• Apparati e reti
  • Mikrotik Corner - Guide, informazioni e aiuti sugli apparati Mikrotik
cdman La 7.4 ha risolto i problemi lte dello Chateau.
Sarebbe da provare per le altre schede.
  • cdman ha risposto a questo messaggio
  • cdman ha messo mi piace.
    LSan83 Si , sarà da vedere sul resto.
    13 giorni dopo
    5 giorni dopo
    25 giorni dopo
    Signori miei, sembra ci siano riusciti davvero.
    Ora c'è da vedere quanto è stabile 👀
    What's new in 7.5 (2022-Aug-30 12:25):
    *) bgp - fixed remote refuse capability options, max prefix limit errors and administrative stop;
    *) bgp - improved stability when "default-originate" is configured;
    *) bridge - fixed "new-priority" value validation for NAT rules;
    *) capsman - added randomized range option for "reselect-interval" parameter (CLI only);
    *) certificate - fixed handling of empty AKID by SCEP client;
    *) console - fixed automatic command completion with keypress;
    *) container - added support for running Docker (TM) containers on ARM, ARM64 and x86 (containers created before v7.4 must be recreated);
    *) defconf - fixed loading of default configuration on RB4011 with WifiWave2 package enabled;
    *) dhcpv4-server - fixed removal of dynamic leases when server is removed;
    *) dhcpv6-client - moved invalid lifetime logging message from "debug" to "error" topic;
    *) dhcpv6-client - use /128 prefix for IA_NA addresses;
    *) dhcpv6-relay - fixed relay forwarding (introduced in v7.1.5);
    *) dhcpv6-server - improved stability when acquiring binding;
    *) dns - added "address-list" parameter for static DNS entries (CLI only);
    *) dns - added "match-subdomain" option for static entries (CLI only);
    *) firewall - added support for RTSP helper;
    *) health - fixed "temperature" and "power-consumption" readings on RB1100x4;
    *) health - improved voltage reading on CRS112-8P-4S;
    *) health - renamed "cpu-temperature" to "switch-temperature" on CRS312-4C+8XG, CRS326-24S+2Q+, CRS354-48P-4S+2Q+, CRS354-48G-4S+2Q+, CRS504-4XQ-IN, CRS518-16XS-2XQ;
    *) hostpot - fixed Walled Garden functionality for HTTPS sites;
    *) hotspot - automatically reject all HTTPS requests passing through HotSpot server for unauthorized users;
    *) hotspot - improved stability when receiving bogus packets;
    *) hotspot - limit maximum allowed connections based on free RAM resources;
    *) hotspot - removed "https-redirect" option;
    *) ike2 - allow sending certificate chain as initiator;
    *) interface - fixed default interface naming on RB1100x2;
    *) l3hw - fixed HW offloaded NAT;
    *) leds - fixed default LED configuration for RBwsAP-5Hac2nD;
    *) leds - fixed wireless LED functionality on LHGG;
    *) lora - do not ignore negative sign for spoofed GPS coordinates;
    *) lte - added at-chat and NMEA port support for Simcom modems, USB composition (device id - 0x9003);
    *) lte - added at-chat support for Simcom modems, USB composition (device id - 0x9005);
    *) lte - added "SIM not inserted" and "SIM failure" messages to "status" and "monitor" commands for AT modems;
    *) lte - changed cell ID info display to short format for 3G connections;
    *) lte - disallow empty APN name only for default entry;
    *) lte - fixed AT channel for Sierra Wireless modems with device ID 0x9091;
    *) lte - fixed LTE interface presence for Telit LN940;
    *) lte - fixed UDP performance on MMIPS devices;
    *) lte - improved antenna scan for Chateau devices with switchable antennas;
    *) lte - improved configuration export when multiple LTE interfaces are present;
    *) lte - modem dialer, do not reset dialing sequence if modem reply with error to user set init-string;
    *) netinstall - fixed Netinstall procedure for ARM devices;
    *) netwatch - automatically start migrated probes from previous RouterOS versions;
    *) netwatch - changed ICMP default packet loss fail threshold to 85%;
    *) ntp - fixed NTP server when "use-local-clock" is used;
    *) ospf - fixed handling of external forwarding address;
    *) ospf - improved stability when interface is being disabled during database exchange;
    *) ovpn - fixed encryption key renewal process which caused periodic session disconnects;
    *) ovpn - improved system stability when hardware acceleration is used on ARM64 devices;
    *) ovpn - moved disconnected user logging message from "debug" to "info" topic;
    *) ping - improved service stability;
    *) port - added support for D-Link DWM-222 in serial/PPP mode (device id - 0xac01/0x7e3d);
    *) port - added support for Huawei/ZTE K5006z in serial/PPP mode (device id - 0x1017/0x1018);
    *) ppp - improved service stability under high load;
    *) ppp - use /32 as default netmask if not specified for "routes" parameter;
    *) ptp - improved system stability on CRS devices;
    *) quickset - removed PPTP and SSTP server addition for "VPN" checkbox;
    *) rb5009 - fixed ether1 status reporting after system reboot;
    *) route-filter - fixed "delete bgp-communities" command;
    *) routerboard - added "reset-button" script feature for TILE devices;
    *) sfp - fixed "eeprom" reading on single SFP port ARM devices;
    *) sfp - fixed QSFP+ and QSFP28 interface disable when using breakout cable;
    *) sfp - fixed unresponsive "sfp1" interface after disabling "ether1" on NetMetal devices;
    *) sfp - improved combo SFP ports initialization handling on CRS312-4C+8XG, CRS328-4C-20S-4S+;
    *) sfp - improved stability when using 2.5G optical modules in CCR2116, CCR2216 and CRS518;
    *) snmp - fixed usage of VRF after system startup;
    *) socks - fixed "dst-port" usage when checking access list;
    *) ssh - added AES support for PEM decryption;
    *) ssh - fixed importing of public keys;
    *) ssh - fixed minor typo issue when importing public key;
    *) sstp - fixed client stuck in "nonce matching" state;
    *) switch - fixed ACL rules for 98DXxxxx switches with more than 28 ports (introduced in v7.3);
    *) switch - removed limit for number of hardware-offloaded bonding interfaces;
    *) swos - enabled SwitchOS support for CRS310-1G-5S-4S+;
    *) swos - fixed SwOS upgrade procedure on CRS305-1G-4S+;
    *) traceroute - added "do-not-fragment" parameter support (CLI only);
    *) traceroute - increased packet size limit to 65535;
    *) vrrp - added "sync-connection-tracking" compatibility with preemption-mode;
    *) vrrp - fixed high CPU usage when "sync-connection-tracking=yes" and the backup router goes offline;
    *) vrrp - fixed HW offloaded bridge MAC address learning when changing from VRRP master to backup;
    *) vrrp - fixed initial connection tracking synchronization, a backup router now always receives all existing connections;
    *) vrrp - improved connection tracking synchronization protocol (CTSYNC), the new protocol is incompatible with previous RouterOS versions with "sync-connection-tracking=yes";
    *) webfig - allow to specify NTP server as domain name;
    *) webfig - fixed displaying of grahs in status pages;
    ) webfig - fixed floating point field's negative value in -0.** format;
    *) wifiwave2 - added "sae-pwe" parameter with hash-to-element mechanism for SAE PWE derivation;
    *) wifiwave2 - added support for 802.11k;
    *) wifiwave2 - disable wireless interface after wireless configuration reset;
    *) wifiwave2 - fixed displaying of AKM in scan results;
    *) wifiwave2 - fixed duplicated AKM in RSN message;
    *) wifiwave2 - fixed group key update for client devices which connect via fast BSS transition;
    *) wifiwave2 - fixed incorrect AKM usage for FT-WPA3-EAP-192;
    *) wifiwave2 - fixed reassociation response sending for fast transition over DS;
    *) wifiwave2 - fixed setting of "ft-nas-identifier" parameter;
    *) wifiwave2 - fixed usage of Canada country setting on US locked devices;
    *) wifiwave2 - improved default channel width selection for interfaces in station mode;
    *) winbox - do not show previously attached LTE interfaces while establishing LTE connection;
    *) winbox - enabled all filters by default under "Tools/Torch" menu;
    *) winbox - fixed "Enable", "Disable" and "Comment" functions for L2TP-ether type interfaces;
    *) winbox - fixed "Next Run" parameter displaying under "System/Scheduler" menu;
    *) winbox - fixed "Type" and "Value" field displaying under "System/Health" sub-menu's;
    *) winbox - show warning messages for BGP connection entries;
    *) wireless - fixed interface initialization on x86 devices;
    *) x86 - allow downgrading to RouterOS v6 only if it was previously installed;
    *) x86 - fixed advertising of 2500M and 5000M link speeds on ixgbe driver;
    io a dire il vero preferivo il supporto kvm...comunque mo farò un po' di prove...
    11 giorni dopo
    Mi è capitato un 4011 usato ad un ottimo prezzo, secondo voi il SoC riesce a sfruttare la WAN gigabit in PPPoE e con una VLAN?
    Chiedo perché mi pare di capire che il tunnel PPPoE usa un solo core del SoC.
    Non posso usare il fast track perché mi servono delle regole nel firewall, niente di complicato…
    Il 5009 è ancora introvabile…
      10 giorni dopo
      GioAda Senza Wi-Fi 6E☹️
      • GioAda ha risposto a questo messaggio
        bit Per me era quasi scontato...
        Ho recuperato un RB2011 e ci stavo "giocando" un po' in questi giorni. Stavo cercando di configurarlo come server VPN IPsec, ma mi sto incagliando in un probema: sembra che le porte sul firewall non si aprano, anche se (credo almeno) ho inserito le regole necessarie (vedi immagine). Qualche idea?
          Qwertyadmin Qualche idea?
          Aggiungici uno schemino di come è connesso in rete e/o almeno il dettaglio delle interfacce... altrimenti l'è dura...
            [cancellato] Giusto. Al momento la porta 1 è usata come WAN (PPPoE TIM, nome dell'interfaccia TIM), mentre il resto delle porte rame sono inserite in un bridge usato come LAN (nome interfaccia br-lan), dove al momento è collegato solo il portatile per la configurazione.
            17 giorni dopo
            Ciao a tutti, una domanda al volo: la nuova antenna Mikrotik ATL LTE18 riceve l’alimentazione dal solo collegamento Ethernet su porta PoE oppure abbisogna anche dell’alimentazione data dall’ alimentatore esterno? In pratica, si può scegliere l’uno o l’altro oppure tassativamente PoE ed alimentatore assieme? Dal loro sito non riesco a capire se funziona come le LHG.
              11 giorni dopo
              GioAda Non posso usare il fast track perché mi servono delle regole nel firewall, niente di complicato…
              Che regole devi mettere che non vanno con fasttrack??? puoi attivare fasttrack per tutto ciò che è dietro il router (NAT) ed escludere ciò che non deve andare in fasttrack (tipo VPN IPSEC o similari)
              4 giorni dopo
              sbaglio oppure è uscita la 7.6 stable la settimana scorsa? La vedo tra gli aggiornamenti del mio RB5009. Di solito è @edofullo che ci tiene aggiornati 🙂
              What's new in 7.6 (2022-Oct-17 13:55):
              *) bgp - added support for BGP advertisement displaying (CLI only);
              *) bgp - fixed reporting of session uptime;
              *) bgp - improved session establishment speed after bootup;
              *) bonding - fixed ARP monitor packets with bond's MAC address;
              *) bonding - improved interface stability on slave configuration changes;
              *) bonding - reduce "actual-mtu" according to interface "l2mtu";
              *) branding - execute "autorun.scr" file when installing branding package;
              *) capsman - fixed RADIUS accounting when EAP is used;
              *) certificate - fixed SHA1 certificate name lookup;
              *) certificate - improved certificate management, signing and storing processes;
              *) certificate - restricted maximum retry attempt window for Let's Encrypt certificate to 60 minutes;
              *) container - added "start-on-boot" parameter for automatic container startup;
              *) container - allow changing container related parameters while it is running;
              *) container - fixed usage of non-authenticated registries;
              *) dhcpv4-server - fixed matcher functionality;
              *) dhcpv4-server - fixed RADIUS accounting for local leases;
              *) dhcpv4-server - improved service stability when removing dynamic leases;
              *) dhcpv6-client - fixed false error status reporting when server offers T1 or T2 value as 0;
              *) dot1x - fixed incorrect error when using "mac-auth";
              *) ethernet - added "5Gbps" option for speed setting;
              *) firewall - added "src/dst-address-type" parameter under "IPv6/Firewall/Mangle" menu;
              *) firewall - disable IRC NAT helper on upgrade;
              *) firewall - fixed IPv6 filtering with "in/out-interface" matcher that is in VRF;
              *) firewall - fixed IRC NAT helper (CVE-2022-2663);
              *) firewall - fixed usage of "netmap" action for IPv6 source NAT;
              *) health - fixed fan speed and temperature reporting on CCR1072;
              *) health - improved voltage reading on RBmAP-2nD;
              *) hotspot - fixed service initialization when HTML directory configured on an external disk;
              *) hotspot - fixed SSL usage on all HotSpot pages;
              *) hotspot - removed "routerboard.com" URL from default HotSpot advertise;
              *) interface - added warning when interface has configured "mtu" higher than "l2mtu";
              *) ipsec - added "invalid-packets" counter for Installed SA's menu;
              *) ipsec - fixed packet processing by hardware encryption engine on MMIPS devices;
              *) l3hw - added "l3hw-settings" sub menu under the switch menu;
              *) l3hw - added support for IPv6 route offloading (disabled by default);
              *) l3hw - fixed "H" flag presence for accelerated connection tracking entries;
              *) l3hw - fixed possible packet loss when using HW offloaded NAT;
              *) l3hw - improved connected host offloading on startup;
              *) l3hw - improved connected IPv6 host offloading when routing table is nearly full for 98DX224S, 98DX226S, and 98DX3236 switch chips;
              *) l3hw - improved system stability;
              *) l3hw - made route offloading selection work only on unicast;
              *) lte - added interface name in MTU debug logging message;
              *) lte - added periodic IPv6 RS to trigger IPv6 adress acquisition for non-MBIM modems;
              *) lte - added support for Neoway N75-EA;
              *) lte - added support to perform FOTA upgrade from local file for EG12-EA, EG18-EA, RG502Q-AE, EG06-A, EP06-A modems;
              *) lte - disabled RPLMN on Chateau 5G;
              *) lte - fixed at-chat on Telit FN980m;
              *) lte - fixed handover from UMTS to LTE when PS activation had failed for MBIM modems;
              *) lte - fixed MBIM modem initialization;
              *) lte - fixed re-attaching on PS detach for MBIM modems;
              *) lte - removed reconnect delay after receiving DETACH notification for MBIM modems;
              *) macsec - added configuration support with VLAN, ARP, DHCP and bridge tagging/untagging;
              *) macsec - added logging support with "debug" and "dot1x" topics;
              *) macsec - added support for MTU and L2MTU;
              *) macsec - fixed interface after Ethernet link down;
              *) macsec - fixed interface statistics and missing properties;
              *) macsec - fixed interface status;
              *) macsec - fixed multiple interface creation on different Ethernet ports
              *) macsec - improved interface stability;
              *) macsec - improved system stability for TILE and RB5009 devices;
              *) macsec - removed interface from SMIPS devices;
              *) mac-telnet - respect interface MTU setting when sending packets for MAC-Telnet and MAC-WinBox;
              *) netwatch - fixed string variable values in script;
              *) ntp - improved initial synchronization speed after bootup;
              *) ospf - added SHA hashing for authentication;
              *) ospf - fixed area "no-summary" setting;
              *) ospf - fixed checksum calculation;
              *) ospf - fixed displaying of VRF interface in related logs;
              *) ospf - fixed transmit of LSA/ACK's on p2p interfaces;
              *) ospf - improved logging when invalid configuration is detected;
              *) ospf - refresh OSPFv3 interface configuration when IPv6 network becomes available;
              *) ovpn - added IPv6 support;
              *) ovpn - added VRF support for client;
              *) ppp - fixed memory leak;
              *) ppp - improved service stability when multiple users disconnect simultaneously;
              *) pppoe - fixed MRU negotiation even when it is set to 1500;
              *) qsfp - added interface temperature warnings and shutdown;
              *) queue - improved stability for CAKE type queues;
              *) radius - require "policy" policy for "login" service configuration;
              *) rip - fixed passwordless MD5 authentication;
              *) route-filter - fixed filtering for multiple community routes;
              *) route-filter - fixed memory allocation when moving entries;
              *) route - fixed disappearance of inactive static routes after upgrade;
              *) route - fixed memory leak;
              *) routerboard - return router's short name in "model" parameter;
              *) routerboard - set "Delete" as default key to enter booter menu ("/system routerboard upgrade" required);
              *) serial - added support for newer PL2303 serial controllers;
              *) sfp - improved QSFP/SFP interface stability for 98DXxxxx and 98PX1012 switches;
              *) sms - added "status-report-request" parameter for "send" command;
              *) sms - fixed handling of SMS send attempts on unsupported modems;
              *) snmp - improved retrieval of routing related OID's;
              *) snmp - improved stability when receiving bogus packets;
              *) ssh - increased key generation timeout;
              *) sstp - added VRF support for client;
              *) supout - added tr069-client section;
              *) supout - removed duplicate "bridge-controller" section;
              *) switch - improved traffic forwarding at 5Gbps rate for 98DX8525, 98DX4310 switches;
              *) system - renamed error messages when trying to edit or remove dynamic entries;
              *) tile - improved system stability when processing packets;
              *) tr069-client - do not allow ":" symbols in username;
              *) tr069-client - fixed reporting of "X_MIKROTIK_MimoRSRP" parameter;
              *) user-manager - accept any username for outer authentication;
              *) user-manager - added "comment" parameter for batch user creation;
              *) user-manager - added support for multiple accounting sessions;
              *) user-manager - added variables to print profile name and end time in voucher templates;
              *) user-manager - allow specifying router's address as subnet;
              *) user-manager - fixed "migrate-legacy-db" command;
              *) user-manager - fixed session expiry when it is stopped by Disconnect-Request;
              *) user-manager - forced username verification against client's certificate for EAP-TLS;
              *) user-manager - use "Class" attribute to associate user's accounting session;
              *) user - removed unused "dude" policy;
              *) vrrp - fixed connection tracking synchronization on MMIPS and MIPSBE devices;
              *) vxlan - added IPv6 support for remote VTEPs (only IPv4 or IPv6 will be used at the same time, use "vteps-ip-version" property on VXLAN interface to change the version);
              *) w60g - improved system stability (introduced in v7.5);
              *) webfig - fixed creation of new IPv6 routes;
              *) webfig - fixed displaying of "Last Seen" parameter under "IP/DHCP Server/Leases" menu;
              *) webfig - fixed hex input for "Host Uniq" field;
              *) webfig - fixed unsetting of "endpoint-address" parameter under "WireGuard/Peers" menu;
              *) wifiwave2 - fixed enabling of unconfigured interfaces;
              *) wifiwave2 - fixed malfunction of WPA3 hash-to-element technique when enabled on multiple interfaces;
              *) wifiwave2 - fixed RADIUS accounting after fast-transition;
              *) wifiwave2 - fixed "WPA Key Data Length" value in EAPOL frame when FT-EAP-SHA384 AKM is used;
              *) winbox - added "Active" prefix for current remote and local session ID fields for L2TP-Ether interfaces;
              *) winbox - added "address-list" parameter under "IP/DNS/Static" menu;
              *) winbox - added "File Name" option for "Load Config" parameter under "System/SwOS" menu;
              *) winbox - added icon for TR069-client menu;
              *) winbox - added MACsec support;
              *) winbox - added quick filtering option for route list;
              *) winbox - added "Rapid Commit" parameter support under "IPv6/DHCP-Server" menu;
              *) winbox - added "Reset Traffic Counters" button for all interfaces;
              *) winbox - added "type" and "status-report-request" parameters under "Tools/SMS" menu;
              *) winbox - allow "timeout" value to be less than 1 under "Tools/Netwatch" menu;
              *) winbox - allow to rename mounted disks;
              *) winbox - changed order of tabs under "User Manager" menu;
              *) winbox - changed "uptime" parameter format when using the wifiwave2 package;
              *) winbox - do not show unavailable features on SMIPS devices;
              *) winbox - fixed interface traffic graph drawing on RB5009;
              *) winbox - fixed maximum allowed value for VRRP's "priority" parameter;
              *) winbox - fixed "Session Uptime" value for not established sessions under "Routing/BGP" menu;
              *) winbox - fixed "Session Uptime" value under "Routing/BGP" menu;
              *) winbox - fixed "System/SwOS" window refreshing after changes are detected;
              *) winbox - fixed "User Manager/User Profiles" window refreshing after changes are detected;
              *) winbox - made "backup.swb" the default value for SwOS backup;
              *) winbox - made sessions removable in "User Manager" menu;
              *) winbox - show "F" flag for failed entries under "Interfaces/VRRP" menu;
              *) winbox - show "Switch" menu on Chateau LTE18 ax;
              *) winbox - show "System/Health" only on boards that have health monitoring;
              *) winbox - show "System/RouterBOARD/Mode Button" on devices that have such feature;
              *) wireguard - strip whitespaces from keys;
              *) wireless - disallowed using "default" as scan list or channel names;
              *) wireless - fixed incorrectly applied ingress priority to non-wireless packets;
              *) wireless - fixed missing wireless interface on some RB921GS-5HPacD devices;
              *) www - improved stability when receiving bogus packets;
              *) x86 - improved ixgbe driver support;
              14 giorni dopo
              Ciao a tutti! Questa settimana mi è arrivata a casa la nuova LHG LTE18: l'elettricista verrà fra qualche giorno a posare il cavo di rete. Ho chiesto di posare almeno un CAT7: volevo chiedervi se devo prendere qualche accorgimento per la presa del cavo di rete lato antenna, quella che rimarrà all'esterno. Devo far montare un connettore particolare? Vedo che è possibile anche collegare la terra, è preferibile/inutile farlo?
              Ho preso il kit pro per agganciare l'antenna al palo... altri suggerimenti per fare un lavoro perfetto e sicuro?
                danielet80 Ho chiesto di posare almeno un CAT7
                Non serve a nulla, anzi spesso e volentieri sono certificati solo "sulla carta" e peggiori di buoni Cat6 o 6A di marca.
                Piuttosto, assicurati se l'antenna LTE va posta all'esterno, che il cavo sia correttamente schermato e messo a terra con gli appositi apparati.
                danielet80 devo prendere qualche accorgimento per la presa del cavo di rete lato antenna, quella che rimarrà all'esterno.
                Dovrebbe finire chiuso all'interno di uno sportellino apposito per non fargli prendere acqua, ma se è un elettricista un minimo "sgamato" queste cose le sa, alla fine non è molto diverso dal montare un'antenna TV concettualmente.
                La messa a terra servirebbe sempre, ancor di più se la location è soggetta a rischio fulminazione (leggi, è il palo più alto della casa, potrebbe non servire se lo monti sotto la falda del tetto ad esempio).
