Qui c'è qualcosa che non torna. CloudFlare sta sparando aeroporti a caso che non coincidono con la realtà!
▶ curl -v https://forum.fibra.click/cdn-cgi/trace
* Trying 172.67.73.139:443...
* Trying 2606:4700:20::ac43:498b:443...
* Immediate connect fail for 2606:4700:20::ac43:498b: La rete non è raggiungibile
* Trying 2606:4700:20::681a:1b1:443...
* Immediate connect fail for 2606:4700:20::681a:1b1: La rete non è raggiungibile
* Trying 2606:4700:20::681a:b1:443...
* Immediate connect fail for 2606:4700:20::681a:b1: La rete non è raggiungibile
* Connected to forum.fibra.click (172.67.73.139) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
* CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
* TLSv1.3 (IN), TLS handshake, Certificate (11):
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
* TLSv1.3 (IN), TLS handshake, Finished (20):
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.3 (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN, server accepted to use h2
* Server certificate:
* subject: C=US; ST=CA; L=San Francisco; O=Cloudflare, Inc.; CN=sni.cloudflaressl.com
* start date: Jul 10 00:00:00 2020 GMT
* expire date: Jul 10 12:00:00 2021 GMT
* subjectAltName: host "forum.fibra.click" matched cert's "*.fibra.click"
* issuer: C=US; O=Cloudflare, Inc.; CN=Cloudflare Inc ECC CA-3
* SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x5632f03b4360)
> GET /cdn-cgi/trace HTTP/2
> Host: forum.fibra.click
> user-agent: curl/7.74.0
> accept: */*
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
* old SSL session ID is stale, removing
* Connection state changed (MAX_CONCURRENT_STREAMS == 256)!
< HTTP/2 200
< date: Mon, 25 Jan 2021 19:34:59 GMT
< content-type: text/plain
< set-cookie: __cfduid=d2f66986d524cca432c3020e5b01610961611603299; expires=Wed, 24-Feb-21 19:34:59 GMT; path=/; domain=.fibra.click; HttpOnly; SameSite=Lax; Secure
< access-control-allow-origin: *
< server: cloudflare
< cf-ray: 61746f4c8e7cf86f-GIG
< x-frame-options: DENY
< x-content-type-options: nosniff
< expires: Thu, 01 Jan 1970 00:00:01 GMT
< cache-control: no-cache
fl=216f41
h=forum.fibra.click
ip=
ts=1611603299.287
visit_scheme=https
uag=curl/7.74.0
colo=GIG
http=http/2
loc=FR
tls=TLSv1.3
sni=plaintext
warp=off
gateway=off
* Connection #0 to host forum.fibra.click left intact
▶ traceroute 172.67.73.139
traceroute to 172.67.73.139 (172.67.73.139), 30 hops max, 60 byte packets
1 LIVEBOX.local (192.168.1.1) 3.438 ms 3.356 ms 3.319 ms
2 80.10.235.137 (80.10.235.137) 5.086 ms 5.054 ms 5.024 ms
3 ae115-0.ncidf204.Paris13eArrondissement.francetelecom.net (193.253.81.202) 6.580 ms 6.538 ms 6.491 ms
4 ae41-0.niidf202.Paris15eArrondissement.francetelecom.net (193.252.98.177) 4.854 ms 6.391 ms 6.341 ms
5 193.252.137.74 (193.252.137.74) 7.929 ms 7.881 ms 7.832 ms
6 81.52.200.165 (81.52.200.165) 7.784 ms hundredgige0-1-0-0.partr2.saint-denis.opentransit.net (193.251.131.154) 5.461 ms 81.52.200.167 (81.52.200.167) 5.325 ms
7 cloudflare-18.gw.opentransit.net (193.251.150.160) 5.247 ms 25.894 ms 25.770 ms
8 172.67.73.139 (172.67.73.139) 5.750 ms 5.688 ms 5.614 ms
