invalid firmware version" to successfully flashing TIM then Elisa
    • Marcin ha risposto a questo messaggio
      Adam2173
      Correct. First install a serial usb-ttl adaptor to X8 connection, then make a backup of all mtd partitions , then from uboot flash the TIM software...
      When you will have TIM you can use standard method to hange to Elisa.
        Marcin I don't have one of those if google search is anything to go by. If its anything outside the mf286d, my laptop and an ethernet cable then its out of my comfort zone 😄 Shame really, would love the ability to change bands with Elisa with the tools i have but seems unlikely at the moment
        Marcin received update many days ago
        GioAda niente da fare. putroppo. 🙁 c'è modo di montare il modulo mPCIe altrove per usarlo come modem esterno usb?
        • gp2k3 ha risposto a questo messaggio
          Yes , but it is problematic. First drivers , on windows they are not exist , on ubuntu it is detected as ethernet card...
          On openwrt you can do it to be detected and connection works.
          Next thing is the antennas. There are 5 uFL connectors , and most probable you have to connect antennas to all of them ( and best to know what is the split of frequency rang on each).
          Adam2173 Unfortunately we no longer have this router ...
          EnzoLorio complimenti per tenere attivo questo thread
          ZTE mc 7010 ho usato per qualche giorno una sim ho mobile sono ripassato a windtre adesso quando seleziono manualmente le bande mi dà questo errore qualcuno sa aiutarmi grazie
          repcell si, su un adattore mPCIe to usb oppure su una router board dotata di tale connettore.
          ovvimante tale porta si trova anche sui portatili ma non ti consiglio di smontarne uno per provare la scheda.
          il modem dovrebbe essere un qualcomm snapdragon X12
          Con questo software si possono selezionare 3 bande
          Tuttavia, non sono stato in grado di risolvere il problema dei falsi positivi del software anti-virus, se avete preoccupazioni, non scaricate, ma fornisco anche il file sorgente python
          Il software è molto facile da usare, basta seguire le istruzioni e inserire l’indirizzo e la password e le bande in ordine.
          https://r.virscan.org/language/it/report/85c95f21fcc076e1a9003c52cf591732
          https://www.mediafire.com/file/soclc5y768qgffy/zte_setband_2.0.1.zip/file
          password: krmUJl7BQxGoCd5
          Questa è la terza volta che lo carico, le prime due volte il sito pensava fosse un virus, quindi non poteva essere scaricato.
          @lucianom @Marcin Loro sono gli autori originali,ho solo fatto un piccolo modifiche.
            EnzoLorio come si fa a dire a windows defender che non è una minaccia??
              GioAda avevi per caso sim tim dentro quando si e aggiornato?
              • GioAda ha risposto a questo messaggio
                ciao, per gestire il modem esiste, come per huawei 535 e app HUA ctrl, una comoda app....anche per gestire le bande? Insomma nn c'e' un modo piu comodo che da browser?
                Per aggregare 3 bande ho letto qui che va tenuto su ALL. A me aggrega con wind la 7-1-3.
                Ma se volessi 7-3-38 come si fa?
                Ho ELISA b11D, gli aggiornamenti sul modem devo etnerli attivi?
                Poi nn ho capito la questione connettori antenna. Non ce scritto MAIN come in huawei.
                Ho una antenna direttiva sul tetto, questa, ha due connettori, come li devo girare sul modem?
                https://www.amazon.it/direzionale-prestazioni-compatibile-Speedport-Amplificatore/dp/B07Z653H8P?fbclid=IwAR2mPrTn7tb7TrukloYihRTRQiTHKBt53j4zgWD1er2KDV8_EqH83Tt723Q
                Grazie 🙂
                Che io sappia il router mf286d ha una gestione delle antenne esterne inesistente. Se clicchi su external antenna nel menù ti mostra una foto nella quale mostra come un'uscita (la sinistra) è fatta solo per la banda 7 e 38 mentre la destra (che è quella in linea con il connettore dell'alimentazione) tutte le altre .
                Io posseggo questo router e lo uso con PM ma ho messo lui direttamente sul terrazzo (in scatola ip65 con un sistema artigianale di dissipazione) perchè con le antenne esterne non funzionava.
                Pare che l'unico modo per usare le antenne esterne sia quello di "staccare" completamente quelle interne a livello hardware
                  andiamo bene! bell handicap ha questo router, spero ti sbagli e siano a rilevamento automatico..la presenza o meno di antenne esterne.
                  in merito alle altre domande che ho fatto sai dirmi qualcosa? grazie
