(IPQ40xx) # bootm $loadaddr
## Booting kernel from FIT Image at 84000000 ...
Using 'config@ap.dk04.1-c1' configuration
Trying 'kernel-1' kernel subimage
Description: ARM OpenWrt Linux-5.10.146
Type: Kernel Image
Compression: uncompressed
Data Start: 0x840000e4
Data Size: 6555024 Bytes = 6.3 MiB
Architecture: ARM
OS: Linux
Load Address: 0x80208000
Entry Point: 0x80208000
Hash algo: crc32
Hash value: 20682930
Hash algo: sha1
Hash value: 20f391bde99f374f1bfb73b99a11771917fbb42f
Verifying Hash Integrity ... crc32+ sha1+ OK
## Flattened Device Tree from FIT Image at 84000000
Trying 'fdt-1' FDT blob subimage
Description: ARM OpenWrt zte_mf286d device tree blob
Type: Flat Device Tree
Data Start: 0x846407a8
Data Size: 18759 Bytes = 18.3 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 73dcaa17
Hash algo: sha1
Hash value: c50d5f1dd92086ec264abaa2ecc230636556bb43
Booting using the fdt blob at 0x846407a8
Loading Kernel Image ... OK
OK
Loading Device Tree to 84ff8000, end 84fff946 ... OK
eth0 MAC Address from ART is not valid
eth1 MAC Address from ART is not valid
Using machid 0x8010001 from environment
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.10.146 (builder@buildhost) (arm-openwrt-linux-muslgnueabi-gcc (OpenWrt GCC 11.2.0 r19777-2853b6d652) 11.2.0, GNU ld (GNU Binutils) 2.37) #0 SMP Fri Oct 7 23:34:56 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: ZTE MF286D
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000080000000-0x000000008fffffff]
[ 0.000000] HighMem empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087dfffff]
[ 0.000000] node 0: [mem 0x0000000087e00000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000088000000-0x000000008fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000008fffffff]
[ 0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960
[ 0.000000] Kernel command line: ubi.mtd=rootfs root=mtd:ubi_rootfs rootfstype=squashfs rootwait ubi.mtd=rootfs root=mtd:ubi_rootfs rootfstype=squashfs rootwait root=/dev/ubiblock0_1
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 235900K/262144K available (6446K kernel code, 608K rwdata, 952K rodata, 12288K init, 246K bss, 26244K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] arch_timer: cp15 timer(s) running at 48.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xb11fd3bfb, max_idle_ns: 440795203732 ns
[ 0.000009] sched_clock: 56 bits at 48MHz, resolution 20ns, wraps every 4398046511096ns
[ 0.000025] Switching to timer-based delay loop, resolution 20ns
[ 0.000343] Calibrating delay loop (skipped), value calculated using timer frequency.. 96.00 BogoMIPS (lpj=480000)
[ 0.000370] pid_max: default: 32768 minimum: 301
[ 0.000551] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000572] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001574] CPU: Testing write buffer coherency: ok
[ 0.001931] qcom_scm: convention: smc legacy
[ 0.002866] Setting up static identity map for 0x80300000 - 0x8030003c
[ 0.003024] rcu: Hierarchical SRCU implementation.
[ 0.003284] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003646] smp: Bringing up secondary CPUs ...
[ 0.007080] smp: Brought up 1 node, 4 CPUs
[ 0.007104] SMP: Total of 4 processors activated (384.00 BogoMIPS).
[ 0.007114] CPU: All CPU(s) started in SVC mode.
[ 0.012379] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.012549] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.012575] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.012813] pinctrl core: initialized pinctrl subsystem
[ 0.014571] NET: Registered protocol family 16
[ 0.014982] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.016075] thermal_sys: Registered thermal governor 'step_wise'
[ 0.016493] cpuidle: using governor ladder
[ 0.016548] cpuidle: using governor menu
[ 0.043280] cryptd: max_cpu_qlen set to 1000
[ 0.047493] usbcore: registered new interface driver usbfs
[ 0.047563] usbcore: registered new interface driver hub
[ 0.047621] usbcore: registered new device driver usb
[ 0.047673] pps_core: LinuxPPS API ver. 1 registered
[ 0.047685] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.047712] PTP clock support registered
[ 0.049646] clocksource: Switched to clocksource arch_sys_counter
[ 0.050669] NET: Registered protocol family 2
[ 0.050923] IP idents hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.051836] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.051901] TCP established hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.051942] TCP bind hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.051994] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.052120] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.052161] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.052434] NET: Registered protocol family 1
[ 0.052483] PCI: CLS 0 bytes, default 64
[ 0.184302] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[ 0.188643] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.188665] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.319611] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.323106] bam-dma-engine 8e04000.dma: num-channels unspecified in dt
[ 0.323131] bam-dma-engine 8e04000.dma: num-ees unspecified in dt
[ 0.324497] tcsr 1949000.tcsr: setting wifi_glb_cfg = 41000000
[ 0.324598] tcsr 194b000.tcsr: setting usb hs phy mode select = e700e7
[ 0.324688] tcsr 1953000.ess_tcsr: setting ess interface select = 0
[ 0.324777] tcsr 1957000.tcsr: setting wifi_noc_memtype_m0_m2 = 2222222
[ 0.325092] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.326875] msm_serial 78af000.serial: msm_serial: detected port #0
[ 0.326923] msm_serial 78af000.serial: uartclk = 1843200
[ 0.326976] 78af000.serial: ttyMSM0 at MMIO 0x78af000 (irq = 33, base_baud = 115200) is a MSM
[ 0.327007] msm_serial: console setup on port #0
[ 0.880158] printk: console [ttyMSM0] enabled
[ 0.885308] msm_serial: driver initialized
[ 0.894017] loop: module loaded
[ 0.895690] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xf1
[ 0.896103] nand: Micron MT29F1G08ABAEAWP
[ 0.902753] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 0.906699] 12 fixed-partitions partitions found on MTD device qcom_nand.0
[ 0.914146] OF: Bad cell count for /soc/qpic-nand@79b0000/nand@0/partitions
[ 0.920979] OF: Bad cell count for /soc/qpic-nand@79b0000/nand@0/partitions
[ 0.928445] OF: Bad cell count for /soc/qpic-nand@79b0000/nand@0/partitions
[ 0.934791] OF: Bad cell count for /soc/qpic-nand@79b0000/nand@0/partitions
[ 0.942370] Creating 12 MTD partitions on "qcom_nand.0":
[ 0.948625] 0x000000000000-0x0000000a0000 : "fota-flag"
[ 0.955780] 0x0000000a0000-0x000000120000 : "ART"
[ 0.960521] 0x000000120000-0x0000001a0000 : "mac"
[ 0.965305] 0x0000001a0000-0x000000260000 : "reserved2"
[ 0.970393] 0x000000260000-0x000000660000 : "cfg-param"
[ 0.980359] 0x000000660000-0x000000a60000 : "log"
[ 0.987005] 0x000000a60000-0x000000b00000 : "oops"
[ 0.988497] 0x000000b00000-0x000001000000 : "reserved3"
[ 0.998925] 0x000001000000-0x000001800000 : "web"
[ 1.011646] 0x000001800000-0x000003500000 : "rootfs"
[ 1.056462] mtd: device 9 (rootfs) set to be root filesystem
[ 1.057081] mtdsplit: no squashfs found in "rootfs"
[ 1.061275] 0x000003500000-0x000004e00000 : "data"
[ 1.104564] 0x000004e00000-0x000008000000 : "fota"
[ 1.186343] spi_qup 78b5000.spi: IN:block:16, fifo:64, OUT:block:16, fifo:64
[ 1.188674] spi-nor spi0.0: gd25q16 (2048 Kbytes)
[ 1.192574] 8 fixed-partitions partitions found on MTD device spi0.0
[ 1.197073] Creating 8 MTD partitions on "spi0.0":
[ 1.203512] 0x000000000000-0x000000040000 : "0:SBL1"
[ 1.208654] 0x000000040000-0x000000060000 : "0:MIBIB"
[ 1.213759] 0x000000060000-0x0000000c0000 : "0:QSEE"
[ 1.218637] 0x0000000c0000-0x0000000d0000 : "0:CDT"
[ 1.223707] 0x0000000d0000-0x0000000e0000 : "0:DDRPARAMS"
[ 1.228260] 0x0000000e0000-0x0000000f0000 : "0:APPSBLENV"
[ 1.233901] 0x0000000f0000-0x0000001b0000 : "0:APPSBL"
[ 1.239261] 0x0000001b0000-0x000000200000 : "0:reserved1"
[ 1.337996] ESS reset ok!
[ 1.412214] ESS reset ok!
[ 1.930885] PHY 3 single test PSGMII issue happen!
[ 1.996587] PHY 4 single test PSGMII issue happen!
[ 2.076441] PHY3 test see issue!
[ 2.080953] PHY4 test see issue!
[ 2.155223] ESS reset ok!
[ 2.668048] PHY 3 single test PSGMII issue happen!
[ 2.733718] PHY 4 single test PSGMII issue happen!
[ 2.813581] PHY3 test see issue!
[ 2.818090] PHY4 test see issue!
[ 2.892350] ESS reset ok!
[ 3.405151] PHY 3 single test PSGMII issue happen!
[ 3.470831] PHY 4 single test PSGMII issue happen!
[ 3.550604] PHY3 test see issue!
[ 3.555117] PHY4 test see issue!
[ 3.629375] ESS reset ok!
[ 4.142270] PHY 3 single test PSGMII issue happen!
[ 4.207939] PHY 4 single test PSGMII issue happen!
[ 4.287775] PHY3 test see issue!
[ 4.292289] PHY4 test see issue!
[ 4.366575] ESS reset ok!
[ 4.879427] PHY 3 single test PSGMII issue happen!
[ 4.945094] PHY 4 single test PSGMII issue happen!
[ 5.024961] PHY3 test see issue!
[ 5.029484] PHY4 test see issue!
[ 5.103763] ESS reset ok!
[ 5.616595] PHY 3 single test PSGMII issue happen!
[ 5.682255] PHY 4 single test PSGMII issue happen!
[ 5.762096] PHY3 test see issue!
[ 5.766608] PHY4 test see issue!
[ 5.840893] ESS reset ok!
[ 6.353725] PHY 3 single test PSGMII issue happen!
[ 6.419411] PHY 4 single test PSGMII issue happen!
[ 6.499268] PHY3 test see issue!
[ 6.503761] PHY4 test see issue!
[ 6.578042] ESS reset ok!
[ 7.090893] PHY 3 single test PSGMII issue happen!
[ 7.156579] PHY 4 single test PSGMII issue happen!
[ 7.236418] PHY3 test see issue!
[ 7.240937] PHY4 test see issue!
[ 7.315225] ESS reset ok!
[ 7.828094] PHY 3 single test PSGMII issue happen!
[ 7.893773] PHY 4 single test PSGMII issue happen!
[ 7.973586] PHY3 test see issue!
[ 7.978091] PHY4 test see issue!
[ 8.052382] ESS reset ok!
[ 8.565225] PHY 3 single test PSGMII issue happen!
[ 8.630933] PHY 4 single test PSGMII issue happen!
[ 8.710786] PHY3 test see issue!
[ 8.715302] PHY4 test see issue!
[ 8.789582] ESS reset ok!
[ 9.302363] PHY 3 single test PSGMII issue happen!
[ 9.368053] PHY 4 single test PSGMII issue happen!
[ 9.447904] PHY3 test see issue!
[ 9.452434] PHY4 test see issue!
[ 9.526723] ESS reset ok!
[ 10.039620] PHY 3 single test PSGMII issue happen!
[ 10.105325] PHY 4 single test PSGMII issue happen!
[ 10.185169] PHY3 test see issue!
[ 10.189677] PHY4 test see issue!
[ 10.263966] ESS reset ok!
[ 10.776829] PHY 3 single test PSGMII issue happen!
[ 10.842495] PHY 4 single test PSGMII issue happen!
[ 10.922312] PHY3 test see issue!
[ 10.926819] PHY4 test see issue!
[ 11.001100] ESS reset ok!
[ 11.513938] PHY 3 single test PSGMII issue happen!
[ 11.579623] PHY 4 single test PSGMII issue happen!
[ 11.659493] PHY3 test see issue!
[ 11.663986] PHY4 test see issue!
[ 11.738266] ESS reset ok!
[ 12.251126] PHY 3 single test PSGMII issue happen!
[ 12.316815] PHY 4 single test PSGMII issue happen!
[ 12.396640] PHY3 test see issue!
[ 12.401124] PHY4 test see issue!
[ 12.475409] ESS reset ok!
[ 12.988249] PHY 3 single test PSGMII issue happen!
[ 13.053930] PHY 4 single test PSGMII issue happen!
[ 13.133795] PHY3 test see issue!
[ 13.138303] PHY4 test see issue!
[ 13.212567] ESS reset ok!
[ 13.725417] PHY 3 single test PSGMII issue happen!
[ 13.791117] PHY 4 single test PSGMII issue happen!
[ 13.870938] PHY3 test see issue!
[ 13.875443] PHY4 test see issue!
[ 13.949705] ESS reset ok!
[ 14.462436] PHY 3 single test PSGMII issue happen!
[ 14.528118] PHY 4 single test PSGMII issue happen!
[ 14.607950] PHY3 test see issue!
[ 14.612452] PHY4 test see issue!
[ 14.686716] ESS reset ok!
[ 15.199601] PHY 3 single test PSGMII issue happen!
[ 15.265267] PHY 4 single test PSGMII issue happen!
[ 15.345124] PHY3 test see issue!
[ 15.349625] PHY4 test see issue!
[ 15.423886] ESS reset ok!
[ 15.936704] PHY 3 single test PSGMII issue happen!
[ 16.002399] PHY 4 single test PSGMII issue happen!
[ 16.082244] PHY3 test see issue!
[ 16.086751] PHY4 test see issue!
[ 16.161020] ESS reset ok!
[ 16.673924] PHY 3 single test PSGMII issue happen!
[ 16.739626] PHY 4 single test PSGMII issue happen!
[ 16.819472] PHY3 test see issue!
[ 16.823962] PHY4 test see issue!
[ 16.898240] ESS reset ok!
[ 17.411128] PHY 3 single test PSGMII issue happen!
[ 17.476832] PHY 4 single test PSGMII issue happen!
[ 17.556713] PHY3 test see issue!
[ 17.561205] PHY4 test see issue!
[ 17.635485] ESS reset ok!
[ 18.148322] PHY 3 single test PSGMII issue happen!
[ 18.214001] PHY 4 single test PSGMII issue happen!
[ 18.293817] PHY3 test see issue!
[ 18.298330] PHY4 test see issue!
[ 18.372592] ESS reset ok!
[ 18.688474] PHY 0 single test PSGMII issue happen!
[ 18.885489] PHY 3 single test PSGMII issue happen!
[ 18.951172] PHY 4 single test PSGMII issue happen!
[ 19.017605] PHY0 test see issue!
[ 19.031041] PHY3 test see issue!
[ 19.035553] PHY4 test see issue!
[ 19.109849] ESS reset ok!
[ 19.622666] PHY 3 single test PSGMII issue happen!
[ 19.688368] PHY 4 single test PSGMII issue happen!
[ 19.768226] PHY3 test see issue!
[ 19.772723] PHY4 test see issue!
[ 19.847002] ESS reset ok!
[ 20.359815] PHY 3 single test PSGMII issue happen!
[ 20.425472] PHY 4 single test PSGMII issue happen!
[ 20.505283] PHY3 test see issue!
[ 20.509789] PHY4 test see issue!
[ 20.584074] ESS reset ok!
[ 21.096936] PHY 3 single test PSGMII issue happen!
[ 21.162605] PHY 4 single test PSGMII issue happen!
[ 21.242465] PHY3 test see issue!
[ 21.246973] PHY4 test see issue!
[ 21.321256] ESS reset ok!
[ 21.834060] PHY 3 single test PSGMII issue happen!
[ 21.899732] PHY 4 single test PSGMII issue happen!
[ 21.979578] PHY3 test see issue!
[ 21.984076] PHY4 test see issue!
[ 22.058358] ESS reset ok!
[ 22.571191] PHY 3 single test PSGMII issue happen!
[ 22.636852] PHY 4 single test PSGMII issue happen!
[ 22.716683] PHY3 test see issue!
[ 22.721192] PHY4 test see issue!
[ 22.795477] ESS reset ok!
[ 23.308291] PHY 3 single test PSGMII issue happen!
[ 23.373957] PHY 4 single test PSGMII issue happen!
[ 23.453808] PHY3 test see issue!
[ 23.458309] PHY4 test see issue!
[ 23.532578] ESS reset ok!
[ 24.045415] PHY 3 single test PSGMII issue happen!
[ 24.111122] PHY 4 single test PSGMII issue happen!
[ 24.190966] PHY3 test see issue!
[ 24.195476] PHY4 test see issue!
[ 24.269751] ESS reset ok!
[ 24.782522] PHY 3 single test PSGMII issue happen!
[ 24.848209] PHY 4 single test PSGMII issue happen!
[ 24.928040] PHY3 test see issue!
[ 24.932539] PHY4 test see issue!
[ 25.006830] ESS reset ok!
[ 25.519622] PHY 3 single test PSGMII issue happen!
[ 25.585302] PHY 4 single test PSGMII issue happen!
[ 25.665139] PHY3 test see issue!
[ 25.669645] PHY4 test see issue!
[ 25.743930] ESS reset ok!
[ 26.256790] PHY 3 single test PSGMII issue happen!
[ 26.322485] PHY 4 single test PSGMII issue happen!
[ 26.402315] PHY3 test see issue!
[ 26.406830] PHY4 test see issue!
[ 26.481115] ESS reset ok!
[ 26.993956] PHY 3 single test PSGMII issue happen!
[ 27.059631] PHY 4 single test PSGMII issue happen!
[ 27.139439] PHY3 test see issue!
[ 27.143930] PHY4 test see issue!
[ 27.218189] ESS reset ok!
[ 27.730978] PHY 3 single test PSGMII issue happen!
[ 27.796664] PHY 4 single test PSGMII issue happen!
[ 27.876517] PHY3 test see issue!
[ 27.881005] PHY4 test see issue!
[ 27.955285] ESS reset ok!
[ 28.468157] PHY 3 single test PSGMII issue happen!
[ 28.533830] PHY 4 single test PSGMII issue happen!
[ 28.613735] PHY3 test see issue!
[ 28.618240] PHY4 test see issue!
[ 28.692530] ESS reset ok!
[ 29.205385] PHY 3 single test PSGMII issue happen!
[ 29.271080] PHY 4 single test PSGMII issue happen!
[ 29.350888] PHY3 test see issue!
[ 29.355400] PHY4 test see issue!
[ 29.429663] ESS reset ok!
[ 29.942445] PHY 3 single test PSGMII issue happen!
[ 30.008128] PHY 4 single test PSGMII issue happen!
[ 30.088010] PHY3 test see issue!
[ 30.092520] PHY4 test see issue!
[ 30.166761] ESS reset ok!
[ 30.548288] PHY 1 single test PSGMII issue happen!
[ 30.679623] PHY 3 single test PSGMII issue happen!
[ 30.745300] PHY 4 single test PSGMII issue happen!
[ 30.816207] PHY1 test see issue!
[ 30.825186] PHY3 test see issue!
[ 30.829687] PHY4 test see issue!
[ 30.903972] ESS reset ok!
[ 31.416829] PHY 3 single test PSGMII issue happen!
[ 31.482521] PHY 4 single test PSGMII issue happen!
[ 31.562341] PHY3 test see issue!
[ 31.566831] PHY4 test see issue!
[ 31.641112] ESS reset ok!
[ 31.956990] PHY 0 single test PSGMII issue happen!
[ 32.022658] PHY 1 single test PSGMII issue happen!
[ 32.153981] PHY 3 single test PSGMII issue happen!
[ 32.219651] PHY 4 single test PSGMII issue happen!
[ 32.286084] PHY0 test see issue!
[ 32.290602] PHY1 test see issue!
[ 32.299572] PHY3 test see issue!
[ 32.304061] PHY4 test see issue!
[ 32.378345] ESS reset ok!
[ 32.891136] PHY 3 single test PSGMII issue happen!
[ 32.956818] PHY 4 single test PSGMII issue happen!
[ 33.036649] PHY3 test see issue!
[ 33.041142] PHY4 test see issue!
[ 33.115424] ESS reset ok!
[ 33.628257] PHY 3 single test PSGMII issue happen!
[ 33.693919] PHY 4 single test PSGMII issue happen!
[ 33.773730] PHY3 test see issue!
[ 33.778229] PHY4 test see issue!
[ 33.852518] ESS reset ok!
[ 34.168388] PHY 0 single test PSGMII issue happen!
[ 34.234078] PHY 1 single test PSGMII issue happen!
[ 34.365428] PHY 3 single test PSGMII issue happen!
[ 34.431120] PHY 4 single test PSGMII issue happen!
[ 34.497549] PHY0 test see issue!
[ 34.502051] PHY1 test see issue!
[ 34.511022] PHY3 test see issue!
[ 34.515522] PHY4 test see issue!
[ 34.589816] ESS reset ok!
[ 35.102666] PHY 3 single test PSGMII issue happen!
[ 35.168340] PHY 4 single test PSGMII issue happen!
[ 35.247797] PHY3 test see issue!
[ 35.252202] PHY4 test see issue!
[ 35.326483] ESS reset ok!
[ 35.839358] PHY 3 single test PSGMII issue happen!
[ 35.905062] PHY 4 single test PSGMII issue happen!
[ 35.984916] PHY3 test see issue!
[ 35.989420] PHY4 test see issue!
[ 36.063697] ESS reset ok!
[ 36.445242] PHY 1 single test PSGMII issue happen!
[ 36.576575] PHY 3 single test PSGMII issue happen!
[ 36.642263] PHY 4 single test PSGMII issue happen!
[ 36.713188] PHY1 test see issue!
[ 36.722163] PHY3 test see issue!
[ 36.726676] PHY4 test see issue!
[ 36.800961] ESS reset ok!
[ 37.313795] PHY 3 single test PSGMII issue happen!
[ 37.379478] PHY 4 single test PSGMII issue happen!
[ 37.459290] PHY3 test see issue!
[ 37.463783] PHY4 test see issue!
[ 37.538061] ESS reset ok!
[ 38.050869] PHY 3 single test PSGMII issue happen!
[ 38.116556] PHY 4 single test PSGMII issue happen!
[ 38.196440] PHY3 test see issue!
[ 38.200939] PHY4 test see issue!
[ 38.275225] ESS reset ok!
[ 38.788116] PHY 3 single test PSGMII issue happen!
[ 38.853797] PHY 4 single test PSGMII issue happen!
[ 38.933588] PHY3 test see issue!
[ 38.938093] PHY4 test see issue!
[ 39.012381] ESS reset ok!
[ 39.525240] PHY 3 single test PSGMII issue happen!
[ 39.590931] PHY 4 single test PSGMII issue happen!
[ 39.670785] PHY3 test see issue!
[ 39.675298] PHY4 test see issue!
[ 39.749577] ESS reset ok!
[ 40.262456] PHY 3 single test PSGMII issue happen!
[ 40.328125] PHY 4 single test PSGMII issue happen!
[ 40.407972] PHY3 test see issue!
[ 40.412476] PHY4 test see issue!
[ 40.486758] ESS reset ok!
[ 40.999606] PHY 3 single test PSGMII issue happen!
[ 41.065271] PHY 4 single test PSGMII issue happen!
[ 41.145110] PHY3 test see issue!
[ 41.149596] PHY4 test see issue!
[ 41.223852] ESS reset ok!
[ 41.736683] PHY 3 single test PSGMII issue happen!
[ 41.802379] PHY 4 single test PSGMII issue happen!
[ 41.881640] PHY3 test see issue!
[ 41.885939] PHY4 test see issue!
[ 41.960129] ESS reset ok!
[ 42.472977] PHY 3 single test PSGMII issue happen!
[ 42.538651] PHY 4 single test PSGMII issue happen!
[ 42.618501] PHY3 test see issue!
[ 42.622989] PHY4 test see issue!
[ 42.697267] ESS reset ok!
[ 43.144497] PHY 2 single test PSGMII issue happen!
[ 43.210178] PHY 3 single test PSGMII issue happen!
[ 43.275858] PHY 4 single test PSGMII issue happen!
[ 43.351191] PHY2 test see issue!
[ 43.355690] PHY3 test see issue!
[ 43.360191] PHY4 test see issue!
[ 43.434475] ESS reset ok!
[ 43.947294] PHY 3 single test PSGMII issue happen!
[ 44.013003] PHY 4 single test PSGMII issue happen!
[ 44.092862] PHY3 test see issue!
[ 44.097377] PHY4 test see issue!
[ 44.171659] ESS reset ok!
[ 44.684489] PHY 3 single test PSGMII issue happen!
[ 44.750183] PHY 4 single test PSGMII issue happen!
[ 44.830028] PHY3 test see issue!
[ 44.834531] PHY4 test see issue!
[ 44.908816] ESS reset ok!
[ 45.421681] PHY 3 single test PSGMII issue happen!
[ 45.487352] PHY 4 single test PSGMII issue happen!
[ 45.567178] PHY3 test see issue!
[ 45.571682] PHY4 test see issue!
[ 45.645969] ESS reset ok!
[ 46.158807] PHY 3 single test PSGMII issue happen!
[ 46.224502] PHY 4 single test PSGMII issue happen!
[ 46.304329] PHY3 test see issue!
[ 46.308828] PHY4 test see issue!
[ 46.383088] ESS reset ok!
[ 46.895940] PHY 3 single test PSGMII issue happen!
[ 46.961602] PHY 4 single test PSGMII issue happen!
[ 47.041436] PHY3 test see issue!
[ 47.045950] PHY4 test see issue!
[ 47.120196] ESS reset ok!
[ 47.633038] PHY 3 single test PSGMII issue happen!
[ 47.698723] PHY 4 single test PSGMII issue happen!
[ 47.778605] PHY3 test see issue!
[ 47.783105] PHY4 test see issue!
[ 47.857387] ESS reset ok!
[ 48.370189] PHY 3 single test PSGMII issue happen!
[ 48.435874] PHY 4 single test PSGMII issue happen!
[ 48.515731] PHY3 test see issue!
[ 48.520223] PHY4 test see issue!
[ 48.594480] ESS reset ok!
[ 49.107360] PHY 3 single test PSGMII issue happen!
[ 49.173024] PHY 4 single test PSGMII issue happen!
[ 49.252882] PHY3 test see issue!
[ 49.257386] PHY4 test see issue!
[ 49.331652] ESS reset ok!
[ 49.844503] PHY 3 single test PSGMII issue happen!
[ 49.910198] PHY 4 single test PSGMII issue happen!
[ 49.990057] PHY3 test see issue!
[ 49.994571] PHY4 test see issue!
[ 50.068852] ESS reset ok!
[ 50.581691] PHY 3 single test PSGMII issue happen!
[ 50.647394] PHY 4 single test PSGMII issue happen!
[ 50.727221] PHY3 test see issue!
[ 50.731713] PHY4 test see issue!
[ 50.805992] ESS reset ok!
[ 51.318782] PHY 3 single test PSGMII issue happen!
[ 51.384473] PHY 4 single test PSGMII issue happen!
[ 51.464323] PHY3 test see issue!
[ 51.468827] PHY4 test see issue!
[ 51.543069] ESS reset ok!
[ 52.055862] PHY 3 single test PSGMII issue happen!
[ 52.121540] PHY 4 single test PSGMII issue happen!
[ 52.201363] PHY3 test see issue!
[ 52.205877] PHY4 test see issue!
[ 52.280144] ESS reset ok!
[ 52.792986] PHY 3 single test PSGMII issue happen!
[ 52.858677] PHY 4 single test PSGMII issue happen!
[ 52.938506] PHY3 test see issue!
[ 52.943001] PHY4 test see issue!
[ 53.017286] ESS reset ok!
[ 53.530187] PHY 3 single test PSGMII issue happen!
[ 53.595854] PHY 4 single test PSGMII issue happen!
[ 53.675682] PHY3 test see issue!
[ 53.680196] PHY4 test see issue!
[ 53.754451] ESS reset ok!
[ 54.267287] PHY 3 single test PSGMII issue happen!
[ 54.332981] PHY 4 single test PSGMII issue happen!
[ 54.412812] PHY3 test see issue!
[ 54.417323] PHY4 test see issue!
[ 54.491587] ESS reset ok!
[ 54.807463] PHY 0 single test PSGMII issue happen!
[ 55.004486] PHY 3 single test PSGMII issue happen!
[ 55.070119] PHY 4 single test PSGMII issue happen!
[ 55.136539] PHY0 test see issue!
[ 55.150051] PHY3 test see issue!
[ 55.154575] PHY4 test see issue!
[ 55.228866] ESS reset ok!
[ 55.741704] PHY 3 single test PSGMII issue happen!
[ 55.807365] PHY 4 single test PSGMII issue happen!
[ 55.887233] PHY3 test see issue!
[ 55.891726] PHY4 test see issue!
[ 55.966010] ESS reset ok!
[ 56.413191] PHY 2 single test PSGMII issue happen!
[ 56.478897] PHY 3 single test PSGMII issue happen!
[ 56.544582] PHY 4 single test PSGMII issue happen!
[ 56.619951] PHY2 test see issue!
[ 56.624463] PHY3 test see issue!
[ 56.628964] PHY4 test see issue!
[ 56.703230] ESS reset ok!
[ 57.216067] PHY 3 single test PSGMII issue happen!
[ 57.281723] PHY 4 single test PSGMII issue happen!
[ 57.361569] PHY3 test see issue!
[ 57.366083] PHY4 test see issue!
[ 57.440351] ESS reset ok!
[ 57.953196] PHY 3 single test PSGMII issue happen!
[ 58.018881] PHY 4 single test PSGMII issue happen!
[ 58.098701] PHY3 test see issue!
[ 58.103190] PHY4 test see issue!
[ 58.177451] ESS reset ok!
[ 58.690303] PHY 3 single test PSGMII issue happen!
[ 58.755911] PHY 4 single test PSGMII issue happen!
[ 58.835725] PHY3 test see issue!
[ 58.840239] PHY4 test see issue!
[ 58.914519] ESS reset ok!
[ 59.427333] PHY 3 single test PSGMII issue happen!
[ 59.493036] PHY 4 single test PSGMII issue happen!
[ 59.572874] PHY3 test see issue!
[ 59.577386] PHY4 test see issue!
[ 59.651670] ESS reset ok!
[ 60.164519] PHY 3 single test PSGMII issue happen!
[ 60.230192] PHY 4 single test PSGMII issue happen!
[ 60.310041] PHY3 test see issue!
[ 60.314551] PHY4 test see issue!
[ 60.388814] ESS reset ok!
[ 60.901628] PHY 3 single test PSGMII issue happen!
[ 60.967310] PHY 4 single test PSGMII issue happen!
[ 61.047145] PHY3 test see issue!
[ 61.051636] PHY4 test see issue!
[ 61.125919] ESS reset ok!
[ 61.638757] PHY 3 single test PSGMII issue happen!
[ 61.704412] PHY 4 single test PSGMII issue happen!
[ 61.784247] PHY3 test see issue!
[ 61.788726] PHY4 test see issue!
[ 61.862993] ESS reset ok!
[ 62.375830] PHY 3 single test PSGMII issue happen!
[ 62.441513] PHY 4 single test PSGMII issue happen!
[ 62.521377] PHY3 test see issue!
[ 62.525890] PHY4 test see issue!
[ 62.600129] ESS reset ok!
[ 63.112930] PHY 3 single test PSGMII issue happen!
[ 63.178618] PHY 4 single test PSGMII issue happen!
[ 63.258454] PHY3 test see issue!
[ 63.262963] PHY4 test see issue!
[ 63.337225] ESS reset ok!
[ 63.850090] PHY 3 single test PSGMII issue happen!
[ 63.915791] PHY 4 single test PSGMII issue happen!
[ 63.995643] PHY3 test see issue!
[ 64.000144] PHY4 test see issue!
[ 64.074422] ESS reset ok!
[ 64.390282] PHY 0 single test PSGMII issue happen!
[ 64.587275] PHY 3 single test PSGMII issue happen!
[ 64.652964] PHY 4 single test PSGMII issue happen!
[ 64.719397] PHY0 test see issue!
[ 64.732843] PHY3 test see issue!
[ 64.737343] PHY4 test see issue!
[ 64.811608] ESS reset ok!
[ 65.324427] PHY 3 single test PSGMII issue happen!
[ 65.390111] PHY 4 single test PSGMII issue happen!
[ 65.469907] PHY3 test see issue!
[ 65.474395] PHY4 test see issue!
[ 65.548674] ESS reset ok!
[ 66.061520] PHY 3 single test PSGMII issue happen!
[ 66.127192] PHY 4 single test PSGMII issue happen!
[ 66.207052] PHY3 test see issue!
[ 66.211534] PHY4 test see issue!
[ 66.285829] ESS reset ok!
[ 66.798683] PHY 3 single test PSGMII issue happen!
[ 66.864345] PHY 4 single test PSGMII issue happen!
[ 66.944216] PHY3 test see issue!
[ 66.948701] PHY4 test see issue!
[ 67.022965] ESS reset ok!
[ 67.535874] PHY 3 single test PSGMII issue happen!
[ 67.601521] PHY 4 single test PSGMII issue happen!
[ 67.681377] PHY3 test see issue!
[ 67.685891] PHY4 test see issue!
[ 67.760135] ESS reset ok!
[ 68.076005] PHY 0 single test PSGMII issue happen!
[ 68.273002] PHY 3 single test PSGMII issue happen!
[ 68.338685] PHY 4 single test PSGMII issue happen!
[ 68.405096] PHY0 test see issue!
[ 68.418538] PHY3 test see issue!
[ 68.423045] PHY4 test see issue!
[ 68.497331] ESS reset ok!
[ 69.010244] PHY 3 single test PSGMII issue happen!
[ 69.075932] PHY 4 single test PSGMII issue happen!
[ 69.155798] PHY3 test see issue!
[ 69.160265] PHY4 test see issue!
[ 69.234528] ESS reset ok!
[ 69.747389] PHY 3 single test PSGMII issue happen!
[ 69.813083] PHY 4 single test PSGMII issue happen!
[ 69.892914] PHY3 test see issue!
[ 69.897430] PHY4 test see issue!
[ 69.971714] ESS reset ok!
[ 70.484517] PHY 3 single test PSGMII issue happen!
[ 70.550180] PHY 4 single test PSGMII issue happen!
[ 70.629994] PHY3 test see issue!
[ 70.634506] PHY4 test see issue!
[ 70.708786] ESS reset ok!
[ 71.221612] PHY 3 single test PSGMII issue happen!
[ 71.287307] PHY 4 single test PSGMII issue happen!
[ 71.367188] PHY3 test see issue!
[ 71.371681] PHY4 test see issue!
[ 71.445958] ESS reset ok!
[ 71.958789] PHY 3 single test PSGMII issue happen!
[ 72.024476] PHY 4 single test PSGMII issue happen!
[ 72.104335] PHY3 test see issue!
[ 72.108847] PHY4 test see issue!
[ 72.183130] ESS reset ok!
[ 72.695943] PHY 3 single test PSGMII issue happen!
[ 72.761608] PHY 4 single test PSGMII issue happen!
[ 72.841464] PHY3 test see issue!
[ 72.845975] PHY4 test see issue!
[ 72.920259] ESS reset ok!
[ 73.433091] PHY 3 single test PSGMII issue happen!
[ 73.498757] PHY 4 single test PSGMII issue happen!
[ 73.578582] PHY3 test see issue!
[ 73.583082] PHY4 test see issue!
[ 73.657360] ESS reset ok!
[ 74.170212] PHY 3 single test PSGMII issue happen!
[ 74.235884] PHY 4 single test PSGMII issue happen!
[ 74.315711] PHY3 test see issue!
[ 74.320210] PHY4 test see issue!
[ 74.394494] ESS reset ok!
[ 74.907272] PHY 3 single test PSGMII issue happen!
[ 74.972932] PHY 4 single test PSGMII issue happen!
[ 75.052795] PHY3 test see issue!
[ 75.057311] PHY4 test see issue!
[ 75.131600] ESS reset ok!
[ 75.382007] PSGMII cannot recover
[ 75.474977] i2c /dev entries driver
[ 75.476967] sdhci: Secure Digital Host Controller Interface driver
[ 75.477278] sdhci: Copyright(c) Pierre Ossman
[ 75.483592] sdhci-pltfm: SDHCI platform and OF driver helper
[ 75.492340] NET: Registered protocol family 10
[ 75.495308] Segment Routing with IPv6
[ 75.498024] NET: Registered protocol family 17
[ 75.501790] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 75.506027] 8021q: 802.1Q VLAN Support v1.8
[ 75.519291] Registering SWP/SWPB emulation handler
[ 75.544023] ubi0: attaching mtd9
[ 75.818128] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 158:2048, read only 64 bytes, retry
[ 75.820202] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 158:2048, read only 64 bytes, retry
[ 75.829655] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 158:2048, read only 64 bytes, retry
[ 75.840953] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 158:2048, read 64 bytes
[ 75.851422] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 75.861774] Hardware name: Generic DT based system
[ 75.867858] Function entered at [<c030cc90>] from [<c0309890>]
[ 75.872539] Function entered at [<c0309890>] from [<c0607d4c>]
[ 75.878355] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 75.884170] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 75.889987] Function entered at [<c06f4568>] from [<c06f9890>]
[ 75.895803] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 75.901619] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 75.907436] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 75.913251] Function entered at [<c0301798>] from [<c0b011ac>]
[ 75.919067] Function entered at [<c0b011ac>] from [<c0946028>]
[ 75.924883] Function entered at [<c0946028>] from [<c0300128>]
[ 75.930699] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 75.936516] bfa0: 00000000 00000000 00000000 00000000
[ 75.941644] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 75.949802] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 75.959850] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 159:2048, read only 64 bytes, retry
[ 75.965415] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 159:2048, read only 64 bytes, retry
[ 75.976873] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 159:2048, read only 64 bytes, retry
[ 75.988372] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 159:2048, read 64 bytes
[ 75.998841] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 76.009168] Hardware name: Generic DT based system
[ 76.015248] Function entered at [<c030cc90>] from [<c0309890>]
[ 76.019935] Function entered at [<c0309890>] from [<c0607d4c>]
[ 76.025750] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 76.031565] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 76.037380] Function entered at [<c06f4568>] from [<c06f9890>]
[ 76.043196] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 76.049013] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 76.054830] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 76.060644] Function entered at [<c0301798>] from [<c0b011ac>]
[ 76.066462] Function entered at [<c0b011ac>] from [<c0946028>]
[ 76.072277] Function entered at [<c0946028>] from [<c0300128>]
[ 76.078094] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 76.083912] bfa0: 00000000 00000000 00000000 00000000
[ 76.089040] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 76.097197] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 76.107228] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 160:2048, read only 64 bytes, retry
[ 76.112825] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 160:2048, read only 64 bytes, retry
[ 76.124305] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 160:2048, read only 64 bytes, retry
[ 76.135768] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 160:2048, read 64 bytes
[ 76.146209] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 76.156566] Hardware name: Generic DT based system
[ 76.162643] Function entered at [<c030cc90>] from [<c0309890>]
[ 76.167331] Function entered at [<c0309890>] from [<c0607d4c>]
[ 76.173144] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 76.178962] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 76.184777] Function entered at [<c06f4568>] from [<c06f9890>]
[ 76.190594] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 76.196408] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 76.202225] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 76.208040] Function entered at [<c0301798>] from [<c0b011ac>]
[ 76.213859] Function entered at [<c0b011ac>] from [<c0946028>]
[ 76.219674] Function entered at [<c0946028>] from [<c0300128>]
[ 76.225490] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 76.231306] bfa0: 00000000 00000000 00000000 00000000
[ 76.236437] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 76.244594] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 76.254604] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 161:2048, read only 64 bytes, retry
[ 76.260186] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 161:2048, read only 64 bytes, retry
[ 76.271679] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 161:2048, read only 64 bytes, retry
[ 76.283176] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 161:2048, read 64 bytes
[ 76.293605] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 76.303960] Hardware name: Generic DT based system
[ 76.310039] Function entered at [<c030cc90>] from [<c0309890>]
[ 76.314724] Function entered at [<c0309890>] from [<c0607d4c>]
[ 76.320542] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 76.326358] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 76.332173] Function entered at [<c06f4568>] from [<c06f9890>]
[ 76.337989] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 76.343805] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 76.349620] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 76.355436] Function entered at [<c0301798>] from [<c0b011ac>]
[ 76.361252] Function entered at [<c0b011ac>] from [<c0946028>]
[ 76.367067] Function entered at [<c0946028>] from [<c0300128>]
[ 76.372885] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 76.378701] bfa0: 00000000 00000000 00000000 00000000
[ 76.383831] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 76.391990] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 76.402011] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 162:2048, read only 64 bytes, retry
[ 76.407577] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 162:2048, read only 64 bytes, retry
[ 76.419072] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 162:2048, read only 64 bytes, retry
[ 76.430600] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 162:2048, read 64 bytes
[ 76.441001] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 76.451356] Hardware name: Generic DT based system
[ 76.457435] Function entered at [<c030cc90>] from [<c0309890>]
[ 76.462122] Function entered at [<c0309890>] from [<c0607d4c>]
[ 76.467936] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 76.473754] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 76.479569] Function entered at [<c06f4568>] from [<c06f9890>]
[ 76.485384] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 76.491202] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 76.497016] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 76.502833] Function entered at [<c0301798>] from [<c0b011ac>]
[ 76.508648] Function entered at [<c0b011ac>] from [<c0946028>]
[ 76.514463] Function entered at [<c0946028>] from [<c0300128>]
[ 76.520282] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 76.526098] bfa0: 00000000 00000000 00000000 00000000
[ 76.531227] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 76.539386] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 76.549403] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 163:2048, read only 64 bytes, retry
[ 76.554994] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 163:2048, read only 64 bytes, retry
[ 76.566467] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 163:2048, read only 64 bytes, retry
[ 76.577967] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 163:2048, read 64 bytes
[ 76.588397] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 76.598752] Hardware name: Generic DT based system
[ 76.604830] Function entered at [<c030cc90>] from [<c0309890>]
[ 76.609518] Function entered at [<c0309890>] from [<c0607d4c>]
[ 76.615333] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 76.621149] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 76.626964] Function entered at [<c06f4568>] from [<c06f9890>]
[ 76.632780] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 76.638597] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 76.644412] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 76.650229] Function entered at [<c0301798>] from [<c0b011ac>]
[ 76.656045] Function entered at [<c0b011ac>] from [<c0946028>]
[ 76.661860] Function entered at [<c0946028>] from [<c0300128>]
[ 76.667677] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 76.673494] bfa0: 00000000 00000000 00000000 00000000
[ 76.678622] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 76.686782] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 76.696803] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 164:2048, read only 64 bytes, retry
[ 76.702390] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 164:2048, read only 64 bytes, retry
[ 76.713863] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 164:2048, read only 64 bytes, retry
[ 76.725361] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 164:2048, read 64 bytes
[ 76.735791] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 76.746148] Hardware name: Generic DT based system
[ 76.752226] Function entered at [<c030cc90>] from [<c0309890>]
[ 76.756914] Function entered at [<c0309890>] from [<c0607d4c>]
[ 76.762728] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 76.768546] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 76.774361] Function entered at [<c06f4568>] from [<c06f9890>]
[ 76.780175] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 76.785992] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 76.791809] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 76.797623] Function entered at [<c0301798>] from [<c0b011ac>]
[ 76.803441] Function entered at [<c0b011ac>] from [<c0946028>]
[ 76.809255] Function entered at [<c0946028>] from [<c0300128>]
[ 76.815073] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 76.820890] bfa0: 00000000 00000000 00000000 00000000
[ 76.826019] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 76.834177] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 76.844201] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 165:2048, read only 64 bytes, retry
[ 76.849764] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 165:2048, read only 64 bytes, retry
[ 76.861261] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 165:2048, read only 64 bytes, retry
[ 76.872759] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 165:2048, read 64 bytes
[ 76.883187] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 76.893544] Hardware name: Generic DT based system
[ 76.899623] Function entered at [<c030cc90>] from [<c0309890>]
[ 76.904310] Function entered at [<c0309890>] from [<c0607d4c>]
[ 76.910124] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 76.915942] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 76.921757] Function entered at [<c06f4568>] from [<c06f9890>]
[ 76.927572] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 76.933387] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 76.939205] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 76.945019] Function entered at [<c0301798>] from [<c0b011ac>]
[ 76.950835] Function entered at [<c0b011ac>] from [<c0946028>]
[ 76.956652] Function entered at [<c0946028>] from [<c0300128>]
[ 76.962467] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 76.968287] bfa0: 00000000 00000000 00000000 00000000
[ 76.973415] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 76.981573] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 76.991586] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 166:2048, read only 64 bytes, retry
[ 76.997163] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 166:2048, read only 64 bytes, retry
[ 77.008654] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 166:2048, read only 64 bytes, retry
[ 77.020155] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 166:2048, read 64 bytes
[ 77.030577] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 77.040940] Hardware name: Generic DT based system
[ 77.047018] Function entered at [<c030cc90>] from [<c0309890>]
[ 77.051705] Function entered at [<c0309890>] from [<c0607d4c>]
[ 77.057520] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 77.063334] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 77.069153] Function entered at [<c06f4568>] from [<c06f9890>]
[ 77.074968] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 77.080784] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 77.086601] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 77.092416] Function entered at [<c0301798>] from [<c0b011ac>]
[ 77.098231] Function entered at [<c0b011ac>] from [<c0946028>]
[ 77.104050] Function entered at [<c0946028>] from [<c0300128>]
[ 77.109865] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 77.115681] bfa0: 00000000 00000000 00000000 00000000
[ 77.120811] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 77.128969] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 77.138992] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 167:2048, read only 64 bytes, retry
[ 77.144578] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 167:2048, read only 64 bytes, retry
[ 77.156049] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 167:2048, read only 64 bytes, retry
[ 77.167547] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 167:2048, read 64 bytes
[ 77.177979] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 77.188335] Hardware name: Generic DT based system
[ 77.194414] Function entered at [<c030cc90>] from [<c0309890>]
[ 77.199099] Function entered at [<c0309890>] from [<c0607d4c>]
[ 77.204917] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 77.210732] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 77.216548] Function entered at [<c06f4568>] from [<c06f9890>]
[ 77.222363] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 77.228179] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 77.233995] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 77.239811] Function entered at [<c0301798>] from [<c0b011ac>]
[ 77.245627] Function entered at [<c0b011ac>] from [<c0946028>]
[ 77.251444] Function entered at [<c0946028>] from [<c0300128>]
[ 77.257260] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 77.263076] bfa0: 00000000 00000000 00000000 00000000
[ 77.268207] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 77.276364] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 77.286385] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 168:2048, read only 64 bytes, retry
[ 77.291979] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 168:2048, read only 64 bytes, retry
[ 77.303447] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 168:2048, read only 64 bytes, retry
[ 77.314945] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 168:2048, read 64 bytes
[ 77.325376] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 77.335730] Hardware name: Generic DT based system
[ 77.341810] Function entered at [<c030cc90>] from [<c0309890>]
[ 77.346497] Function entered at [<c0309890>] from [<c0607d4c>]
[ 77.352312] Function entered at [<c0607d4c>] from [<c06f3f00>]
[ 77.358129] Function entered at [<c06f3f00>] from [<c06f4568>]
[ 77.363945] Function entered at [<c06f4568>] from [<c06f9890>]
[ 77.369759] Function entered at [<c06f9890>] from [<c06ee1d4>]
[ 77.375575] Function entered at [<c06ee1d4>] from [<c0b19f7c>]
[ 77.381391] Function entered at [<c0b19f7c>] from [<c0301798>]
[ 77.387209] Function entered at [<c0301798>] from [<c0b011ac>]
[ 77.393023] Function entered at [<c0b011ac>] from [<c0946028>]
[ 77.398839] Function entered at [<c0946028>] from [<c0300128>]
[ 77.404655] Exception stack(0xc182bfb0 to 0xc182bff8)
[ 77.410472] bfa0: 00000000 00000000 00000000 00000000
[ 77.415604] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 77.423760] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 77.433781] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 169:2048, read only 64 bytes, retry
[ 77.439348] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 169:2048, read only 64 bytes, retry
[ 77.450202] random: crng init done
[ 77.461791] ubi0 warning: 0xc06f3ecc: error -74 (ECC error) while reading 64 bytes from PEB 169:2048, read only 64 bytes, retry
[ 77.465743] ubi0 error: 0xc06f3efc: error -74 (ECC error) while reading 64 bytes from PEB 169:2048, read 64 bytes
[ 77.476153] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.146 #0
[ 77.486513] Hardware name: Generic DT based system
[ 77.492591] Function entered at [<c030cc90>] from [<c0309890>]
[ 77.497278] Function entered at [<c03
